02-03-2005, 08:24 PM | #1 |
Member#: 15144
Vehicle:93 impreza orange |
04 sti trans to a jdm 2.0?
my 2.0 jdm legacy turbo motor just blew the tranny , i have an sti drivetrain minus a few parts, so i can't do the whole swap just yet. does anybody know if the transmision will bolt up to that motor and will the tranny work without the computers hooked up. i am pressed for time with this car, it is my daily driver,
any body with any answers please help
02-03-2005, 09:02 PM | #2 |
Member#: 35585
Vehicle:RIP I'll always be The Ver8 Magistrate |
JDM 5mt and 6mt tranny will fit EJ2.0, EJ2.2 and EJ2.5. Basicly any contemproary EJ2x motor as far as I know. Sometimes not all the housing bolts are used but not that big a deal. It is a DCCD tranny, I assume it is as you state a computer hooked up?
If so it will work with out the controller your center diff will run in open position giving 70-30 torque split or so. That is fine, just do not take it on a dyno with independent rollers like a Dyno Jet. Hope that helps. Good luck man! |
02-04-2005, 04:18 PM | #3 |
Member#: 54077
You may have to use a V7 or newer STi flywheel to run a 6 speed. Either that or you can modify the clutch forks by welding a little bit on the end of them to make them longer.
Bryan |
02-06-2005, 11:38 AM | #4 |
Member#: 27017
Vehicle:07 WRX |
y cant u take it on the dyno
02-07-2005, 08:28 PM | #5 |
Member#: 15144
thank you, im not planning ondynoing it, it is fast enough ,just not at the present moment
02-07-2005, 09:19 PM | #6 |
Member#: 69435
Vehicle:2005 Aspen STi,rip02 Bugeye mafia 02 :( |
it isnt nessesary to get a new flywheel, you can go from a 5mt to a 6mt........just not 6mt to 5mt.
-nate |
02-07-2005, 11:40 PM | #7 |
Member#: 35585
If it is DCCD you can dyno it if it is a dyno with rollers tied together. Like Dyno Dynamics for instance. If not and you have no DCCD controller, the center diff is open and will want to send torque to the rear. Then the 2 axles will rotate at different speeds causing the center diff to go mad trying to correct what it is casuing. Very expensive mistake.
If it is non DCCD there is no issue. |
Do JDM 2.0 heads bolt right up to US Sti 2.5 block? | IA Performance | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 01-06-2012 12:01 AM |
*WTB: STI short block, JDM 2.0 or USDM 2.5 | Lam | Private 'Wanted' Classifieds | 5 | 02-14-2008 06:42 PM |
*WTB: STI short block, JDM 2.0 or USDM 2.5 | Lam | VIC Private Classifieds | 0 | 02-11-2008 11:38 PM |
USDM 2.0 vs. JDM 2.0 | flon3y | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 07-12-2006 08:03 PM |
Fully Built JDM 2.0 STI High Revving Engine - Built to Order | Gruppe-S | Services | 15 | 06-01-2006 03:51 PM |
