10-04-2002, 03:42 AM | #26 |
Member#: 23517
Vehicle:2002 WRX Silver |
This is the Stock "VF30 TMI INJEN VF30 AGRESSIVE STRT 18PSI" map in a readable format. Note, I haven't played nor tweaked this one yet, just posting it because...
Code:
VF30 TMI INJEN FUEL (%) TURBOXS UTEC (Version 2.2) (c) 2002 RPM 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 500 -6.6 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 750 -6.6 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 1000 -6.6 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 1250 -6.6 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 1500 -7 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 1750 -7 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 2000 -7 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 2250 -7 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 2500 -7 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 2750 -7 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 3000 -7 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 3250 -7 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 -5.1 3500 -7 -5 -5 -5 -5 -5 -5 -5 -5 -5 -5 3750 -7 -5.2 -5.2 -5.2 -5.2 -5.2 -5.2 -5.2 -5.2 -5.2 -5.2 4000 -7 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 4250 -7 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 4500 -7 -5.7 -5.7 -5.7 -5.7 -5.7 -5.7 -5.7 -5.7 -5.7 -5.7 4750 -7 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 -5.5 5000 -6 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 5250 -5 -5 -5 -5 -5 -5 -5 -5 -5 -5 -5 5500 -4 -5 -5 -5 -5 -5 -5 -5 -5 -5 -5 5750 -3 -4.6 -4.6 -4.6 -4.6 -4.6 -4.6 -4.6 -4.6 -4.6 -4.6 6000 -3 -4.5 -4.5 -4.5 -4.5 -4.5 -4.5 -4.5 -4.5 -4.5 -4.5 6250 -3 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 -4.2 6500 -3 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 6750 -3 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 7000 -3 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 -3.6 VF30 TMI INJEN TIMING (Deg.) TURBOXS UTEC (Version 2.2) (c) 2002 RPM 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 500 ECU ECU ECU ECU ECU ECU ECU 35 35 35 35 750 ECU ECU ECU ECU ECU ECU ECU 35 35 35 35 1000 ECU ECU ECU ECU ECU ECU ECU 33 33 33 33 1250 ECU ECU ECU ECU ECU ECU ECU 32 32 32 32 1500 ECU ECU ECU ECU ECU ECU ECU 31 31 31 31 1750 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 2000 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 2250 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 2500 ECU ECU ECU ECU ECU ECU ECU 27 27 27 27 2750 ECU ECU ECU ECU ECU ECU ECU 24 24 24 24 3000 ECU ECU ECU ECU ECU ECU ECU 20 20 20 20 3250 ECU ECU ECU ECU ECU ECU ECU 18 18 18 18 3500 ECU ECU ECU ECU ECU ECU ECU 15 15 15 15 3750 ECU ECU ECU ECU ECU ECU ECU 15 15 15 15 4000 ECU ECU ECU ECU ECU ECU ECU 18 18 18 18 4250 ECU ECU ECU ECU ECU ECU ECU 18 18 18 18 4500 ECU ECU ECU ECU ECU ECU ECU 20 20 20 20 4750 ECU ECU ECU ECU ECU ECU ECU 22 22 22 22 5000 ECU ECU ECU ECU ECU ECU ECU 23 23 23 23 5250 ECU ECU ECU ECU ECU ECU ECU 23 23 23 23 5500 ECU ECU ECU ECU ECU ECU ECU 24 24 24 24 5750 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 6000 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 6250 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 6500 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 6750 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 7000 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 VF30 TMI INJEN BOOST TURBOXS UTEC (Version 2.2) (c) 2002 RPM 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 500 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 750 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 1000 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 