03-20-2009, 03:18 PM | #201 |
Member#: 3409
NWIC
Vehicle:98 My FMIC Is bigger than yours. |
oh mai gawd! That poor XJ!!!
tnt longarms eh? Nice. Sorry about your loss man.
03-20-2009, 03:27 PM | #202 |
Member#: 12391
NESIC
Vehicle:I did her 5 times then 7 times, then 5 more |
Yeah, that tattered tent thingy just adds to the sadness there.
On another note, I'm garaging my Jeep for a while starting next week. While it's there, - Building/installing 4.5 stroker - installing 5 1/2" lift, sye, and rear locker that have been waiting 6 months - sliders and tube bumpers welded-up - a good winch and set of lights ...god, I can't wait to start on this. Already got the garage cleared-out. |
03-20-2009, 03:37 PM | #203 |
Member#: 3409
NWIC
Niiiiice!
My Jeep is garaged right now. Radiator end cap cracked. Then I was buttoning everything up and I stripped the tranny cooler fitting. ARGH!!!! |
03-20-2009, 03:51 PM | #204 | |
Member#: 12391
NESIC
Was out mudding with a friend the other day, in his '93 xj, when all hell broke loose. His fan shroud came loose on one corner and his fan started hitting it. This caused his slightly loose worn-out serp belt to start slipping a bit. 1/2 the width of the belt shredded and the rest slipped off. This stopped turning his alternator and water pump and the engine temp skyrocketed. The coolant pressure was too much for the system to handle and the 4-way heater valve burst. This was his first time taking it out mudding, didn't bring any tools or spare parts with him, and was starting to have a meltdown on the side of the trail. It took a bit of doing, but I got him going again. Trimmed the fray off the usable 1/2 of the serp belt and put it back on, properly tightening it. Ziptied the shroud back and rerouted the coolant hose, cutting-out the heater. Two jugs of water and a quick priming of the coolant system saw him on his way home safely. Actually, I'm going by his place after work. I helped him install a new clutch slave a few days ago, and had to show him how to safely remove/reinstall a tranny. Should have him in good shape for the weekend. |
03-20-2009, 04:20 PM | #205 |
Member#: 102682
Vehicle:... ripper's sister. |
The shrockworks parts are arriving finally.
03-20-2009, 05:45 PM | #206 | |
Member#: 3409
NWIC
Yeah nothing went supernova on mine. Ok it's a bit weird, but when I bought it almost 2 years ago the heater didn't work for ****. I figured I'd have to invest in an 8 hour dash tear-out to swap the heater core, then all of a sudden about 5 days ago the heater started working and the low coolant light turned on. Turns out the radiator end tank blew. I guess there must have been air in the system, and the crack allowed it to bleed out. Some ass clown put the wrong coolant in it before I bought it too, so it looks all muddy and brown. I went to the local radiator shop, guy said it's common for the end tanks to die, then he said my water pump was thrashed too. Hmmmmm. He's the expert... it seemed fine to me though. Then he came back with a quote of almost $900 and they could get it done that day. Ha. Right. So I went to Napa and ordered a pump, radiator, new hoses, tstat, spark plugs, serpentine belt, radiator cap, etc. Might as well, since I'm in there. Pulled the front end ALL apart. headlights, header panel, radiator, bumper, everything from the motor forward is scattered in my garage. Water pump, tstat, what a friggin DREAM compared to the old LA-style motors. Got it all back together, filled the fluids, fired it up, walked back out front, and it was dumping Mercon/Dexron out the fitting on the tranny cooler. Popped it apart, no o-ring. Damn. Found it, on the ground under a towel, buttoned it back up, and stripped out the tranny cooler. Damn. |
03-21-2009, 01:06 AM | #207 |
Member#: 117996
BAIC
Vehicle:2002 WRX Wagon 5MT White |
In all honesty, I couldn't tell you where I posted it. I saw this thread for the first time and decided to share the vids. I believe that the videos have gone arround places like NAXJA and pirate4x4...
03-21-2009, 03:34 PM | #208 |
Member#: 47926
SCIC
Vehicle:2017 STi CWP |
03-21-2009, 03:38 PM | #209 |
Member#: 3409
NWIC
Not a mod over there, just been around so damned long that I got grandfathered into lifetime member.
03-23-2009, 02:09 PM | #210 | |
Member#: 12391
NESIC
Yeah, Jeep motors are easy as hell to work on. Replacing a head, water pump, thermostat... it's all easy stuff. A lot of stuff that AMC borrowed from Chevy that Chrysler had the foresight to leave alone. |
03-23-2009, 07:32 PM | #211 |
Member#: 47926
SCIC
05-09-2010, 11:26 PM | #212 |
NASIOC SUPER Supporter
n00b jesus Member#: 200000
RMIC
Vehicle:2012 Wrangler |
Anyone know how to add a snorkel to an 03 grand cherokee (V8)? My friend wants to add one, but apparently no one makes one for it. I've heard that one for an xterra can be modified to fit, but I don't know how true that is. Anyone have experience with this?
