06-01-2015, 03:41 PM | #401 |
Member#: 146732
Vehicle:2006 Impreza 2.5i Obsidian Black Swirl |
N/A power white paper, long, please critique.
Hi folks, looking for a sanity check. On a 2006 2.5i with stock redline and cams, is there any point in going with the TWE high output (2.5") header offerings, or am I better off sticking with the 2.25" super sports for a ST* autox car?
Alternatively, am I missing something fundamental about the way those 4-2-1's move the power band?
06-01-2015, 03:48 PM | #402 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
There is no 2005 2.5i.
Do you mean 2005 2.5RS or 2006 2.5i? If you mean a 2005 2.5RS, then things will improve dramatically with the High Output headers (which is what I have). You'll get a TON of extra torque all through the power band. However, the biggest gain is the fact that they keep breathing up close to 7kRPM. If you're not raising the redline, I'm not sure if the SS would be better than the HO. I'm sure if you call Tom at TWE, he'll discuss it with you. |
06-01-2015, 03:51 PM | #403 |
Member#: 146732
Meant 2006, defeated by phone keyboard once again. Editing original...
06-01-2015, 03:57 PM | #404 |
Member#: 71092
With the 2006, I'm really not sure what you'll see on stock cams, let alone vs that stock header (which is MUCH better than the older stock header). You definitely need to talk to Tom at length about your goals and limitations for the car.
06-08-2015, 03:32 PM | #405 |
Member#: 421571
Vehicle:2004 Impreza Red |
Good write up for sure!
06-11-2015, 12:30 PM | #406 |
Member#: 83764
South East
Vehicle:02 02 WRX/00 RS |
https://youtu.be/zcoE9U7M5wU
Here is mine. I have since added Area1320 TB spacer, Grimmspeed phenolic spacers and grounding kit as well as removing a crap load of weight. Havent got it re-dyno'd though |
12-08-2015, 01:04 AM | #407 | |
Member#: 374688
NWIC
Vehicle:2005 STI WRB |
12-08-2015, 02:27 PM | #408 |
Member#: 83764
South East
Getting stuff together for the fuel cell swap over and upgrading the rear suspension with a new swaybar and stout mounts as well as lateral links and arms. http://www.rs25.com/forums/f145/2222...-racing-2.html |
05-19-2016, 05:14 PM | #409 |
Member#: 447273
Does anyone have any info on the 300hp motor in the original post? The link is broken.
01-17-2017, 11:25 PM | #410 | |
Member#: 442772
Vehicle:2009 WRX sedan the faster charcoal grey |
01-18-2017, 06:32 AM | #411 |
Member#: 446519
Vehicle:2010 WRX Premium Rally Blue |
05-05-2017, 09:37 PM | #412 |
Member#: 411867
E. Canada
Vehicle:2011 Impreza 2.5i WRB |
Anybody here has ported and polisshed their headers?
05-06-2017, 12:01 PM | #413 |
Member#: 446519
It would be interesting to know how these power gains stack up against current WRX / STi numbers.
If they're pretty good, I may consider picking up an NA from a junkyard and doing a full teardown and rebuild with Stage1/2 components and just doing a swap out. It would let me put the money in when I have it, a 'little' at a time. |
05-08-2017, 12:17 PM | #414 |
Member#: 161832
Vehicle:2000 Outback Limited Black |
ScooBear... "Stage1/2 components"?
05-08-2017, 01:24 PM | #415 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
As I said in another thread, nothing really to port on tube headers. Make sure the header inlet/flange is a bit bigger than the head outlet, make sure the exposed end of the tubes is pressed against the ID of the flange. A small ballpeen hammer helps with this.
Polishing the outside is for looks, won't hurt or gain anything. |
05-08-2017, 11:22 PM | #416 |
Member#: 446519
05-09-2017, 09:53 AM | #417 |
Member#: 161832
i mean what engine parts are you considering stage 1 and/or 2?
05-10-2017, 12:28 AM | #418 | |
Member#: 446519
On a side note, knowing next to nothing about the actual mechanical makeup of a Subi engine, can the 2.5 na be resleeved? Bored over? Would be nice to bump it up to a around a 3.0L. No replacement for displacement, after all. Just a thought that crossed my mind while driving around today. |
05-11-2017, 04:55 PM | #419 |
Member#: 161832
ScooBear... N/A's won't make gobs of power. Bolt-ons and cams on a SOHC 2.5L will be somewhere around 225HP at the crank. this is my build...
http://xcceleration.com/imp-gallery-...back.25.na.htm adding high-compression pistons/internals, head work, throttle body, intake manifold, etc MAY get you around 265HP at the crank. i know of only 1 that made reliable high power as N/A... http://xcceleration.com/imp-gallery-rs.htm XXYYZZ motorsport had one that made near 300HP at the crank, but ran like crap and blew up. |
05-11-2017, 06:02 PM | #420 | |
Member#: 374688
NWIC
06-24-2017, 11:18 PM | #421 |
Member#: 469887
Almost done wading through the crap.
It's kinda disconcerting - new member, seriously considering owning a Subaru, looking at popular informative forums, and get treated to pissant bickering. Oh well, working my way to the current posts! |
06-25-2017, 12:16 AM | #422 | |
Member#: 464727
Vehicle:2008 Outback Sport OBP/DGM |
06-25-2017, 04:32 PM | #423 |
Member#: 446519
Thanks for these links, Terrainasaurus... Still unsure about the route I'm gonna take... I may just end up finding a late model sti engine at a junkyard and putting it on an engine stand, take it all the way down to the bearings and upgrade everything a little and see what I can do. Either way, I can see sinking $8k to $10k into the engine and then dropping it back into my OBS platform and enjoying my sleeper ***128527;
06-25-2017, 06:30 PM | #424 | |
Member#: 464727
Well have to get some OB-STI or OBS-T badges made |
06-25-2017, 07:58 PM | #425 |
Member#: 464727
Recently I've been debating whether or not to go TWE headers for full n/a, or get wrx/sti EL headers with a custom catback and be able to swap them onto an ej257 to take the sti swap route.
Build-up plans, please critique | bongchild | Normally Aspirated Powertrain | 11 | 09-27-2005 03:25 PM |
OT: Please Critique my resume | DrDRum | Off-Topic | 25 | 07-20-2005 04:48 PM |
Please critique this computer... | GarySheehan | Off-Topic | 67 | 09-13-2004 06:40 PM |
OT please critique my resume | suprsubepower | Off-Topic | 17 | 03-23-2004 04:15 PM |
IT/Developers please critique my resume | maaw | Off-Topic | 9 | 08-22-2003 03:16 PM |
