Brakes & Suspension Forum sponsored by The Tire Rack |
11-12-2008, 07:08 PM | #1 |
Member#: 99594
Vehicle:2002 WRX Wagon WR Blue |
Used Koni shocks - expected change in feel from full soft to full firm?
I just picked up what appeared to be a great suspension setup for my needs that included Koni struts already mounted in 2002 wagon strut bodies. I wanted to test the adjustment from full stiff to full soft by hand. I first pushed the strut down and pulled it up to get a feel for the compression and rebound damping at full soft. The resistance seemed to be steady and controlled. I then turned the adjuster to full stiff and pushed down and pulled up. At full stiff I didn't notice any difference in compression, although it was much stiffer in rebound. Is this normal?
I expected the Koni's to get equally stiffer in both compression and rebound and was suprised by the fact that I found no difference in compression between full soft and full stiff. I was just pushing down on the unmounted strut by hand, but I wouldn't think it would make any difference when mounted on a vehicle. Appreciate any input from those with experience with the Koni inserts.
11-12-2008, 07:20 PM | #2 |
Member#: 38772
Vehicle:2 Cars, No Bling |
Yes, Koni single adjustable struts (the yellow ones) only adjust rebound.
11-12-2008, 07:43 PM | #3 |
Member#: 99594
Thanks - makes me feel better.
Why the change in plugs from 02 to 03? | FalconRS | Normally Aspirated Powertrain | 4 | 11-21-2005 11:50 AM |
changing wiring harness from one HU to another | Spy | Car Audio, Video & Security | 2 | 03-17-2005 06:28 AM |
In Philly from Dec. 1st to Dec. 5th! | Jard | Tri-State Area Forum | 2 | 12-01-2003 04:56 PM |
In Irving from 2-12 to 2-16. | Digital_Boy | Texas Impreza Club Forum -- TXIC | 23 | 02-15-2001 04:25 PM |
Arranged my 40 pcs. sockets back in order from the smallest to the largest. | Subies | General Forum Archive | 7 | 10-11-2000 07:46 PM |
