07-22-2009, 10:39 AM | #1 |
Vendor
Member#: 155450
Vehicle:2007 FXT WRB |
Anyone put a silencer or small muffler on their EWG dump?
Just curious if anyone has seen anyone do this.
I dont want to, I love the sound of my EWG. But I was thinking.. (bad things happen when I do this) If you have someone, who wants an EWG, and doesnt want quite as much of the noise, what would doing say a motorcycle muffler, or a short glass packed type muffler be like. I also know that bends knock sound down, so I also wonder if extending the dump down and venting it out behind the pass side front wheel would knock it down a bit. For the purpose of this discussion, lets pretend that for whatever reason, routing it back into the turboback is NOT an option. |
07-22-2009, 11:26 AM | #2 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
I've heard of someone doing this (or at least planning on doing this) with a motorcycle muffler, but I don't remember seeing any results/videos.
07-22-2009, 11:33 AM | #3 |
Member#: 102808
Tri-State
Vehicle:1995 Built EJ207 6sp 30r ***break in*** |
confused so...
basically, you're trying to decrease in cabin noise as opposed to the noise it makes in general? |
07-22-2009, 11:36 AM | #4 |
Member#: 51961
RMIC
07-22-2009, 12:49 PM | #5 | |
Member#: 102808
Tri-State
"I also wonder if extending the dump down and venting it out behind the pass side front wheel would knock it down a bit." doesn't really make it quieter... |
07-22-2009, 01:08 PM | #6 | ||
Member#: 51961
RMIC
07-22-2009, 01:46 PM | #7 |
Member#: 58405
Vehicle:2004 Element GT65'd Hydra, Hydramist'd STi |
the effect of the bends in pipe to the volume of the sound has to do with the speed the air leaves the pipe,
more bends, more resistance on air, lower exit velocity |
07-22-2009, 02:23 PM | #8 |
Member#: 102808
Tri-State
07-22-2009, 12:36 PM | #9 |
Member#: 141952
MWSOC
Vehicle:2023 M340i |
i bought this as it was the smallest muffler i could find, havent gotten around to installing it yet. http://www.summitracing.com/parts/MPE-10444/
07-22-2009, 03:07 PM | #10 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
got that video and what wg are you using? Egg
07-22-2009, 03:44 PM | #11 |
Member#: 51961
RMIC
07-22-2009, 03:17 PM | #12 |
Member#: 143149
Tri-State
Vehicle:2006 gmc envoy stealth |
07-22-2009, 09:00 PM | #13 |
Member#: 70395
MAIC
There was another thread about this not that long ago.How about a Supertrapp/Kerker?
07-22-2009, 09:03 PM | #14 |
Vehicle:OK buy Nates beans westcoastroasting.com |
wassamatta dave....ya ricermobile finally getting to ya?!?!?!?!?!!
ya bloody wanker.....supertrap makes a small muffler that'd work a bloody muffler on the kiddie noise maker jesus dave next thing ya be doin is takin the bov off |
07-22-2009, 10:47 PM | #15 |
Member#: 163445
MWSOC
Vehicle:l33t ******* [email protected] |
http://www.importdpsonline.com/vibra.../i-165132.aspx
Don't know if they ever or still make it but its worth a shot!? |
07-22-2009, 11:09 PM | #16 |
Member#: 24890
SCIC
Vehicle:2002 Jackwagon WRB GG |
I extended the dump tube so that it ends about 10 inches back from the bend in the down pipe. Putting the sound behind you instead of in front of you makes a big difference in the cabin. Outside of the car it will still wake the dead and I have a lot of fun scaring people with it. I also feel it vibrate a little now that it's longer. I tried putting a cheap baffle in it but it didn't quiet it much and it didn't run the same so I took it out.
07-23-2009, 12:01 AM | #17 |
Member#: 141952
MWSOC
most bike mufflers are 1.5" - 1.75". i dont know what you guys run, but my dump tube is 2" thats why i got the magnaflow muffler. after searching for a couple weeks, it was the smallest one i could find.
07-23-2009, 03:52 AM | #18 |
Vendor
Member#: 155450
I was just thinking of extending it all the way to the back, then use a twin 3" in (would have to neck the EWG pipe up a bit) 4" out muffler. Obviously it would be a custom axleback to do this. That way you route it through the muffler like you had recirc'd it, but with none of the downsides of plumbing it back in.
But that would knock the sound down the same as plumbing it back in like normal. Yeah I am not looking to do this on mine. I am just brainstorming out of my own curiosity. Has anyone seen if flames come out the EWG dump? How badass would it be venting out behind the pass front wheel spewing flames at night Then you can melt your sideskirts AND rear bumper, instead of just the rear bumper. |
07-23-2009, 09:47 AM | #19 | |
Member#: 79791
MWSOC
Vehicle:2007 STI |
07-23-2009, 03:16 PM | #20 |
Member#: 23568
Vehicle:'08 Forester STi Shaggin' Wagon Thrice |
I'm pretty sure the older Porsche 930's used to run muffler's on the EWG right from the factory. May want to hit up some Porsche forum's and see if you can get your hands on one.
07-23-2009, 03:28 PM | #21 |
Member#: 108624
VIC
Vehicle:'06 SlowBaLow MEISTER |
u guys r making it way more complicated than it is.
here, just get this valve, weld one side onto the EWG dumptube, cut an opening on the side of ur downpipe and weld the other side of the valve onto the down pipe. now valve will only open when u have boost, and stays shut when out of boost. http://www.atpturbo.com/Merchant2/me...egory_Code=BCS |
07-23-2009, 04:03 PM | #22 | |
Member#: 51961
RMIC
07-23-2009, 04:25 PM | #23 | ||
Member#: 160311
Vehicle:2007 WRX Sedan Aspen white |
Found this interesting thread on a Saab forum. The guy never posted the final result but it gives an idea of what others have tried.
This is the link to the thread http://saab92x.com/viewtopic.php?id=11887 Quote:
07-23-2009, 06:17 PM | #24 | |
Vendor
Member#: 155450
07-23-2009, 06:38 PM | #25 |
Member#: 108624
VIC
nm dono y i posted that.
was something thinking to myself it would work. |
Similar Threads | ||||
Anyone Put The Perrin Equal Lenght Header On Their Car | Andreas Miko | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 20 | 07-09-2006 12:18 PM |
Anyone put a STI or WRX Shifter on a FWD Subaru?90-on | HomeSlice | Transmission (AT/MT) & Driveline | 0 | 10-01-2003 07:49 PM |
anyone running a magnaflow muffler on their legacy? | Sobelizard109 | Legacy Forum | 8 | 05-12-2003 04:52 PM |
Anyone in Eastern CT or RI with a Prodrive muffler on their WRX? | Paulie V | New England Impreza Club Forum -- NESIC | 8 | 05-11-2002 08:07 PM |
does anyone have an OBX Muffler on their RS? | biomed_eng_2000 | Technical Forum Archive | 5 | 08-26-2000 10:10 PM |
