Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 04-19-2013, 05:44 PM   #26
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD) / 87 GL
what you are refering to is a nitrous/meth system which really does exist but it does not operate in any way, shape, or form that you are describing.
http://www.theturboforums.com/thread...nti-Lag-System
If that is not what you're talking about then cool. Please show us what you're talking about. Seems kind of weird that you've been running ALS on your nova for 3 years but you are just now asking whether or not a 2 step is harmful. If you know the answer already then why did you ask? Obviously you are way more educated on the subject than anyone else here, so please, enlighten us.
Zefy is online now   Reply With Quote
Old 04-19-2013, 10:13 PM   #27
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
I don't know about antilag as I have never used it.
Umadbroej26 is offline   Reply With Quote
Old 04-19-2013, 10:24 PM   #28
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
Originally Posted by Umadbroej26 View Post
Pm me ill hook u up with the best anti lag u can get bar none
Go out and enjoy sleeper type launches without all the noise of antilag
When u spray the kit it will produce full boost
Like I said before I've been running this system on my nova for 3 years with no problem
So you haven't been running this system for 3 years in your nova? You've been calling it antilag but now you're saying you haven't ever run it?
Post some pictures or something. You don't really seem to be making sense and I really would like to know what you've done. Before today I hadn't seen the meth/nitrous system that I posted above and I find it neat. That guy however has well documented his work and is showing it. I would have never looked into it if you hadn't sparked this discussion.
But that guy explaining and posting actual videos and pictures shows what he is doing. Unlike yourself. Step up with proper info and pictures like you said you would.
Old 04-19-2013, 10:39 PM   #29
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
I will "step up" with the pics when family goes back home, the guys at turn in concepts know what I'm capable of sorry your so doubtful.
Old 04-19-2013, 10:45 PM   #30
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
your right it does not work that way, in no way shape or form. No it's not a nitrous meth system, it's obvious you didn't read the post about my setup
Old 04-19-2013, 10:48 PM   #31
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
My system doesn't have to be "ignited" you can spray co2 as well.
Old 04-19-2013, 10:49 PM   #32
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Just post pics/video. Something about a single nozzle spraying against that wheel doesn't sound like it has the volume of gas to spin the turbine fast enough for "full boost."
If it works, great. I'd just like to see it.
Old 04-19-2013, 10:50 PM   #33
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
I will post a video next week of a turbo on a bench so you can see the system layout and how it works, I would like anyone to be able to use this setup
Old 04-19-2013, 10:53 PM   #34
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
Depending on the size of turbo it's used on, you pick the size hp shot accordingly. With the correct size it will spool a t88 on a 2jz to 32psi almost instantly
Old 04-19-2013, 11:51 PM   #35
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
anyone can spin a turbo on a bench. it's extremely easy and proves nothing. It's also bad for a turbo... your description of the system seems fairly straight forward so further explanation is probably not needed.
please post a video/pictures of your nova. I'm not trying to be confrontational and I apologize if it seems that way. Just sounds way to good to be true.
Old 04-21-2013, 06:27 PM   #36
Andrewxxcarlson
Member#: 316415
2006 WRX
Nothin more on this topic?
Andrewxxcarlson is offline   Reply With Quote
Old 04-21-2013, 08:05 PM   #37
StackSmasher
Member#: 316928
2012 STI limited
subscribed for proof and results..
Or flaming for neither.
Not doubting just would like to see proof of concept.
StackSmasher is offline   Reply With Quote
Old 04-21-2013, 09:21 PM   #38
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
Originally Posted by StackSmasher View Post
Subsribed for proof and results..
The supra posted earlier in the thread has this system installed but will make a new video with some views of the setup installed
Old 04-21-2013, 09:25 PM   #39
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
I do realize it seems too good to be true guys I promise it's deffinantly worth installing.
Old 04-21-2013, 09:37 PM   #40
quazimoto
Member#: 70395
If you are such an expert on antilag then why did you have to ask this?
http://forums.nasioc.com/forums/show....php?t=2492081
Old 04-21-2013, 09:57 PM   #41
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
Lol thanks for amusing me, when I post that I was thinking of the traditional ignition delay style antilag, and know nothing about that type of antilag. However I , as well as most any one know what is ment buy the term "anti-lag".
Knowing what is ment by this I built this system. I would love to know why Subaru forum "experts" and "gurus" and I use that term loosely, come out of the wood work to question things I post only because I have the nubie tag by my name.
Old 04-22-2013, 02:53 PM   #42
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
everybody knows that the titles of 'guru' and 'specialist' are given due to post counts. Not actual technical expertise. The only reason I'm a 'specialist' is because I've been here for years... I make on average 1 post per day... You actually post 6x more than me per day.
And everybody here was a 'nubie' at one point. This isn't hazing... it's validating your work.
But once again, the reason people are questioning you is because you're making claims that you're not backing up... A video of a random supra shows nothing of the system you're claiming. Is there a build thread of the supra? I'm assuming you know the car being that there is no info in the video description...
You also said you were going to 'step up' with photos when your family got home...? Still out i presume...?
People would be more receptive to your many threads (most asking/telling the same things) if you posted some DETAILED info and photos/videos. I would personally like to see a photo of your nova with the nozzle setup and a video/datalog of the spray system being on and off with some form of pressure measurement (for comparison) to show that your system works and builds boost like the 32psi instant spool you're claiming that supra makes with this system.
Old 04-28-2013, 04:12 PM   #43
StackSmasher
Member#: 316928
2012 STI limited
Still waiting for proof of concept here..
Old 04-28-2013, 05:25 PM   #44
Andrewxxcarlson
Member#: 316415
2006 WRX
Yup me too.
Old 04-28-2013, 09:04 PM   #45
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
Geek Guy is offline   Reply With Quote