05-09-2010, 11:40 PM | #213 |
Member#: 233929
Vehicle:2004 WRX sedan WR Blue |
Just checking in on this thread with my wife's JK Wrangler X. We bought it new last February and so far all we've done is cosmetic (decals and brush guard). She really loves off-roading, so mods definitely are in this Jeep's future. The only problem is that my wife has a rare arthritic condition that affects her ability to lift and climb some days, so a lift is pretty much out of the question since this is her DD. We're going to do some wheels with beefier tires (will probably have to modify the fenders to make them fit without a lift), skid plates, and whatever else we can to get it trail ready. Any suggestions?
Obiligatory whoring: |
05-09-2010, 11:44 PM | #214 |
RMIC
If you plan on doing anything more than light offroading you'll want to invest in some armor (skid plates, rock sliders, etc.)
05-09-2010, 11:50 PM | #215 |
Member#: 165457
BAIC
Vehicle:'02 CBR F4i Red '89 BroRunner Black |
yotas can play too. I was pretty impressed with mine (black runner) considering the suspension is 100% stock and its IFS. My buddies has a lift and is solid front axle
Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Last edited by saltYmirv; 05-09-2010 at 11:55 PM. |
05-09-2010, 11:51 PM | #216 |
Member#: 22035
SCIC
Vehicle:2014 Brocoma DCab 71 FJ40, 13 DRZ400SM |
i see a part number for that jeep. maybe call up a dealer for them and see whats up PN SS1140HF
05-09-2010, 11:52 PM | #217 |
Member#: 47926
SCIC
Big Bear?
05-09-2010, 11:54 PM | #218 |
Member#: 22035
SCIC
now do a SAS on that yota and you will be gold
05-09-2010, 11:58 PM | #219 |
Member#: 165457
BAIC
Bear River Reservoir, yes. Great spot
I have a complete SA, arc welder and torch. I need all the mounting stuff, springs, shocks and a lift for the rear to match. I was thinking the 63" chevy swap would work out nice. also want to make a rear bumper |
05-10-2010, 12:01 AM | #220 |
Member#: 47926
SCIC
That used to be my second home between off-roading and snowboarding haha.
05-10-2010, 12:04 AM | #221 |
Member#: 165457
BAIC
05-10-2010, 12:07 AM | #222 |
Member#: 47926
SCIC
Nice man...gotta love a good wheelin trip.
05-10-2010, 12:07 AM | #223 |
Member#: 43748
TXIC
copied from my thread in txic
so, in about a month i will have this in this plus this http://www.offroadevolution.com/stor...d=EVO-COILOVER http://www.offroadevolution.com/stor...prod=EVO-LEVER the tranny should be in this week. getrag-238 6spd manual shaun h |
05-10-2010, 12:23 AM | #224 |
Member#: 180769
NESIC
Vehicle:lots of junkers |
92 subaru loyale, 4" lift, 235/75r15's, EJ22 out of a legacy, dual range 4x4 tranny out of an older GL, clutch type LSD in the rear, homebuilt front bumper, skidplates, and lots of repairs to the body. It's missing the winch in that pic because I rear-ended a ford ranger and popped the magnets loose inside the winch motor. 9k MM normally fills the hole in the grill. 71 Ford Bronco. 302, 3spd. I'm building a 351 for it now, and looking for a 5spd. It can do 110mph with the 3spd and 4.11:1's but the MPG would be a fair bit better with the 5spd. It has a 2.5" suspension lift now, and a roll bar in the back. |
05-10-2010, 12:59 AM | #225 | |
Member#: 233929
Freakin' WIN. Please post up some finished pics and vids! |
with all the gay and straight threads | [27] | Off-Topic | 27 | 05-08-2013 06:31 PM |
the Official Rally/Off-Road thread? | Longitude | Member's Car Gallery | 178 | 09-05-2006 05:39 PM |
Why all the bestiality and dehydration threads today??? | Grap | Off-Topic | 15 | 01-11-2006 03:55 PM |
this site is dwindling (aka: The piss and moan thread v.2) | stevedood | Bay Area Impreza Club Forum -- BAIC | 59 | 04-01-2004 12:38 AM |
A lazy monday thread...A continuation of the saturday and sunday thread | DoctorNick | Mid West Subaru Owners Club Forum -- MWSOC | 9 | 09-10-2002 08:17 AM |
