07-25-2001, 01:01 PM | #1 |
Member#: 6707
Vehicle:2002 WRX Wagon WR Blue Pearl |
Less power?
A simple question: if one were going on a long highway trip, would it be possible to set a boost controller for less than stock boost (say, 7 psi) and improve gas mileage? I know this would reduce power, but for highway cruising at sane (80-90 mph) speeds, not much power is needed anyway. Any ideas?
07-25-2001, 02:04 PM | #2 |
Member#: 862
The only way I know of adjusting boost is with the use of a boost controller. I can't speak for all of them, but as far as the HKS EVC-4, it won't let you lower the boost to anything less than stock.
Pete |
07-25-2001, 02:26 PM | #3 |
Member#: 6124
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
No... wouldn't do you a bit of good...
At cruise you are not boosting anyways.... Jorge (RiftsWRX) www.ProjectWRX.com |
07-25-2001, 02:31 PM | #4 |
Member#: 7374
BAIC
Vehicle:2023 MAGA Hat Model3 grey, or is it gray? |
no boost?
Is there really no boost developing at 90mph? I'm sure it is not full boost but in my old Saab 900 turbo (which came stock with a boost guage - shame on you SOA), there was a moderate amount of boost at anywhere above 60 mph or so.
My guess is that reducing max boost might help if you were driving alternating between 60-90 but not at all if you were able to maintain a constant speed. |
07-25-2001, 03:15 PM | #5 |
Member#: 4427
SWIC
Vehicle:1998 Legacy GT silver for now |
I would bet that at a constaint speed around 80mph you meaby made five PSI of boost.
07-25-2001, 03:29 PM | #6 |
Member#: 5206
Turn it Off
You could always just turn the BC off and the let spring pressure of 6 psi or so control boost.
JaMa |
07-25-2001, 03:45 PM | #7 |
Member#: 961
Vehicle:1999 RS-Tw/ CobraMAF Custom Rallispec kit/IC#1 |
RiftsWRX is right. Your not boosting at speed, so dont wast your time.
Skunkeye, not to sound like a jerk.... but... dont cruise at 90mph if you want to save gas... it aint gonna happen! 55mph will save you gas (plus you can still mess around with Mustangs if you leave your boost alone!) A Rule to remember.... never mod your car to be slower! Ever! You got it!????? |
07-25-2001, 07:56 PM | #8 |
Member#: 6707
Yeah, I know, slow down = save gas. It's just that I'm coming from a BMW that got 30+ mpg at 80-90 mpg, and the WRX is only giving me 22-23 at that speed... Just trying to find a nice compromise between actually getting where I'm going in a reasonable amount of time and wasting gas...
07-26-2001, 10:53 AM | #9 |
Member#: 6925
Vehicle:2006 Cayman S |
Less power
Keeping it out of the boost while getting to 80 MPH is what'll save your gas mileage.
07-26-2001, 11:22 AM | #10 |
Member#: 5596
TXIC
Vehicle:2010 Honda Fit Sport Black |
22-23 MPG seem a little low, even at 80-90MPH. A lot of us are getting 28-29 MPG on the freeway, at about 70-75.
I just installed my boost gauge a few days ago, but I can tell you that cruising at 80-90, you won't be boosting at all. Might be even running vacuum. Be gentle on your "go" pedal and you should get decent mileage. -Ray |
07-26-2001, 12:10 PM | #11 |
Member#: 2918
Vehicle:2002 Impreza WRX Silver Sedan |
rkkwan:
Thats pretty suprising since at 80 your doing 3200rpm roughly. And at 90 you're probably over the 3500 point so I'm pretty sure some boost would be there even with the light load of 5th gear. |
07-26-2001, 12:21 PM | #12 |
Member#: 4980
This depends a whole lot on engine load, and how far your foot is in the gas. You can actually be in vac even at 7000 rpms. At 90mph you can be in boost very quickly if you like, but your going to be cruising in vac.
-Nathan |
07-26-2001, 12:46 PM | #13 |
Member#: 3574
NESIC
Vehicle:2002 WRX Blase' Yellow----R.I.P. |
Yup Nat is right.
Easy on the acceleration and you`ll stay out of the boost for the most part. I think my mpg is pretty good for the amount of hp I have. If I wanted great mpg I`d have bought a honduh. I like the fact I can get mid to upper twentys mpg and still be able to smoke Cobra Mustangs and drive year round. Bill |
07-27-2001, 11:21 AM | #14 |
Member#: 5596
TXIC
Did a little experiment this morning. 80mph, 5th gear, with cruise control, flat road, I read between -.01 and -.02 MPA. So, it is running at vacuum at that speed.