1250 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 1500 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 1750 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 2000 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 2250 ECU ECU ECU ECU ECU ECU ECU 95 95 95 95 2500 ECU ECU ECU ECU ECU ECU ECU 95 95 95 95 2750 ECU ECU ECU ECU ECU ECU ECU 95 95 95 95 3000 ECU ECU ECU ECU ECU ECU ECU 50 50 50 50 3250 ECU ECU ECU ECU ECU ECU ECU 46.8 46.8 46.8 46.8 3500 ECU ECU ECU ECU ECU ECU ECU 46.8 46.8 46.8 46.8 3750 ECU ECU ECU ECU ECU ECU ECU 43.5 43.5 43.5 43.5 4000 ECU ECU ECU ECU ECU ECU ECU 43.5 43.5 43.5 43.5 4250 ECU ECU ECU ECU ECU ECU ECU 44.5 44.5 44.5 44.5 4500 ECU ECU ECU ECU ECU ECU ECU 45.9 45.9 45.9 45.9 4750 ECU ECU ECU ECU ECU ECU ECU 48.6 48.6 48.6 48.6 5000 ECU ECU ECU ECU ECU ECU ECU 48 48 48 48 5250 ECU ECU ECU ECU ECU ECU ECU 46 46 46 46 5500 ECU ECU ECU ECU ECU ECU ECU 43.5 43.5 43.5 43.5 5750 ECU ECU ECU ECU ECU ECU ECU 42.5 42.5 42.5 42.5 6000 ECU ECU ECU ECU ECU ECU ECU 42.5 42.5 42.5 42.5 6250 ECU ECU ECU ECU ECU ECU ECU 42.5 42.5 42.5 42.5 6500 ECU ECU ECU ECU ECU ECU ECU 42.5 42.5 42.5 42.5 6750 ECU ECU ECU ECU ECU ECU ECU 42.5 42.5 42.5 42.5 7000 ECU ECU ECU ECU ECU ECU ECU 42.5 42.5 42.5 42.5
10-04-2002, 03:47 AM | #27 |
Member#: 23517
This is what the Stock "VF30STG4TMI" map looked like after 19 DynaPak runs and a lot of tweaking. I'll also post the "MAP" version you can cut and paste into a text file to upload next, please do be careful as I take NO responsability for damage caused!!! This isn't my final tune by far, just better than how it came for me on Chevron 93 Pump gas in Atlanta...
Fueling was COMPLETELY changed as it came pig rich, timing was flatend(sp?) a little in a couple of spots as well. Boost was left alone. I'm hitting 20PSI with this map... Code:
Tuned Stage 4 FUEL (%) TURBOXS UTEC (Version 2.2) (c) 2002 RPM 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 500 -9.5 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 750 -9.5 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 1000 -9.5 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 -6.8 1250 -9.5 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 1500 -5.5 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 1750 -5.5 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 -3.7 2000 -5.5 -3.3 -3.3 -3.3 -3.3 -3.3 -3.3 -3.3 -3.3 -3.3 -3.3 2250 -5.5 -1.4 -1.4 -1.4 -1.4 -1.4 -1.4 -1.4 -1.4 -1.4 -1.4 2500 -5.5 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 2750 -5.5 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 -1.3 3000 -5.5 -1.2 -1.2 -1.2 -1.2 -1.2 -1.2 -1.2 -1.2 -1.2 -1.2 3250 -5.5 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 3500 -5.5 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 -2.8 3750 -5.5 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 -5.3 4000 -5.5 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 4250 -5.5 -8.3 -8.3 -8.3 -8.3 -8.3 -8.3 -8.3 -8.3 -8.3 -8.3 4500 -5.5 -8 -8 -8 -8 -8 -8 -8 -8 -8 -8 4750 -5.5 -8 -8 -8 -8 -8 -8 -8 -8 -8 -8 5000 -5.5 -8 -8 -8 -8 -8 -8 -8 -8 -8 -8 5250 -5.5 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 5500 -5.5 -8 -8 -8 -8 -8 -8 -8 -8 -8 -8 5750 -5.5 -8 -8 -8 -8 -8 -8 -8 -8 -8 -8 6000 -5.5 -9.4 -9.4 -9.4 -9.4 -9.4 -9.4 -9.4 -9.4 -9.4 -9.4 6250 -5.5 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 -8.6 6500 -5.5 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 6750 -5.5 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 7000 -5.5 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 -9.7 VF30STG4TMI FUEL (%) TURBOXS UTEC (Version 2.2) (c) 2002 Tuned Stage 4 TIMING (Deg.) TURBOXS UTEC (Version 2.2) (c) 2002 RPM 