11-24-2010, 01:25 PM | #251 |
Member#: 59388
RMIC
Vehicle:2003 WRX - Hybrid I do my own stunts |
How much for the remote tune? Is it like XPT Tuning?
11-24-2010, 01:38 PM | #252 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
11-24-2010, 02:55 PM | #253 |
Member#: 59388
RMIC
Gotcha! Since I'm down in the Monterey area, he was pushing me to have you dyno tune this rebuild. Makes sense why now.
11-24-2010, 03:40 PM | #254 |
Member#: 26933
BAIC
11-24-2010, 04:05 PM | #255 |
Member#: 59388
RMIC
Make me a sick deal I can't refuse. I got severely burned($$$) the last time I had it dyno-tuned and have been skeptical about tunes ever since... The tune was worse than the OTS map I was running. Worse timing, boost and fuel economy all around. I was not able to get my $$$ back.
11-24-2010, 04:55 PM | #256 | |
Member#: 26933
BAIC
-- Ed |
11-24-2010, 11:50 PM | #257 |
Member#: 227951
Vehicle:2004 Impreza WRX WRB |
Well sounds awesome I will contact you guys once the engine is ready to be started.
11-29-2010, 02:02 PM | #258 |
Member#: 26933
BAIC
bump!
11-30-2010, 09:37 PM | #259 |
Member#: 26933
BAIC
bump!
12-01-2010, 06:31 PM | #260 |
Member#: 82989
SWIC
Vehicle:2002 WRX Hybrid EJ257 |
Got my heads back from EQ today... holy crap I can't even believe that these are my heads with 128k on them. They are pristine and the CNC looks spectacular!
12-01-2010, 07:41 PM | #261 |
Member#: 26933
BAIC
12-14-2010, 02:31 PM | #262 |
Member#: 26933
BAIC
bump!
12-15-2010, 10:36 AM | #263 |
Member#: 264838
Vehicle:04 Sti PSM |
Hey I have a 2004 sti and I'm starting to get some valve noise so I am starting to look at my options. I was thinking about 2.0L heads but my question is the ports are bigger on the 2.0L head vs. 2.5? Because if not what's the point of putting 2.5 combustion chamber in the 2.0 head?
12-15-2010, 02:28 PM | #264 |
Member#: 26933
BAIC
There's no good reason to go to 2.0l heads on an STI as you would miss out on the AVCS. This option is meant mainly for hybrid builds when people already have 2.0l heads to start with.
For your valve noise, you probably just need a valve lash adjustment or possibly a valve job. -- Ed |
12-15-2010, 07:13 PM | #265 |
Member#: 59388
RMIC
^^I've got way noisy valves - Machine shop ground a little too much off the tips, and thus I have 2 that are a wee bit on the loose side (ie .12 instead of .10)... sounds like my dads charger now(the valve noise, not the engine/exhaust). A little noise is no reason to tear the car apart unless the noise is a catastrophic meltdown.
Ed, I'm saving my pennies to come have it tuned on the dyno. Not sure when that'll be though. |
12-20-2010, 03:30 PM | #266 |
Member#: 26933
BAIC
bump!
12-20-2010, 03:52 PM | #267 |
Member#: 33458
Vehicle:Your BOV sounds lame 93 RX7+09 Forester |
Do you guys do any porting to go along with a CNC chamber? I'm looking to have a set of bone-stock heads w/78k miles FULLY refreshed/built.
12-20-2010, 04:01 PM | #268 |
Member#: 18602
Vehicle:2005 Moller Skycar glow in dark purple |
still a bit fuzzy about options for 2.0 to 2.5 hybrid.
are 'big port' jdm version 6 heads better than 2003 stock 2.0 heads? if you were to buy these 'big port' heads for use on a hybrid do they need to be opened up like the usdm 2.0 WRX heads? are you better off starting with the v6 heads and then opening them up (because they flow better than USDM WRX heads before porting? ) second question. i've heard different opinions on this. can you set the valve buckets (lash) once you've machined the heads as part of the job or do the heads need to be torqued on the block before the correct valve lash can be set with buckets? |
12-20-2010, 05:49 PM | #269 |
Member#: 59388
RMIC
Q1:?
Q2: You should always set the lash AFTER the heads are torqued to the block. You can get close to setting the lash before, but mine have always changed after I torqued the head onto the block. |
12-20-2010, 06:12 PM | #270 | |
Member#: 26933
BAIC
Thanks -- Ed |
12-20-2010, 06:15 PM | #271 | ||
Member#: 26933
BAIC
FYI, we also offer fully built shortblocks and can also build and ship full longblocks. In this case, we set the valve lash in house. Thanks -- Ed |
12-21-2010, 07:01 PM | #272 |
Member#: 26933
BAIC
bump!
12-22-2010, 06:33 AM | #273 |
Member#: 131379
Vehicle:2003 354 ftlb@3k rpm justablue hatch |
Core Charge An Option?
going for a 2.5 bottom with 2.0 head rebuild of 03 wrx with 150k miles...
do you offer fully reconditioned and cnc'd heads without mine? I'd pay a core charge up front and then you refund after receipt of my heads. Understand the refund is variable depending on condition of my heads. That would save me car downtime to have the heads ready for install. |
12-22-2010, 02:02 PM | #274 |
Member#: 26933
BAIC
We don't currently offer a core exchange like that. The variance in head conditions is so high that it would be tough to do this fairly.
Thanks -- Ed |
12-23-2010, 12:06 AM | #275 |
Member#: 181869
SCIC
Vehicle:2003 WRX Silver |
Check your PM, I'm going to commit to you guys for my build. Just need to work out the details with you. Thanks Ed..I'm excited to see how all this turns out!
Oil Leak on Driver's Side after EJ257 Hybrid Build | lancelucas | Service & Maintenance | 13 | 11-25-2014 04:42 PM |
ej257 hybrid build | imc343 | Newbies & FAQs | 3 | 05-06-2010 01:58 PM |
FS: 2002 WRX 2.5 EJ257 Hybrid Build | 02WRXmoddedrex | Private Vehicle 'For Sale' Classifieds | 3 | 04-14-2010 09:25 PM |
new Sti options for the New Impreza | Reiflex | General Forum Archive | 9 | 12-22-2000 12:27 AM |
