Tire & Wheel Forum sponsored by The Tire Rack |
09-06-2009, 12:00 AM | #1 |
Member#: 194132
Vehicle:2009 WRX Sedan SSM |
Help me understand
Why everyone is so apt to go from 17in to 18in etc sized rims just to fill in the fender well? Don't you realize that your speedometer is off and your gearing ratios have changed?
I'm confused by this trend on this forum. I'm all for reducing fender well gap, but not at the price of ****ing my mileage and gearing ratios up. Unless you can relfash for larger diameter tires/rims? I dunno. I rather just lower the darn thing on coilovers and not mess around with larger diameter tires/rims. If this logic is wrong please guide in the right direction.
09-06-2009, 12:32 AM | #2 |
Member#: 191819
Vehicle:2002 WRX Aspen White |
not sure where you're seeing people go to larger tires to get rid of wheel gap. When you plus size the wheel, you downsize the sidewall to match, so the overall diameter doesnt change.
09-06-2009, 07:39 AM | #3 |
Member#: 111506
International
Vehicle:2005 WRB STi |
^ What he said ^ Going from a 225/45/17, for example, to a XXX/40/18 or 35/18 will cut down on that inch you just gained.
09-06-2009, 09:22 AM | #4 |
Member#: 221314
Vehicle:08 STI SSM |
Heres how your speedo will be affected at 60mph... starting with 22/45/17
If you go to... 235/40/18 -- actual speed will be 61 mph 245/40/18 -- actual speed will be 61.8 mph 245/35/18 -- actual speed will be 59.5 mph As you can see, this is hardly any difference at all. |
09-06-2009, 09:38 AM | #5 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
As mentioned, correctly doing a "+1" or "+2" tire/wheel combo retains the gearing and speedo accuracy.
Granted, the rims are usually heavier with the greatest mass further out which is bad for acceleration. But hey, if that's what they want to do, then fine by me. |
09-06-2009, 09:55 AM | #6 | |
Member#: 194132
i'll stick with suspension mods rather than getting huge rims. |
09-06-2009, 12:31 PM | #7 |
Member#: 50995
Vehicle:2002 WRX Wagon |
Since I put the 305/25-20's on my wagon, my speedometer is only off 4% but you should see how da honeys be checkin out my ride.
09-06-2009, 10:05 PM | #8 |
Member#: 194132
Even a little change bothers me. Your mileage will not be correct, and with a warranty it bothers me even more.
09-06-2009, 11:00 PM | #9 |
Member#: 131067
SCIC
Vehicle:your "stance" sucks |
^ haha you're such a newb it's not even funny
do some research man. You have no idea what you are talking about. I usually don't bash on newbs, but this thread is pointless. 18's aren't huge "rims"...you find what height in inches your factory tires are and try to keep it really close to those specs. Literally every tire has their specs posted somewhere (usually on the manufacturers or dealers website) if you look. Your logic is completely wrong. Here's some generally based tire height info - http://www.jekylhyderacing.com/HeightofTires.htm some people actually go down in tire height slightly to gain a better gearing ratio. It's pretty common for WRX (5speed) owners to go to a 235/40/17 sized tire. Your speedo will be off hardly a noticeable amount, but you will notice the difference in (better) acceleration. tires don't affect your warranty. You are worried about mileage so much? That's what bothers me. You aren't going to notice much of a difference at all with any size close to factory specs if you are driving to save mileage anyways. I could understand if you put some 40lb. chrome 20's on, but we aren't talking about that. You can get lightweight 18's that would be better for performance than your stock 17's. |
09-06-2009, 11:41 PM | #10 | |
Member#: 194132
I think I know what you are saying. You can keep the same diameter in an 18in tire as you can a 17in tire, it just depends on rim width, sidewall height wanted etc. Correct? |
09-07-2009, 12:36 AM | #11 |
Vehicle:OK buy Nates beans westcoastroasting.com |
OK......here it is simple
If you want a bit more tire than stock---we'll use a 17x7 wheel and 215/45 tire as the stock size example...... In order to go to a larger tire and maintain the stock tire OD...and NOT alter the final drive ratio, which affects the spedometer....... You must change the 'aspect ratio'--the '45' in the above tire size.....that is lower it to(for this example) '40' and increase the tire width (in mm)---the 215 as above.....to 245. this makes the tire sidewall shorter in proportion to the wider width, while maintaining the OD This is all approximate, and will vary by a few percent for many possible reasons, but for the sake of this experiment, we will ignore this minor(and irrelevant to most of us) error. So now we have a wider tire, and need a wider wheel in order to maintain symmetry of the tire when mounted(some autox users ignore this for their specific, non-street, use and their usage does not apply here). Tire manufacturers have a 'recommended wheel width' range for their tires......and our 'NEW' size of 245/40 in a RE-11 has an 8-9.5" recommended wheel width range, so the new wheel would be in that width range to be 'correct' For an 18" wheel, the tire would have to be 225/40 or 255/35 with the wheel to fit those widths |
09-07-2009, 04:26 PM | #12 | |
Member#: 194132
Similar Threads | ||||
Can someone help me understand how to read compressor maps? | Carlito2002WGN | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 11-04-2002 10:19 PM |
Help me understand valve lash | Patrick Olsen | Normally Aspirated Powertrain | 7 | 08-15-2002 04:04 PM |
Help me understand the finer points of the ECU | z28dan | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-25-2002 07:22 PM |
Help me understand the Subaru Mystique... | RSKwannabe | Legacy Forum | 32 | 05-23-2002 05:36 PM |
help me understand. Why does | Rally-RS | General Community | 1 | 11-09-2001 12:35 AM |