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 500 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 750 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 1000 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 1250 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 1500 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 1750 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 2000 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 2250 ECU ECU ECU ECU ECU ECU ECU 30 30 30 30 2500 ECU ECU ECU ECU ECU ECU ECU 27 27 27 27 2750 ECU ECU ECU ECU ECU ECU ECU 24 24 24 24 3000 ECU ECU ECU ECU ECU ECU ECU 22 22 22 22 3250 ECU ECU ECU ECU ECU ECU ECU 20 20 20 20 3500 ECU ECU ECU ECU ECU ECU ECU 20 20 20 20 3750 ECU ECU ECU ECU ECU ECU ECU 20 20 20 20 4000 ECU ECU ECU ECU ECU ECU ECU 20 20 20 20 4250 ECU ECU ECU ECU ECU ECU ECU 20 20 20 20 4500 ECU ECU ECU ECU ECU ECU ECU 21 21 21 21 4750 ECU ECU ECU ECU ECU ECU ECU 23 23 23 23 5000 ECU ECU ECU ECU ECU ECU ECU 23 23 23 23 5250 ECU ECU ECU ECU ECU ECU ECU 23 23 23 23 5500 ECU ECU ECU ECU ECU ECU ECU 23 23 23 23 5750 ECU ECU ECU ECU ECU ECU ECU 24 24 24 24 6000 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 6250 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 6500 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 6750 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 7000 ECU ECU ECU ECU ECU ECU ECU 25 25 25 25 Tuned Stage 4 BOOST TURBOXS UTEC (Version 2.2) (c) 2002 RPM 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 500 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 750 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 1000 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 1250 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 1500 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 1750 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 2000 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 2250 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 2500 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 2750 ECU ECU ECU ECU ECU ECU ECU 100 100 100 100 3000 ECU ECU ECU ECU ECU ECU ECU 55 55 55 55 3250 ECU ECU ECU ECU ECU ECU ECU 51.48 51.48 51.48 51.48 3500 ECU ECU ECU ECU ECU ECU ECU 47.85 47.85 47.85 47.85 3750 ECU ECU ECU ECU ECU ECU ECU 47.85 47.85 47.85 47.85 4000 ECU ECU ECU ECU ECU ECU ECU 48.95 48.95 48.95 48.95 4250 ECU ECU ECU ECU ECU ECU ECU 50.49 50.49 50.49 50.49 4500 ECU ECU ECU ECU ECU ECU ECU 53.46 53.46 53.46 53.46 4750 ECU ECU ECU ECU ECU ECU ECU 52.8 52.8 52.8 52.8 5000 ECU ECU ECU ECU ECU ECU ECU 50.6 50.6 50.6 50.6 5250 ECU ECU ECU ECU ECU ECU ECU 47.85 47.85 47.85 47.85 5500 ECU ECU ECU ECU ECU ECU ECU 46.75 46.75 46.75 46.75 5750 ECU ECU ECU ECU ECU ECU ECU 46.75 46.75 46.75 46.75 6000 ECU ECU ECU ECU ECU ECU ECU 46.75 46.75 46.75 46.75 6250 ECU ECU ECU ECU ECU ECU ECU 46.75 46.75 46.75 46.75 6500 ECU ECU ECU ECU ECU ECU ECU 46.75 46.75 46.75 46.75 6750 ECU ECU ECU ECU ECU ECU ECU 46.75 46.75 46.75 46.75 7000 ECU ECU ECU ECU ECU ECU ECU 46.75 46.75 46.75 46.75 7250 ECU ECU ECU ECU ECU ECU ECU 46.75 46.75 46.75 46.75 |
10-04-2002, 03:48 AM | #28 |
Member#: 14535
Vehicle:02 Impreza WRX Silver |
you are on 93 octane right?
10-04-2002, 03:51 AM | #29 |
Member#: 23517
Here is my "Modified VF30STG4TMI After Dyno Runs" MAP file. I chose to name the extension "MAP" instead of TXT as I can keep it apart easier. Simply cut and paste everything between the "code" words and paste it into a file and save it, then upload per the UTEC instructions should you decide to do so. Be VERY aware gas, weather, the moon, and tides effect all parts of the country differently and what make work for me may blow you up!
