03-01-2006, 12:33 AM | #1 |
Member#: 106163
Vehicle:2004 sti Blue |
Accessport weird problem..!!
I'm just installing my accessport on my 2004 sti... I did everything as said on the manul and when it gets to initialize the accessPort it progress 2 dots and then repeat the message turn off and fully on.. or something like that... i already check the process again repeated.. reset the factory ecu... i looked for the ecu part number and it is 241... i still cannot get the problem resolved... what should i do....??
03-01-2006, 12:41 AM | #2 |
Member#: 51918
Vehicle:2015 Audi S3 Daytona Gray |
Green test connectors??? AP new or used?.. make sure its for an 04STi (look on back of AP). . need more info.
03-01-2006, 01:05 AM | #3 |
Member#: 106163
Green connectors disconnected and connected back again... i even disconected and connected the passenger test connectors...
New AP .. and in the back is says that is for sti 04... also when i run the map manager it says that is for 2004 sti... |
03-01-2006, 01:24 AM | #4 | |
Member#: 75122
SCIC
Vehicle:2005 Impreza WRX Wag White |
Huh??? You should not be getting a menu if its a new accessport. it should go directly into the "choose a base map" phase. Passenger test connectors? Connect green connectors, Plug in, choose a map, turn car to on position, press start, wait... and wait... and wait... then done. |
03-01-2006, 09:17 AM | #5 |
Member#: 60324
Vehicle:1998 RS |
the only question i see is "what should i do", i don't understand what problem you are actually having.
03-01-2006, 10:05 AM | #6 |
Member#: 106163
ok.. here is the thing... after i do everything the test mode.. and all that stuff.. when i plug the conector in the obdII port... i get that message... select base map... i select the map... turn the key to off position then to on `position and then OK...!!! Then it says initializing it start showing dots to show progress... but it stops when there are two dots progress and then after 30 segs it goes back to the screen that says turn the off and fully on...
Any ideas what could happen?.. thank you |
03-01-2006, 10:31 AM | #7 |
Member#: 60324
Vehicle:1998 RS |
it will time out if you don't press OK to start flashing after turning the car off then on again, you're not waiting are you?
03-01-2006, 11:10 AM | #8 | |
Member#: 106163
I don't understand.. can you please explain me..? thank you |
03-01-2006, 11:57 AM | #9 | |
Member#: 60324
Vehicle:1998 RS |
after you turn your car back into the 'on' position you have a limited amount of time to start the flashing process before the AP will "time out". |
03-01-2006, 12:16 PM | #10 |
Member#: 67213
Vehicle:04 WRX STi Java Black Pearl |
My access port gave me the "unable to communicate with ECU" message at about the same time in the process that you are getting your error message. after several months of tribulation(including sending back to cobb twice) it turned out that they put the WRX programming module into an STi outer shell of the device. So even though i had an STi serial number, its innards were incorrect.
While my problem is not exactly the same as yours, I would suggest that if you have called their customer service and you have done the following steps: a) get a new cable from Cobb b) get a firmware update from Cobb Tuning Customer Service (801-713-8035) c) updated to latest map manager and set of maps and it still isn't working, send it back to them for a full diagnostic. Make sure that they know the steps you have taken(type up a short, clear, report) and ask them to check the device over physically to confirm it is operating normally and is not wacked out in anyway. -Chris *edit* I just realized its kind of weird to have cobb tuning on speed dial in your cel phone. |
03-01-2006, 01:01 PM | #11 | |
Member#: 106163
I've noticed something when i start the AP is says 2004 impreza wrx.. i does not says any sti or 2.5... however in the back of the AP says 2004 sti.. So I don't know if that can be an issue... |
03-02-2006, 09:20 AM | #12 | |
Member#: 82378
South East
Vehicle:<--- Hot Donuts Now |
thats what i was thinking. maybe hes pressing it right away? i think it says 3-10 seconds. |
03-01-2006, 11:27 AM | #13 |
Member Status: Member
Member#: 46241
SWIC
Vehicle:- Can I get a wayo |
Maybe you shuld call Cobb when you are with your car.
i'll bet they can figure it out. My bet is on a cable being replaced. Is your car getting into test mode? (cel flashing and radiator fans cycling) |
03-01-2006, 12:20 PM | #14 | |
Member#: 106163
Do you thing is the cable? The problem is that i am in south america.. i it is difficult to me to send it from here... i have a cable that is the din-9 to obdII but it uses all the pins? can i try with that one? thank you |
03-01-2006, 12:35 PM | #15 |
Member#: 51918
majunche66 :Try this. . in this order please. Start from scratch. Unhook everything. Shut off anything powered. . (radar det., dome light, fan etc ) Do NOt put ign key in yet. . leave out.
