07-10-2003, 10:03 AM | #1 |
Member#: 23676
NESIC
Vehicle:. |
WHY is my car so heavy? how much does yours weigh??
3350 with my fat ass in it, 1/2 tank gas, single 10" sub in small box (and not super high end super heavy sub) That also includes the spare. I would have though I would be sub 3000lbs
Here is what I have removed/replaced w/ lighter parts alternator cover (plastic) and brackets that hold it factory boost contoller brackets and cover (just bolted it to the tower) Glove box brace driver side knee brace ( I know of the danger) catless up pipe- TurboXS stealthback with no cats Coilovers (possibly same weight as factory suspension) Fog lights (mesh covers in place the whole intake horn/box/boost fluid bottle (lol) thing replaced air box with perrin short ram (lighter by a touch) All floor mats but the drivers side rear door speakers Factory radio, replaced with single din Alpine(no idea if its lighter) trunk carpet/sound mat Lighter crank/alternato pulley hood liner gone HERE IS WHAT I HAVE ADDED THAT IS/MAY BE HEAVIER 22mm whiteline sway bar front 20-24mm whiteline rear sway bar/links mid sized Eclipse amp (about 10x10x2 size) XM reciever/XM antenna 10" eclipse sub in small MDF box(prolly like 20-30 lbs, not super heavy) TurboXS TMIC GFB bov Samco IC hoses (IC outlet and recirc only) VF24 (easy 3-4lbs heavier) My 225lb ass(on a diet as of last week) The car also has P1's in 17x7 with 225/45/17 Azenis, which I hear are heavy Is it just me or is my car REALLY heavy? I keep hearing that the WRX weighs 3000lbs, but with the things I have removed, which make more/the same diff as the things I added, I would expect 3220ish or less with me in the car.
07-10-2003, 11:20 AM | #2 |
Member#: 442
NESIC
Vehicle:17 Imp Spurt 00 S2k |
My car (wagon remember) weighed in at 3050 without me in the car, 1/8 tank of gas.
The only things I've done are header/uppipe and turboback with a highflow cat, and struts that could be considered 'losing weight'. Your P1/Azenis are at least 5lbs each (total 20) over stock. P1 are 19ish lbs (so that's 3 each corner right there) and the tires are about 3-4 also over the stock 205/55-16 Bridgerocks. Is the weight of the WRX sedan with or without the rear wing? That could be more. Window washer fluid? A/C removed? Smaller Battery? Remove that stereo crap. Won't help you go fast4r. --kC |
07-10-2003, 11:41 AM | #3 |
Member#: 16876
Vehicle:2002 Impreza WRX WR Blue |
Curb weight of a 5MT sedan is 3085 lbs. I don't really see anything on your list of removed items that would qualify as a big weight saver. And like KC said, you added a heavier wheel/tire combo, and plenty of stereo stuff.
07-10-2003, 02:15 PM | #4 |
Member#: 9827
Vehicle:2002 WRX Wgn 292whp Alex Performance |
My wagon with a full tank of gas and me in it and my heavy rims comes in at 3398 Lbs. I weighed it twice 3 months appart and at different scales and it was with in a few lbs.
Alex... |
07-10-2003, 02:37 PM | #5 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
sub 2800lbs here
-Jon |
07-10-2003, 02:49 PM | #6 |
Member#: 23260
BAIC
Vehicle:Patr ick Willis for Rookie of the year |
If you really want to lose weight, lose the spare, trunk carpeting, winshield washer resivoir (not that it is that heavy but so the dumbasses who change your oil dont fill it up everyimte you take your car in), definitly lose the stereo, go to lighter rims (rota Tarmacs have the same design and are lighter, or something like Gram Lights), and change your battery to an Optima or something else that is much lighter then the heavy stock battery. Also you might want to get a trunk relocation kit for the battery so the weight you have is more evenly distributed.
07-10-2003, 06:37 PM | #7 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
3040 with my ass in it and all the crap in the back. Oddly enough, it almost seems like it's less the stock by itself, yet all I've done is add to it. I will have to roll by the scale and double-check that number tonite.
07-11-2003, 02:05 PM | #8 | |
Member#: 8679
Vehicle:2010 The most hated vehicle on the internets |
Re: WHY is my car so heavy? how much does yours weigh??