Code:
[22;23r[23;01f[START][MAPGROUP1][MAPGROUP] Map Name:-[VF30STG4TMI] Map Comments:-[Dyno Run Changes] Fuel Map [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [-9.5] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-9.5] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-9.5] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-6.8] [-9.5] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-5.5] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-5.5] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-3.7] [-5.5] [-3.3] [-3.3] [-3.3] [-3.3] [-3.3] [-3.3] [-3.3] [-3.3] [-3.3] [-3.3] [-5.5] [-1.4] [-1.4] [-1.4] [-1.4] [-1.4] [-1.4] [-1.4] [-1.4] [-1.4] [-1.4] [-5.5] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-5.5] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-1.3] [-5.5] [-1.2] [-1.2] [-1.2] [-1.2] [-1.2] [-1.2] [-1.2] [-1.2] [-1.2] [-1.2] [-5.5] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-5.5] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-2.8] [-5.5] [-5.3] [-5.3] [-5.3] [-5.3] [-5.3] [-5.3] [-5.3] [-5.3] [-5.3] [-5.3] [-5.5] [-7] [-7] [-7] [-7] [-7] [-7] [-7] [-7] [-7] [-7] [-5.5] [-8.3] [-8.3] [-8.3] [-8.3] [-8.3] [-8.3] [-8.3] [-8.3] [-8.3] [-8.3] [-5.5] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-5.5] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-5.5] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-5.5] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-5.5] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-5.5] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-8] [-5.5] [-9.4] [-9.4] [-9.4] [-9.4] [-9.4] [-9.4] [-9.4] [-9.4] [-9.4] [-9.4] [-5.5] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-8.6] [-5.5] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-5.5] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-5.5] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-9.7] [-5.5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5.5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5.5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5.5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5.5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5.5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5.5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5.5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [-5] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] Timing Map [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [30] [30] [30] [30] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [27] [27] [27] [27] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [24] [24] [24] [24] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [22] [22] [22] [22] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [20] [20] [20] [20] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [20] [20] [20] [20] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [20] [20] [20] [20] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [20] [20] [20] [20] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [20] [20] [20] [20] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [21] [21] [21] [21] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [23] [23] [23] [23] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [23] [23] [23] [23] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [23] [23] [23] [23] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [23] [23] [23] [23] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [24] [24] [24] [24] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [25] [25] [25] [25] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [28] [28] [28] [28] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [28] [28] [28] [28] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [28] [28] [28] [28] Boost Map [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [100] [100] [100] [100] [0] [0] [0] [0] [0] [0] [0] [55] [55] [55] [55] [0] [0] [0] [0] [0] [0] [0] [51.4] [51.4] [51.4] [51.4] [0] [0] [0] [0] [0] [0] [0] [47.8] [47.8] [47.8] [47.8] [0] [0] [0] [0] [0] [0] [0] [47.8] [47.8] [47.8] [47.8] [0] [0] [0] [0] [0] [0] [0] [48.9] [48.9] [48.9] [48.9] [0] [0] [0] [0] [0] [0] [0] [50.4] [50.4] [50.4] [50.4] [0] [0] [0] [0] [0] [0] [0] [53.4] [53.4] [53.4] [53.4] [0] [0] [0] [0] [0] [0] [0] [52.8] [52.8] [52.8] [52.8] [0] [0] [0] [0] [0] [0] [0] [50.6] [50.6] [50.6] [50.6] [0] [0] [0] [0] [0] [0] [0] [47.8] [47.8] [47.8] [47.8] [0] [0] [0] [0] [0] [0] [0] [46.7] [46.7] [46.7] [46.7] [0] [0] [0] [0] [0] [0] [0] [46.7] [46.7] [46.7] [46.7] [0] [0] [0] [0] [0] [0] [0] [46.7] [46.7] [46.7] [46.7] [0] [0] [0] [0] [0] [0] [0] [46.7] [46.7] [46.7] [46.7] [0] [0] [0] [0] [0] [0] [0] [46.7] [46.7] [46.7] [46.7] [0] [0] [0] [0] [0] [0] [0] [46.7] [46.7] [46.7] [46.7] [0] [0] [0] [0] [0] [0] [0] [46.7] [46.7] [46.7] [46.7] [0] [0] [0] [0] [0] [0] [0] [46.7] [46.7] [46.7] [46.7] [0] [0] [0] [0] [0] [0] [0] [42.5] [42.5] [42.5] [42.5] [0] [0] [0] [0] [0] [0] [0] [42.5] [42.5] [42.5] [42.5] [0] [0] [0] [0] [0] [0] [0] [42.5] [42.5] [42.5] [42.5] [0] [0] [0] [0] [0] [0] [0] [42.5] [42.5] [42.5] [42.5] [0] [0] [0] [0] [0] [0] [0] [42.5] [42.5] [42.5] [42.5] [0] [0] [0] [0] [0] [0] [0] [42.5] [42.5] [42.5] [42.5] [0] [0] [0] [0] [0] [0] [0] [42.5] [42.5] [42.5] [42.5] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [END][MAPGROUP][0C8CC][EOF][1;24r[22;01fFINISHED [23;01f [25;80f |
10-04-2002, 03:52 AM | #30 |
Member#: 23517
Yup, 93 Chevron Pump. I will use Toulene on a drag strip or C16 just to be on the safe side...