1. Plug in green test connectors under drivers side dash. 2. Plug AP cable to AP. . make sure to tighten the little screws. . .I wrap the excess cable around shifter. . so that it wont pull out of OBD2. . .THEN plug other end into the OBD2 plug. . making sure it feels secure. 3. AP should power up now. 4. Now put ign key in to ign. . and turn to "on" position. . .Do NOT START!!!!!! 5. Should be in test mode (dash lights blinking, fans on & off. . clicking in glove box area) 6. Select on AP. . ."change base map".. . then press OK (large round button). Now your asked to turn back key to OFF position and back to ON position (never start it) 7. This is when the AP will show intitializing ECU. . . . . . . . .blinking dots and fans will stop. . dash lights will stop blinking and should be silent as AP & ECU are starting to marrying. 8. AP will show progrees indicator in % ( 50% etc) blinking dots and some codes (cpu jibber jabber). .. 9. This should take app 10-15 min to flash base. 10. AP will tell you when its done... I think you have to press OK on AP first 11. Now youll have to turn key back to OFF pos and back to ON once more to complete it. 12. Now you can load a realtime map over the base if desired. 13. Before step 6. . .try and select on AP.. show current map? Im curious if the Base may have worked from you trying it. . if I did work. . it will tell you what map is selected. 14. In this order :Remove ign key. . .unplug OBD2 from under steering column, unplug cable from AP and finally go back under drivers dash and disconnect the green test connectors. 15. Put key into ign. .. turn to ON position. . . I always give it a second and turn on your STi. 16. Thats if everything worked. 17. Good Luck 18. Now that I seen your in South America. . .AP may not be compatible. Make sure to let Cobb know this (BTW. . did you post something like this on the Cobb WRX forum). . this sounds fimilar to me????? 19. hi "HC". . ."The STi" Last edited by ADR 04STi; 03-01-2006 at 12:42 PM. |
03-01-2006, 01:09 PM | #16 | |
Member#: 106163
And in respect of being in Venezuela the car was bought in the US and brought here... So i do not thing that's the issue... Even I checked the part number for the ECU and is compatible with the one than cobb gave me... Last edited by majunche66; 03-01-2006 at 01:22 PM. |
03-01-2006, 02:43 PM | #17 |
Member#: 51918
OK. . .running out of idea's. Sounds to me. . defective cable or wrong AP then? I really dont know. So its an North America Subie just shipped to you. That shouldnt matter. Id call Cobb or email SEAN@Cobb. . hes their AP software guy and helped me out bigtime and solved my AP-PC sync problem.
Hope this helps: [email protected] Well Good Luck. |
03-01-2006, 03:01 PM | #18 |
Member#: 106163
thank you man... Let me call cobb to see what they can do for me...!!!
03-01-2006, 05:57 PM | #19 |
Member#: 106163
i called the guys on cobbtuning and they came up that the problem was that they installed the wrong software on the AP.. They told me to send back the unit to them so they can reprogram it. What do you think?
03-01-2006, 06:24 PM | #20 | |
Member#: 67080
03-01-2006, 06:31 PM | #21 |
Member#: 45043
SCIC
Vehicle:2004 WRX |
Did you plug in the little white connector (that came with the AP) into the connector near the green ones?
03-01-2006, 06:37 PM | #22 |
Member#: 67080
^^^ STI's don't have those.
03-01-2006, 07:49 PM | #23 |
Member#: 1871
Vehicle:2000 Impreza 2.5RS Blue Ridge Pearl |
Do you have a USDM STi? If you don't, the AP will not work for you. The AccessPORT available from Cobb is currently for US models only.
03-01-2006, 08:03 PM | #24 | |
Member#: 106163
03-02-2006, 07:50 AM | #25 |
Member#: 67213
the bird road service guy is the shiznit.
Similar Threads | ||||
New Accessport Weird Problem | Cadaver | Engine Management & Tuning | 35 | 05-29-2005 11:58 AM |
hmmm weird problem with A/F install | Impreza25RS | Normally Aspirated Powertrain | 3 | 11-25-2001 09:21 PM |
('93-'01) Weird problem when I try to start my car | Dobes | Impreza Forum | 13 | 09-16-2001 09:49 PM |
Any weird problems with the Website? | Nick | General Forum Archive | 41 | 01-31-2001 10:53 AM |
Weird problem, radio wont come on | BoomerRS | Car Audio, Video & Security | 3 | 08-28-2000 11:30 AM |
