Old 06-24-2012, 10:47 PM   #1
axleon2
Member#: 154117
2004 WRX
JAVA BLACK PEARL
I know that this is a question that has been asked about a million times, however, after searching and searching I haven't been able to find out a solution to my problem.
I swapped an 05 STI steering wheel into my 2004 WRX. The swap went fine I was able to re-wire the horn and the cruise control in order for it to work flawlessly. The airbag was plug n play so I didnt touch the airbag wiring at all. The only thing I am having an issue with is the airbag light won't go away, I initially just used the 05 STI airbag charge when I installed it the first time, but when the airbag light wouldn't turn off I disconnected the battery again (as I did the first time as well) and swapped the WRX charge into the STI steering wheel. The light is still on. I tried disconnecting the battery once more but this time let it sit for about half an hour and it is still there!?!?
I really don't want to have to stick a resistor somewhere in order for it to go away but if that's the only solution I don't mind doing it. Also if anyone has done that do you have any pictures of where it would go?
Thanks in advance,
Ax.
axleon2 is offline   Reply With Quote
Old 06-25-2012, 10:06 AM   #2
axleon2
Member#: 154117
2004 WRX
JAVA BLACK PEARL
Bump.
Old 06-25-2012, 10:12 AM   #3
MD04WRX
Member#: 72891
2004 WRX SDN JBP
96 SVX -2012 Fiesta
Does your horn work?
I have a 05 STi steering wheel in my 04 WRX and did not have to do any re-wiring or change out any airbag parts. I reused my 04 cruise control switch. No airbag light prolbems.
MD04WRX is offline   Reply With Quote
Old 06-25-2012, 10:43 AM   #4
axleon2
Member#: 154117
2004 WRX
JAVA BLACK PEARL
Horn works fine so does the cruise control.
Yeah I don't get why some people's have been plug n play but I had to re wire it for the cruise control and horn due to the way the different cruise controls were positioned.
PLEASE HELP my DCCD light and airbag light are on... livinlocal Electrical & Lighting 15 03-23-2011 07:14 PM
FS : Seat & Steering wheel Airbag light delete - Airbag light fix resistors rubinm Interior/Dressup/Audio & Security 18 03-02-2011 09:06 PM
Airbag light is on, aftermarket seats, 4 airbag cords? subierider Interior & Exterior Modification 7 10-26-2008 05:00 PM
Replacing airbag OE seats - airbag light on? fpan Interior & Exterior Modification 4 10-19-2008 10:06 PM
Airbag light having nothing to do with airbags? coloradosti Interior & Exterior Modification 2 06-27-2004 05:02 PM
Message Board Statistics All times are GMT -4. The time now is 10:56 PM.
