06-17-2002, 07:21 PM | #1 |
Member#: 18358
Vehicle:02 WRX Wagon Midnight black pearl |
How bad is it to drop a bolt in the engine?!
Well, I was attaching the last wire of my grounding mod - the one that goes to the passenger side engine manifod... and sure enough I dropped the dam bolt in the engine!! Its LOST! nowhere to be found, and I looked for a long time.. It made 2 clinks against metal and then stopped somwhere. I'm not about to start unbolting all sorts of stuff to find it.. I used another bolt to secure the wire, but how bad is it now to have this bolt floating around??? From where I dropped it, I don't think its really in harms way of the belts/fans, but I'm not sure!
And please, no replies that just say 'your screwed' Ts (I started the car and drove it w/ no problems.. I also made some hard stops from forward and reverse trying to make it drop, but no luck) |
06-17-2002, 07:30 PM | #2 |
Member#: 3097
NWIC
Vehicle:2013 Ford Focus ST Performance Blue |
You just dropped it in the engine compartment, and not inside the engine, right? If it's just in the engine compartment, it shouldn't be a problem; heck, it probably fell out on your drive home. I've done the same thing on several of my cars, and it's never been a problem, unless I didn't have a replacement for the bolt I dropped. Now, if you somehow dropped it inside of the block or heads, that's bad, but sounds like you didn't have the engine taken apart or anything, so don't sweat it.
06-17-2002, 08:24 PM | #3 |
Member#: 11932
Tri-State
Vehicle:1998 CW ITR 2006 NBP SI |
i would say it fell out, but next time have a magnet with you or somthing that can get bolts when they fall(get a magnetic tool tray thing to, those kick ass)
06-18-2002, 08:41 AM | #4 |
Member#: 5077
Vehicle:'97 e39 540i6 Black |
Take off your intercooler and look. Will take ten minutes and you just may find it.
06-18-2002, 09:30 AM | #5 |
Member#: 15265
Vehicle:2002 WRX Wagon WR Blue |
I swear the wrx has more bolt/screw/nut/socket-catching nooks and crannies than anything else I've ever worked on! I don't think I have evr just dropped something and have it clink and clank its way all the way to the ground. Sorta eerie the way it sucks up small parts.
06-18-2002, 09:44 AM | #6 |
Member#: 13726
Vehicle:2002 WRX - 264 AWHP ION-Turbo&LINK 12.83@106 |
so true...
06-18-2002, 11:10 AM | #7 |
Member#: 8681
this is pointless
06-18-2002, 12:30 PM | #8 | |
Member#: 11932
Tri-State
i droped a bolt into a sunfire intake at school, i get my trusty magnet and i get that and i pulled out a part of the PCV system |
06-18-2002, 01:02 PM | #9 |
Member#: 10186
MWSOC
I lost the small nut that holds the clamp to join the two parts of the turbo together. Two weeks later I pulled off the IC to install a knock link and found the nut sitting on a ledge under the cruise control unit. Poor little guy didn't want to let go of my car.
06-18-2002, 01:06 PM | #10 |
Member#: 13881
MAIC
Vehicle:08 Spec B |
Whats the worse that could happen?
Check out the last two pictures on AdamsRS's Site
Ouch http://homepage.mac.com/adamsrs/PhotoAlbum15.html Last edited by EdsWRX; 06-18-2002 at 01:15 PM. |
06-18-2002, 01:18 PM | #11 |
Member#: 8828
MWSOC
Vehicle:01 BRP 2.2T Hybrid 08 Tundra |
I had a spark plug fall and get wedged under a shock absorber near the crossmember. It made my entire car virbrate at idle. It took me an hour to knock the little bastard out of there. That's probably the worst that could happen unless of course you like a free massage.
06-18-2002, 02:02 PM | #12 |
Member#: 12678
NESIC
i thought if you drop a screw in the cylinder it would just shoot out the tailpipe!
06-18-2002, 02:26 PM | #13 |
Member#: 15917
Vehicle:2002 teh FastAR rex Black like my soul |
When I first saw the title of this thread I was a little worried. I thought you actually dropped a bolt into the ENGINE itself. That would be very bad. Engine compartment is no big deal, I've lost all kinds of crap under the hood of my rex. Some pliers, a socket, a bolt... No big deal, you'll find it eventually.
06-18-2002, 03:03 PM | #14 | |
Member#: 9106
SCIC
Vehicle:2015 FXT - DGM 2008 STI - Aspen White |
For the full story, click Here |
06-18-2002, 08:04 PM | #15 |
Member#: 16172
I count how many times I have heard freinds talking about working on their old muscle cars. Putting the air filter nut on the carb for some reason. Then deciding to test fire the car without the air filter on. The secondaries would open and then "kthunk". So weird I have heard this story from multiple people.
06-19-2002, 12:23 PM | #16 |
Member#: 18791
MWSOC
Vehicle:2002 WRX wagon Silver! |
My wagon came from the factory that way...
I had to remove the grille when I installed my Supertones and found an extra clip just sitting there. The little bugger was in there for over 700 miles... |
06-23-2002, 10:42 PM | #17 |
Member#: 7979
Vehicle:2002 WRX White |
I had a Jeep Cherokee I "lost" a screw in. (no, not inside the intake). Everythong was fine so I forgot about it. Ona trip I heard a very loud screeching noise. The little bugger had worked its way down between the crank pully and the block.
Freaky, but still did no damage (except to the bolt). My nerves were sure shot after that. |
Similar Threads | ||||
Fender Liners totally trashed... =( how bad is it to run like this in MD? | Psybin | Mid Atlantic Impreza Club -- MAIC | 30 | 11-19-2009 11:19 PM |
How bad is it to use 80w-90 in cold climates?? | WRXSleeper | Transmission (AT/MT) & Driveline | 10 | 01-27-2006 12:10 PM |
how bad is it to have ear buds in all day at work? | maaw | Off-Topic | 4 | 11-08-2005 08:08 PM |
How bad is it to move with the parking brake?? | mike270 | Normally Aspirated Powertrain | 2 | 09-15-2002 12:19 AM |
How bad is it to leave out the exhaust manifold heat shields? | Blue02WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 01-10-2002 11:30 PM |
