02-26-2004, 12:31 AM | #1 |
Member#: 5796
Vehicle:2013 BRZ & 2004 WRX |
2.5 shortblock mated to 1.8 heads, will they bolt up?
I am almost possitive from reading old posts that all ej- motors are interchange able, shortblocks and longblocks.....but if so....other questons.
possible cr? how would i figure that one, say i used a phase 2 from a 00 or 01 shortblock. i would rebuild the head as well, and possibly some porting of sorts, as the 1.8 heads flow not so well.... well anyways if anyone has done this, please chime in.... -mikey |
02-26-2004, 01:21 AM | #2 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
Thats not smartness
02-26-2004, 01:48 AM | #3 |
Member#: 5796
qua?
02-26-2004, 05:07 AM | #4 |
Member#: 2181
SCIC
Vehicle:2003 Forester XS |
Translation: The 1.8 heads aren't doing a great job of filling the cylinders at 1.8 liters, so how are they going to fill cylinders of 2.5 liters?
Not very well |
02-26-2004, 04:32 PM | #5 |
Member#: 5796
i know they dont flow the best but that can be changed , i just wanted to know if they would bolt up and estimated cr darnit!
-mikey |
02-26-2004, 04:33 PM | #6 |
Member#: 5796
also the 1.8 heads are from 95, dual port, thanks for info
02-26-2004, 08:17 PM | #7 |
Member#: 2181
SCIC
Look up the spec on the valve sizes and then decide if it's going to be easy to get an EJ18 head to flow like a EJ25. While you're at it look at Kostamojen's thread on fitting EJ20 heads to the EJ25 block and see how the valves are placed on the EJ18 heads.
I'm repeating myself, so I'll **** after this: It's not worth it. http://forums.nasioc.com/forums/show...highlight=EJ20 http://forums.nasioc.com/forums/show...hreadid=492724 |
03-05-2004, 09:08 PM | #8 |
Member#: 36333
Vehicle:98 RS GT30R, closed deck madnes |
how bout ej22 heads ?
not worth it unless you have an extra ej25 sitting around and your legacy wagon needs a block...
will my ej25 from my 98 2.5rs fit on my 91 legacy ej22 heads? I think they are the same heads as the 1.8 correct? |
03-05-2004, 11:37 PM | #9 |
Member#: 45494
Vehicle:95 impreza L awd green |
yeah for the money your best bet is to swap block and heads from the 2.5 and bolt to the intake manifold as this should be the most inexpensive way to get power without rewiring
Similar Threads | ||||
Will a Harbor Freight electric impact get the job done? | THansenite | Custom Fabrication, Welding & Tools | 28 | 11-13-2010 12:53 AM |
AT&T to data users: [Nelson] HA HA! [/Nelson] | cucamelsmd15 | Off-Topic | 142 | 06-11-2010 01:08 PM |
FS : (CNJ) Konig Afternurners 18x7.5 | 04.STI | Tri-State Area Private Classifieds | 8 | 06-04-2010 06:54 PM |
stage 2 clutch | jospgut | Newbies & FAQs | 13 | 06-02-2010 03:54 PM |
will a sti 04 tranny, ds and rear diff fit a 2008 wrx? | DJIMPREZA | Transmission (AT/MT) & Driveline | 1 | 06-02-2010 11:11 AM |