07-11-2003, 02:47 PM | #9 |
Member#: 31992
South East
Vehicle:2007 STI UGM |
Where to weigh in? I'd like to tip the scales but the car is a little too heavy to lift overhead and step on the bathroom scale with.
07-11-2003, 05:06 PM | #10 | |
Homicidal Maniac
Vehicle:2008 STI |
Re: Re: WHY is my car so heavy? how much does yours weigh??
-Jon |
07-11-2003, 07:55 PM | #11 | |
Member#: 35081
NESIC
Vehicle:2012 WRX WRB |
07-11-2003, 09:56 PM | #12 | |
Member#: 23676
NESIC
Vehicle:. |
07-11-2003, 11:15 PM | #13 |
Member#: 9090
Vehicle:09 Forester Gump 02WRX->04STi->09Gump |
my car weighs 3250 wit my skinny ass in it iirc Thats what you get when ur a ~v6 |
07-11-2003, 11:29 PM | #14 |
Member#: 33937
Vehicle:2002 Impreza WRX WRB |
Dave, it's all the rice you keep buying off KC...
07-12-2003, 05:53 AM | #15 | |
Member#: 23676
NESIC
Vehicle:. |
07-12-2003, 05:29 PM | #16 | |
Member#: 35081
NESIC
07-12-2003, 07:18 PM | #17 | |
Member#: 23676
NESIC
Vehicle:. |
I mean they ARE a very good battery, and if you ahve amonster stereo... |
07-14-2003, 11:09 AM | #18 |
Homicidal Maniac
Vehicle:2008 STI |
A dynabatt or Hawker Genesis would be what you are looking for.
-Jon |
07-14-2003, 11:03 PM | #19 |
Member#: 16523
Go on a diet.
07-17-2003, 11:29 AM | #20 |
Member#: 31624
Vehicle:02 WRX White uppipe, turbo-back, MBC |
I weighed my car completely stock with a full tank of gas. Without me in it - 3140lbs.
MY02 WRX, 5 speed, spoiler, stock 16" wheels |
07-17-2003, 11:58 AM | #21 |
Member#: 21857
Vehicle:1987 Barbie Corvette Yeah Baby |
hey guys, i have a 99rs, and i was wondering a few things regarding weight. one, my car is much heavier than a wrx, why is that? i would assume some of it is block weight, but what about the rest? and two, what are some good ways to loose massive weight on my car. i'd love to get down atleast around 3250 (3750 now). and three, where do you guys go to weigh your cars, i've always wondered that. thanks guys.
07-17-2003, 12:31 PM | #22 |
Member#: 442
NESIC
3750?????????????????????????????????????
A 99 RS is 2805 lbs according to specification from the factory. Edmunds lists it as 2840... http://www.edmunds.com/used/1999/sub...nav..6.Subaru* Was the thing totalled and all body panels replaced with 'All Steel' panels? --kC Last edited by KC; 07-17-2003 at 12:37 PM. |
07-17-2003, 12:37 PM | #23 |
Member#: 31624
You have to watch where you weigh your car. We weighed them first at a freight moving company. They were several hundreds of pounds heavier. Because they charge by the pound they altered the scales in their favor.
07-18-2003, 09:56 AM | #24 |
Member#: 19111
Full Mrt exhaust, no muffler, uppipe, cusco zero2r, rota attacks w/ azenis sports, no spare or jack, 3/8 tank of gas...thats the big stuff. oh, and i am about 165-170 lbs.
3210 lbs. 1604 RF + LR 1606 LF + RR Kev |
07-18-2003, 02:08 PM | #25 |
Member#: 12454
Vehicle:10 Toyota Taco K8 SV650SF |
My MY02 sedan weighed 3098 with me in it, with a 1/4tank of gas a helmet and a laptop computer in the pass. seat. I have minor weight reduction listed somewhere in this forum under one of my track threads.
Why is my clutch so heavy? | JonM in MN | Newbies & FAQs | 6 | 12-14-2006 11:10 AM |
Why is my car so slow? | hdrwrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 11-19-2003 07:13 AM |
What happened? Why is my car so slow now? | jigga | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 04-22-2003 11:15 PM |
Why is my car so slow? | zip_256 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 04-22-2003 07:44 PM |
Why is my car so loud..? | typeRS | Normally Aspirated Powertrain | 18 | 02-06-2002 02:23 AM |