Shawn |
10-04-2002, 03:55 AM | #31 |
Member#: 14535
LOL - i am on 91 octane... and will run really lean with the FMIC. but i'll keep it for reference.
I am glad things are working out for you with the UTEC. |
10-04-2002, 04:06 AM | #32 |
Member#: 23517
Now, the Dyno scans will be posted by tonight (Friday night).
In short, walking in and doing the first run I was at 220hp to the wheels as the UTEC came. After all was said and done I am at 260hp to the wheels:-). Now, I think there more room to grow but I was happy today getting this out of it. I say that because 19 runs is a lot, and I would say 15 of them was figuring out how the constants worked and block multiplying or filling. My A/F was ALL over the place on the first run. Now it is flatlined and perfect the whole way accross the board. The boost has room to grow and I believe the timing does as well. My initial goal is 300hp to the wheels as she stands, maybe with a couple of home brew mods like light TB porting, ditching the intake coolant recirc, and other such stuff. I have questions to add to this but I'm too tired tonight to keep going. One thing that I didn't figure out at first (I'm new at this) is that under the fueling map setup that the %'s are NOT throttle position, they are load. Thats what the first 9-10 runs didn't even open up until after like 4500RPM's. DUH, so I went back and remapped from 10% to 100% to cover the whole range with the same constants. Once I got used to it I really liked the UTEC interface. It took some time, and I'm glad I was able to do it on a DynaPak with a Wideband sensor and all the goodies. The next set of runs I believe will be a breeze as the learning curve is done for what I considered the hard part. Oh, one more thing. I had to adjust my TPS reading in the UTEC under "Parameters". Mine would read 95 at WOT, which makes a difference. I set the voltages and you'll notice in the first set of UTEC logs the TPS never goes over like 95, after that change it went right to 100, sometimes 101. Any comments or suggestions are welcome as always. I could use the help, and I'm trying my best to spread the knowledge. More to come tomarrow, including the Dyno Plots. Shawn |
10-04-2002, 04:28 AM | #33 |
Member#: 13831
so much good stuff shawn, thanks for taking the time man. 40whp increase from tuning is good, just think what all the poor off the shelf unichip folks could be getting from alittle tweaking.
Im so close to getting a UTEC |
10-04-2002, 07:37 AM | #34 |
Member#: 14576
Vehicle:2002 WRX Sedan Silver |
DiMensionX
Big Props to you for doing everyone elses R&D.... great job.. MORE POWER SCOTTY, I NEED MORE POWER |
10-04-2002, 02:51 PM | #35 |
Member#: 23517
Bumping for a couple of questions.
At what point should I start messing with the knock threshold setting. At some point you can only tune around problem points in the range, after that you still get slight, VERY slight CEL flashes that are too quick for any logging to pick up. I'm at the point now where I would like the CEL to flash only during a major knock event that needs to be tuned around. Next question. I need an example as to how to set the ambient air or intake air threshold to add or subtract X amount of gas or timing based on air temp. At night it's cool here, during the day it's hot. I know where to set this information, just not how the constants work. An example would be much appreciated! Thanks, Shawn |
10-04-2002, 03:18 PM | #36 |
Member#: 6124
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
I'm at 96C for coolant and 54C for air
with .4 for fuel enrichment and 2 for timing retard. So far it's worked good. Jorge (RiftsWRX) www.ProjectWRX.com |
10-04-2002, 03:20 PM | #37 |
Member#: 23517
Your the man:-)
Shawn |
10-04-2002, 04:28 PM | #38 |
Member#: 17763
W. Canada
[in a Homer Simpson voice]
mmmmm..... data.
