08-24-2002, 12:43 PM | #1 |
Member#: 23390
Vehicle:2010 WRX STI SE WRB |
Oil overfill
//Newbee mode ON//
3000 mile oil change; went to J____ L___ since its 100 in the shade and its a black WRX. I registered my wagon as WRX 2.0 turbo so computer would tell "staff" what filter, how much oil, etc. Bottom line: Bill said 5.0 qts - manual says 4.8. Asked about that and was told it varies with type of filter, droid says dip stick is OK. Drove home and check after letting it cool down a bit. Dip stick is about 1/4 inch above "F"! Question: Should I panic? Should I drain the 1/4 qt out? Should I drive back (not)? Yes, I know, I'll never use them again and will always change my own oil, probably using quick drain valve. Thanks for your help! //Newbee mode OFF//
08-25-2002, 12:02 PM | #2 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
Above the "F" dot in the dipstick is a notch- that notch is the mark for "full" when the oil is hot. You are fine.
Brian http://www.northursalia.com http://www.imprezamods.com http://www.scoobymods.com http://www.deniedmywarranty.org |
engine oil overfilled. | ImprezaRSfan! | Service & Maintenance | 7 | 02-14-2004 01:25 PM |
another oil overfill thread | x12oyx316x | Service & Maintenance | 9 | 10-08-2003 08:11 AM |
Oil overfill on oil change- bad? | Integra-R | Service & Maintenance | 5 | 09-28-2003 01:57 PM |
changed oil, overfilled | dingo dave | Service & Maintenance | 22 | 04-18-2003 05:22 PM |
Oil Overfilled... cause bearing wear in crank or turbo? | Vineet Singh | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 11-19-2001 12:59 AM |