The cruise won't go up to 90mph, but I tried as smooth as possible on the gas, and it runs about 0 to -.01MPA. -Ray |
07-27-2001, 05:45 PM | #15 |
Member#: 4764
TXIC
Vehicle:2004 STi sold :( forizzle |
28-29!!!!!! What kind of tail wind are you guys driving in? Is there any relation between gas mileage and humidity? It's 90% down here and I use 93 octane fuel. The best mileage I ever got was just over 25 running about 75-80 most of the time and no racing. I filled up in Texas and drove to Louisiana without stopping for gas or restroom. My usual mileage is about 18-19. Yes, it's completely stock w/7000 miles on it.
07-27-2001, 05:53 PM | #16 |
Member#: 5818
Vehicle:2002 WRX, '72 510 V is for Victory, Hippie! |
I agree, at best I get 24mpg between 75 and 80. Are you sure your speedo doesn't read in Km's?
07-27-2001, 06:03 PM | #17 | |
Member#: 4980
I dont even want to think about what MPG i am getting. I have my foot in it too much now that the exhaust system is on. -Nathan |
07-27-2001, 09:58 PM | #18 |
Member#: 5596
TXIC
Well, I did observe 28+ mpg on a couple of trips from Rhode Island to Canada, at about 75 mph. And I've read here on some "gas mileage" post about getting 29 mpg.
I drive my car very aggressively usually, and in mixed highway/local, I'm getting 21 mpg pretty consistently. Note that I seldom use A/C up here, so 18-19 for you guys are not too far off. BTW, I'm still the low MPG champ. 9 mpg on a race track. Still haven't seen any numbers lower than that. -Ray |
07-27-2001, 11:12 PM | #19 | |
Member#: 7994
Vehicle:2002 WRX Wagon Silver |
Doug |
07-28-2001, 12:19 AM | #20 |
Member#: 7696
A stock Cobra is not all that powerful compared to a modified WRX (Car and Driver times, except Imprezer):
Cobra: 320 HP, 0-60 in 4.8, et 13.5 @ 105 Cobra R: 385 HP, 0-60 in 4.7, et 13.2 @ 110 ($55K limited edition) Sti 22B: ~300 HP, 0-60 in 4.8, et 13.5 @ 101 Imprezer's WRX: ~340 HP, 0-60 in 4.4, et 12.8 @ 104 You should be really impressed if someone says they can smoke a Z06 Corvette or Viper. Both of those cars run in the mid 12's stock! --Jason |
07-28-2001, 06:38 AM | #21 |
Member#: 961
BrownKiler
Would you happen to know the 1/4 time for a late 98-99ish Mustang Cobra SVT? I beat one running high-13s and was curious if it was car or bad driving. FYI: stock vs stock... no way a WRX can smoke a Cobra! |
07-28-2001, 03:41 PM | #22 |
Member#: 5670
the 99 Cobra was the one with the HP problem
Many of those owners reported dyno numbers that were really, REALLY low... 98s were the 305hp model... anyhow, for MPG I get about 23-24, but its virtually all city driving. Or put it this way... in my C5 (and currently, in my girlfriend's 325i) there was a average MPH trip computer... the average speed is about 35-40mph... Its the same route I use in the WRX... its pretty sad when you think about it... traffic sucks that bad (I am out at off peak hours -- before rush hour and also during lunch)... |
07-29-2001, 02:04 AM | #23 |
Member#: 7863
Vehicle:2002 WRX |
Hmm...see what a lot of you guys dont understand is that a car like a Z06 or Cobra won't put out those numbers consistently. My friend has a Camaro SS and the car is very hard to launch due to the huge amount of torque it puts to two wheels. I can consistently take 2 car lengths on him right off the line (he catches me shortly after) in my stock Rex. Another important thing to remember is that once you know your WRX, it becomes very easy to get a good launch. And with a few mods and the better launch your Rex should not have a problem with nearly every car on the road. And if all else fails....race them in the rain.
Look at it this way: A Z06 = 13.0 is a great 1/4 mile....with an average driver lets say its a 13.3. Now you have you're WRX, with lets say TB system, boost set a 16, and air filter. Now you could be running as low as 13.5 if its set up right and you can drive. Figure it this way...on any given day any car can win. |
07-29-2001, 03:17 PM | #24 |
Member#: 3357
Vehicle:2002 WRX Black |
I think gas mileage has a directly related to your driving personality and mood.
07-30-2001, 07:38 PM | #25 | |
Member#: 5670
I'd say my personality is pretty stable, and mood the same as any other time I am in traffic -- irritated, lol!
WTT Power for Less Power | JohnST2k6k | Tri-State Area Private Classifieds | 0 | 01-11-2010 02:11 PM |
Replacement clutch=Less power? | Tomnel | Transmission (AT/MT) & Driveline | 16 | 03-04-2003 03:56 AM |
The vain? search for safe, CEL-less power | Hedonic Treadmill | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 25 | 12-31-2001 12:15 PM |
less power | WRXGAL | Newbies & FAQs | 11 | 06-22-2001 12:30 AM |
