09-04-2005, 06:09 PM | #1 |
Member#: 90826
Vehicle:1997 -S14, +GC8 -blue, +grey |
underboosting in a jdm sti v.5 motor.
Hey guys... just wanted to inquire upon your wisdom regarding underboosting.
I've searched the forums and could not find anything specific to my problem but close, and i have looked into the few possibilities that were laid out but have yet to solve the problem I have a jdm v.5 sti motor, 2 days it ago it was making 17psi-19psi max boost depending on gear and rmp. Yesterday while driving down I270 and hitting WOT i noticed it was a lil slower. I checked the boost and i was only getting about 10psi or so. So what ive checked so far is driving until i hit full boost, i hit full boost right now at 10psi around 3500-4000 rpm which was normal when i was able to boost at 19psi. But instead of the boost climbing it stops at 10psi. Driving up until then 10psi and up the rpm feels normal, the motor still pulls like before. its just the boost stops at 10psi. So we visually checked the vaccum hoses, no disconnections or visual leaks. Intercooler and everything looks fine. I even emptied the oil catch can, but the can didnt seem clogged or anything, air can freely move in it. I then check the intake and noticed that the clamp from intake to turbo was broken, so i tighten it. check everything else. Reset the ECU and drove... Since there was no intake leak anymore the cars response was better, but then the underboost issue is still there. I know that underboosting can be caused by wastegate, blow off valve or bad boost solenoid other than vacuums. Is there any else i can do to check or any other factors i can look into and ways to check these mechanical issues so that i get my boost back? any help is appreciated, thanks guys. -peter.
09-04-2005, 11:30 PM | #2 |
Member#: 24565
Vehicle:2000 V6 STi RA #856 Blue |
What type of ECU are you running. Has it been reflashed or do you have a piggy back or a stand alone. The ECUs are pretty smart and will retard timing and limit boost if the gas does not support it properly.
09-05-2005, 02:28 AM | #3 | |
Member#: 90826
09-05-2005, 05:31 AM | #4 |
Member#: 24565
I would get a reflash on the ECU because I am pretty sure the octane you run on a regular basis is not the same as JDM gas!
09-05-2005, 05:58 AM | #5 |
Member#: 67608
Hmmm ... faulty wastegate control solenoid leaving you with only base-boost?
09-05-2005, 08:10 PM | #6 | |
Member#: 77886
South East
Vehicle:04 COBB stg 2 WRX Java Black Pearl |
09-06-2005, 09:59 AM | #7 |
Member#: 90826
Its a jdm ecu so i dont know what i can use for the ecu reflash.... but i will check to see if there is a bad wastegate solenoid, because it seems like it only running base boost from the wastegate.
09-06-2005, 11:26 AM | #8 |
Member#: 77886
South East
i think u can ship your ecu out to kingpin and they can reflash it for you.
09-06-2005, 05:21 PM | #9 | |
Member#: 90826
09-06-2005, 09:26 PM | #10 |
Member#: 90826
thanks for all the advice guys... im actually boosting normally now. I guess sundays ECU reset took some time to figure things out after i fixed the intake issue.
feels good around 17-20psi again. |
09-07-2005, 12:02 AM | #11 |
Member#: 77886
South East
09-07-2005, 12:11 AM | #12 | |
Member#: 51282
SCIC
Vehicle:98 RS black & blue from parking |
I know they're smart and will pull that, but driving a JDM car on 93 is kinda like driving a US WRX on 87. Why take chances with a rare, expensive motor? |
Zmax in an JDM STI motor??? | Rallly2000 | Newbies & FAQs | 6 | 01-09-2009 09:32 PM |
What Waterpump/thermostat in V7 JDM Sti motor? | aaird | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 07-11-2008 10:05 PM |
question for 2.5 STI short block swap in my jdm sti | JeremyRS | Subaru Conversions | 1 | 09-13-2006 11:12 PM |
$650 JDM sti version 5 GC8 GAB 5 way adjustable suspension COMPLETE 4 corners | supermoose | Private 'For Sale' Classifieds | 11 | 10-07-2005 08:53 AM |
underboosting in a jdm sti v.5 motor. | peters14gc | Mid Atlantic Impreza Club -- MAIC | 4 | 09-06-2005 09:27 PM |
