08-03-2009, 12:40 PM | #51 |
Member#: 1057
Vehicle:2004 WRX STi Very Yellow |
A couple of things:
1) A minimum weight was enforced for all cars. 2) 40mm restrictors were enforced for all cars. 3) Sequential gearboxes were allowed, but they had to be manually actuated (no paddle shifters). Spark cut was allowed, but that's about the extent of any fancy gearbox stuff. The Fiestas may have been able to make 800hp in their original trim, but not with the restrictors. 30 pounds of boost, 50 pounds of boost, really doesn't matter that much because you can only get so much air through that thing and excess pressure just causes heat. The Fiestas had sequential gearboxes. SRT was testing with sequentials earlier in the year, I don't know if they stuck with them or went with a more standard gearbox. The Fiestas had mechanical center diffs, the Subarus had the electronic STi center diffs. The Fiestas were much more difficult to turn in because if you touch the throttle the center locks and you have to lift off to get them to turn, then modulate the throttle through the corners to control rotation. The Subarus are much easier to drive in the twisty stuff. As Tanner said on one of the blogs, you have to drive the Fiesta very aggressively or it doesn't want to play at all. So there was no "cheating", no weight advantage, no horsepower advantage outside of what could be tuned through the 40mm restrictor and it was never a foregone conclusion that one make of car would trounce the other. If anything I would have guessed the Subarus would have an easier time of it because of how tight the course was. It looks to me like driver errors were a much bigger contributing factor than what type of car they were in. As for the format and rules and so forth, it's an ESPN TV show that happens to contain some cars similar to those we use in rallies. The fact that it's broadcast live plays a big part in why things are set up the way they are. It's just a show, not a rally. Cheers, -Doug
08-03-2009, 12:44 PM | #52 |
Member#: 70252
Vehicle:05 STI blue |
08-03-2009, 12:47 PM | #53 |
Member#: 124727
SCIC
im not sure if it has been mentioned here yet but the fiestas all had to add over 200 lbs of led weight to bring them up to the minimum weight requirement. that being said, im not sure if they were still lighter than the subies/evos or not.
08-03-2009, 12:53 PM | #54 |
Member#: 70252
was the power turned down? the announcer kept saying 800 hp.. which is the hill climb trim.
08-03-2009, 12:57 PM | #55 |
Member#: 19546
Vehicle:2009 Honda Fit |
I highly doubt they were in 800HP trim. Travis was able to keep up with Brack easily. It was the poor driving of the other drivers which made it look like it was super overpoewrd.
08-03-2009, 01:00 PM | #56 |
Member#: 70252
the straights the car definitely had to have more power.. seemed to catch all the cars on the straights.
08-03-2009, 01:06 PM | #57 | |
Member#: 692
SCIC
Vehicle:2021 Tacoma TRD Pro White |
You must have been watching a different race than me. The Fiestas didn't seem any faster than Subies to me. Just better driven. |
08-03-2009, 01:07 PM | #58 |
Member#: 7523
Vehicle:1999 Impreza 2.5 RS Black |
Brack had much cleaner lines going into the straight from the long corners. Notice all that wheel smoke from Pastrana? He was not maximizing his grip and getting a good exit speed.
08-03-2009, 01:20 PM | #59 | |
Member#: 59607
Vehicle:08 Open Class STI The works one.. |
He had to do a very quick and responsible (IMO) decision to skip the jump, especially since he had an ESPN commentator in the car with him..He did continue the run putting on a show for the fans and TV and still beating Deegan, but per rules he was DQ as soon as he crossed the line.. Xgames is a lottery, congrats to Ford for the win, they really brought some trick prototypes to the event this year and SRTUSA drivers almost got them at the end...with basically production based chassis/drivetrains.. |
08-03-2009, 01:27 PM | #60 | |
Member#: 182396
NESIC
Vehicle:2005 WRX Wagon 2004 FXT for Mrs. BeatLA |
And why were you not chosen to do the in car commentary?? I always find your pace reading to be entertaining |
08-03-2009, 01:31 PM | #61 | ||
Member#: 20952
Vehicle:BRZ & Datsun White & White |
- andrew |
08-03-2009, 01:41 PM | #62 |
Member#: 138923
SCIC
Vehicle:2000 2.5RS Coupe F8 Green |
IMO the cars were pretty damn even. If you watch Mirra vs. Brack, Mirra was damn close. When Foust ran Brack that could have easily been a Photo finish but Foust overcooked the corner cause he knew Brack was giving him a run for his money. The final was much the same way. Pastrana knew him and Brack were pretty even and was pushing, cut a corner a little too close and it cost him. A Subaru could have easily won if the driver had maintained their cool, and not panicked when someone pressured them. All in all it was a good show!