Thanks Shawn! jc |
10-04-2002, 04:47 PM | #39 |
Member#: 23517
Don't thank me, I'm just sharing what I'm learning. Heck, Jorge has been contributing for ALOT longer than me and has helped out tremendously with both his web site and posts.
Shawn |
10-04-2002, 04:47 PM | #40 |
Member#: 19502
South East
Vehicle:2010 Impreza with no scoop. =( |
Nice numbers... glad to see the huge stack of data flowing in. Just so you know Shawn, I fixed the forum on the ECU Tuning site.. so you can use the CODE tags now to organize it there.
10-04-2002, 04:53 PM | #41 |
Member#: 23517
Sounds good Crazyhorse, I'll dual post for now here and there and maybe just switch over to there to reduce load on this site.
Any chance I can attach JPG's:-). Shawn |
10-04-2002, 05:08 PM | #42 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
Nice to see the map posted, it will probably be the same setup I'll have minus the catless exhaust (1 cat) and a few other things on my car (headers). The one thing I had a question about was the spool time of the turbo. How fast do you generally hit 14psi with it driving on the street?
Phil |
10-04-2002, 05:18 PM | #43 |
Member#: 19502
South East
Yea you should be able to.. works the same as vbulletin.. just email me if you have any troubles.
10-04-2002, 05:21 PM | #44 |
Member#: 23517
10.3.02 Dyno Group Runs 1
10-04-2002, 05:23 PM | #45 |
Member#: 23517
10.3.02 Dyno Group Runs 2
10-04-2002, 05:24 PM | #46 |
Member#: 23517
10.3.02 Dyno Group Runs 3
10-04-2002, 05:25 PM | #47 |
Member#: 23517
10.3.02 Dyno Before & After
10-05-2002, 09:47 AM | #48 |
Member#: 4980
I've already shared this with Shawn in an email, but it's pretty cool to see the knock correction of the UTEC in action on the last dyno plot.
There are two areas where the UTEC retarded timing in that dyno plot that changed the curves quite a bit. The first is just after boost comes on and torque starts to dip. The second is in the high RPM where the HP curve looks like someone just took a bite out of it. I am glad the UTEC caught both instances of det, and by looking at the size of the bite in the curves they would have been rather major. These two spots also give a little insight into how you have to tune an EJ20. On pump gas and 93 octane we tune our stage 4 kits to around 10.7:1 AF ratio in the upper RPM sections of the map. You can go leaner before boost builds, but as the boost comes on it must be richened up to avoid detonation in the “would be peak torque" zone. If i have time I’ll post an Air: fuel chart today that will give a better idea of how we like to run a street tune. -Nathan www.turboxs.com |
10-05-2002, 10:11 AM | #49 |
Member#: 19502
South East
Nathan,
I'd love to see the a/f chart.. Thanks! |
10-05-2002, 10:34 AM | #50 |
Member#: 22710
Vehicle:02 wrx sadona red pearl |
altitude!!
What are some general adjustments that need to be made to a high altitude(5000 feet ) tune on the UTEC??
FS: PA utec with 4 tuned maps and map selector switch | whitesti04 | Engine/Power/Exhaust | 5 | 04-27-2007 08:53 AM |
FS: UTEC with Map Selector, Exhaust and Others | WRX11 | MAIC Private Classifieds | 67 | 03-06-2007 01:19 PM |
NJ:TXS Rev.7 STi 04-06 Utec-w/rem. map selector and custom tuned maps | Cuztom15 | Engine/Power/Exhaust | 2 | 12-04-2006 04:27 PM |
Which maps are safer to run between PDX and Cobb maps? | gopsu | AccessPort | 59 | 03-06-2006 04:27 PM |
FS: MIAMI Utec rev6b with Remote Map changer W/ or Wo Laptop!+other | Zdsquared | Private 'For Sale' Classifieds | 3 | 11-01-2005 11:26 AM |
