06-22-2007, 01:43 AM | #1 |
Member#: 121305
Vehicle:2004 WRX WRB Sedan 02 WRX PSM Stage 3+ SOLD! |
JDM v7 STi TMIC Install on 02-03
I know this is in Unibomber's TMIC FAQ, but it doesn't answer to this particular question nor has 3 days of searching and asking various people via PMs. I bought a JDM STi TMIC v7. It has nothing but the TMIC, meaning no y-pipe or any pipes for that matter throttle body, etc. I'm having a real tough time getting a straight/common answer. What is needed for an install on the 02-03 models? I've heard the following answers:
#1 everything OEM is fine and bolts right up, y-pipe, hoses, etc #2 everything but throttle body hose, bolts right up, y-pipe, etc; so you must buy the OEM STi USDM Throttle Body Hose #3 you must get the whole Perrin or Gruppe-S kit and TB hose Can we agree on any of these for the 02-03 MODELS<---- Remember this pertains to 02-03s only, because I've found PLENTY threads on the later years but from what I understand the v7 fits this car better/differently than any newer years. Thanks HUGE in advance for answering 3 days of looking myself. #1!!! FTW is the correct answer. I did it and will post pics below as proof. My issues were the following: #1 Getting the y-pipe and the TB hose BOTH in position to forcefully push on. #2 Keeping them BOTH on while forcefully pushing hoses onto the turbo and TB. #3 Although I'm told hardly noticeable, after finished the TMIC sits crooked (left is slightly higher than right)because... #4 The right side attaches to the bracket and I haven't found a way to attach the left or it would probably fit even. But I don't see how it's possible the way the pipe/hose leaves its position when in the proper fitment.
06-22-2007, 06:16 PM | #2 |
Member#: 121305
Finished project
Couple pics of throttle body OEM hose fitting (y-pipe also in background in 1st pic) OEM Y-Pipe Fitting A/C Line NOT touching, WITHOUT bending anything Last edited by ThePunisherGT; 07-30-2007 at 01:24 AM. Reason: Pics!! |
06-22-2007, 08:16 PM | #3 |
Member#: 25027
Bolts right up. Dunno it the stock y-pipe will work though
06-22-2007, 09:15 PM | #4 |
Big Ron
Super Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
Good question. I'm 98***37; sure the OEM throttle body hose will fit as I'm using my OEM one with my Ver. 7 right now. As to the Y pipe...I'm like 81% sure the OEM one or any aftermarket one will fit. If nothing else, try it out....swapping out intercoolers is not hard, so do a test fit and that will give you your answers.
06-22-2007, 09:26 PM | #5 |
Member#: 18914
South East
Vehicle:2006 WRX Black with some stuff |
Let us know what you find out so that future search results will turn up the correct answer for other who want to know the same thing.
Carlos |
06-22-2007, 09:46 PM | #6 |
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
when I installed it into my friend's car we reuesed pretty much everything. USDM STi TMIC is not a simple bolt on though...
06-22-2007, 10:23 PM | #7 | |
Member#: 121305
Vahnatai: I did know the bolts match up perfectly that info is unanimous and easily found, but thank you. txl146: Thanks for the tip, because that is my plan for now. Also a well known fact about the USDM, but again thank you for your time, reading my post, and posting. |
06-23-2007, 01:26 AM | #8 |
Member#: 58670
Vehicle:2005 got muuuuu? |
^ get back to work....
07-30-2007, 01:27 AM | #9 |
Member#: 121305
Updated!!
07-30-2007, 03:07 AM | #10 |
Member#: 148732
SCIC
Vehicle:2018 STI Black |
hahah 81***37;...nice
12-12-2007, 10:47 PM | #11 |
Member#: 121305
People are looking for this info it seems, from what I'm hearing. Any chance of it getting moved to the proper section and/or maybe a link in Unibomber's awesome Manifesto about TMIC's? Maybe like the "How do I install a TMIC?" section?
12-13-2007, 01:00 AM | #12 |
Vehicle:OK buy Nates beans westcoastroasting.com |
please measure and post the IC core size----the top opening, inside measurements
12-13-2007, 08:07 AM | #13 |
Member#: 121305
02-09-2016, 02:04 PM | #14 |
Member#: 357158
Vehicle:2009 Subaru STi White |
I'm having the same problem right now trying to get everything to fit. Do I just reuse all the stock wrx IC hoses with the V7 TMIC? Do I use the wrx ypipe or V7 TMIC ypipe?
Similar Threads | ||||
FS in CT: JDM V7 STI splitter and USDM 02/03 WRX hoodscoop and splitter (MBP) | gling | Exterior/Styling | 14 | 07-18-2007 11:26 AM |
FS Socal: JDM V7 STI Fog Covers PSM 02-03 Bug Eye | ComTekAuto | Exterior/Styling | 2 | 03-14-2007 03:16 PM |
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) | normaspirated | Private 'Wanted' Classifieds | 0 | 02-09-2006 03:00 PM |
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) | normaspirated | MWSOC Private Classifieds | 0 | 01-31-2006 02:26 PM |
JDM V7 STi TMIC vs USDM STi TMIC | crystalhelix | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 18 | 01-13-2006 03:16 PM |