08-03-2009, 02:02 PM | #63 | |
Member#: 56
South East
Vehicle:1999 RS-T (Stage V) 2021 Audi A4 SLine 45TFSI |
Yes it did... Just like Brawn and Red Bull are beating Ferrari, McLaren & Renault in F1... or are you going to argue that Button & Vettel are better drivers than Alonso, Hamilton & Kimi? Subaru lost fair-n-square, don't go blaming the driver for it ... |
08-03-2009, 02:17 PM | #64 |
Member#: 19546
08-03-2009, 02:21 PM | #65 |
Member#: 215168
BAIC
Vehicle:2006 WRX stage 2 OS Aspen White |
08-03-2009, 02:25 PM | #66 |
Member#: 70252
08-03-2009, 02:51 PM | #67 | |
Member#: 182396
NESIC
The most disapointing thing about the whole thing is not that Ford won, it's that several of the races never finished. Block was DQ'd, Deegan was DQ'd, Pastrana DNF'd. And with Deegan's DQ, Pastrana only had one full trip around the course before the finals where Brack was on his 4th? I would bet any money that someone in the X-Games corporate side is very unhappy that between Block and Pastrana there was only 1 trip over the jump... |
08-03-2009, 03:27 PM | #68 |
Member#: 115107
NESIC
Vehicle:02 wrx wagon 61 Morris Mini |
While the jump is good for TV, it's also good for wadding up sheet metal. There has to come a point where it isn't worth the risk. Whether it is the risk to your body or your wallet. I can't imagine the landing would feel all that great if I had crashed earlier in the weekend trying to land a motorcycle stunt.
Regardless, the format needs to be tweeked, as this years incarnation did not deliver the excited of years passed in my opinion. I could care less which manufacturer or driver wins, so long as it's entertaining and more people finish than dnf. |
08-03-2009, 03:53 PM | #69 |
Member#: 3586
Vehicle:2000 RSTI Rally Car 2012 STI SWP Hatch |
I couldn't have cared less who won, just glad to see SRT-USA up against some good competition. TP's driving has matured alot, except that "early apex" got him....could have been a photo finish the way things were going. I can say that without the Ford contingent it would have been a serious snoozer...
Not the best X-Games "rally", but come on....it's going to be hard to beat McRae's roll against TP for excitement! |
08-03-2009, 03:53 PM | #70 | |
Member#: 70252
I kinda feel less sympathy for these drivers since.. no ones forcing them to do the jump. they signed up, and know the venue.. there has been a jump in all 4 years of x games. i understand what youre saying, dont get me wrong. |
08-03-2009, 04:29 PM | #71 |
Member#: 148732
SCIC
Vehicle:2018 STI Black |
Block did the right thing. If he did the jump and destroyed the car and hurt the passenger (not co-driver) I'm sure he would have gotten a good talk to. Although I do believe he did have the speed, I still think it was a smart choice. It's not like he planned on doing it, he had a matter of seconds to think "damn, something isn't right here."
Pastrana could have kept going, he wasn't wedged in at all, he had room to move around. He just gave up. If it was McRae, he would have pushed that car to the limits. The FORD's did well though and they are fast little things.Great driving from those three. I was a little disappointed, but overall it was a good show |
08-03-2009, 04:30 PM | #72 |
Member#: 15135
NWIC
Vehicle:95 GF WRX Black |
Not sure how many of you have seen this thread:
http://forums.nasioc.com/forums/show...1817075&page=8 It's pretty comical.. At least in the Motorsports forum many people have a clue. Maybe some of you might want to chime in on that one. Rally On! B- |
08-03-2009, 04:41 PM | #73 |
Member#: 39915
Vehicle:2007 Legacy GT |
Very hard to keep going the at the very least, the right front wheel was not fully attached to the car. Even with AWD, it makes steering difficult.
08-03-2009, 04:55 PM | #74 | |
Member#: 152680
They actually had more mechanical problems with the Ford's. They couldn't even fix Deegan's properly for his last race... not that it would have mattered. Either way, Breck outdrove TP.... Block made a mistake and took himself out of the race. |
08-03-2009, 04:56 PM | #75 |
Member#: 128368
Vehicle:03 WRX Wagon silver |
I just watched the replay of Pastrana and he never hit the front of his car. He came extremely close but never actually touched it.
Ford Fiestas set to break up Subaru's party at X Games 15 | BeatLA | General Community | 36 | 07-31-2009 02:08 PM |
X Games 15 Schedule & Limited Edition NOS Energy/ACP Rally Wallpapers | BoostAddictPL | Motorsports | 3 | 07-28-2009 12:23 PM |
X Games 15 Competition Schedule | ejicon | Southern California Impreza Club Forum -- SCIC | 25 | 06-19-2009 01:12 PM |
X-Games 15 Dubai | Rally Medic | Motorsports | 17 | 08-09-2008 08:27 AM |
FS: Xbox 360 premium modded plays DVDs and burned games! 15+ games, controllers, more | 1FSTREX | Non-Subaru Stuff | 9 | 10-08-2007 05:21 PM |
