07-06-2003, 12:43 PM | #1 |
Member#: 32186
Miss Shifting
I have a problem (mostly while in turns) with miss shifting sometimes... I intend to go to 4th... and end up in 2nd. Now normally this isnt TOO much of an issue. That is until recently when I was just about at redline and went to shift to 4th and ended up in 2nd! Anyway, my question I guess is if i install a short shifter, do you think this may help resolve my little issue? or would it make it worse?!
07-06-2003, 01:54 PM | #2 |
Member#: 34672
Vehicle:2003 wrx WR Blue Pearl |
No offense, but the issue is that you can't shift.
Getting a short shifter will definitely improve the quality of the shifts, but if you physically have a problem finding that right gate, that's still your problem. |
07-06-2003, 02:04 PM | #3 | |
Member#: 32186
07-06-2003, 04:11 PM | #4 |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
A shifter might help a bit, shifter bushings might help a bit too.
Try getting a shift knob. Knob style. I am a fist shifter too Thats why we made the Knuckleball shift knob. I can use a pistol type if needed but i feel much more comfortable with a ball type knob. I have to admit the Subaru factory shifter is quite vague at best. Happy Shifting [email protected] www.kartboy.com |
07-06-2003, 04:57 PM | #5 |
Member#: 15106
actually a shortshifter will improve the feel of the shift and
lessen your chances for mis shifts. i for one use kartboy shifters on both my cars and ever since mis-shifting has been at a minimum. the subaru shifter is long and hard to find the gates sometimes. and a good shift knob is also a very big plus. my wrx came with those skinny STI titanium knob....it sucked big time. i use greddy knobs. |
07-08-2003, 12:43 AM | #6 |
Street's closed, pizza boy
Member#: 17301
Vehicle:2018 Focus RS 2006 Evo #17 STU |
For the 5->4, don't try to do it in one motion. Just do it in two little motions - 5->N (should happen naturally when you pull it out of 5th) and then N->4 (pull straight back). And it's easier if you either shift before or after the corner, not during, since the side-side motion can throw you off. Plus if you're turning you should probably have two hands on the wheel anyways
p.s. the stock shift knob is rubbery and evil, get the Knuckleball. -bd |
07-08-2003, 12:52 AM | #7 | |
Member#: 32186
But I see your point on the shifting.. As well as the two hands on the wheel thingee ... (*blush*) |
07-08-2003, 07:52 AM | #8 |
Member#: 8808
Vehicle:2011 WRX DGM 5D |
Good points, all of them -- some of my trackwhore friends tell similar stories of lateral G forces making shifts hard to hit.
Certainly, if you're downshifting, double clutching helps you find your gate, as if things don't line up almost immediately, you're probably at the wrong gate, and breaks up the shift into two more manageable chunks. Similarly, waiting for the revs to match on your 3-4 upshift (instead of forcing it in through the synchro) will help you avoid mis-shifts. If you don't feel the dogs line up and the lever just "snick" into gear, you're at the wrong gate. Place it in neutral, clutch out, rev the motor back up a bit, clutch in, and try it again into the correct gate. Train yourself on that technique, as it's a good "escape" technique if you botch a shift under any circumstance and find yourself out of gear when you really need to be in it. /Andrew |
07-08-2003, 01:26 PM | #9 |
Member#: 32186
More and more I am realizing just how much I need someone to teach me these techniques (*sigh). Damn schools are so expensive.... I wish I actually knew someone who could teach me! LOL I guess until I can afford it, it will just be practice, practice, PRACTICE!!!! I do so appreciate all of the wonderful tips and advice I get from you all though!!
07-08-2003, 01:34 PM | #10 |
Member#: 34832
Vehicle:1989 M3 White |
not sure if its been posted, but way i learned when i had trouble was to drop to neutral release the shift knob and it will center above 3rd & 4th. then straight down to 4th.. really slow, but helps you find the center.
07-08-2003, 02:16 PM | #11 |
Member#: 8877
Vehicle:2000 Impreza 2.5RS (sept '01-jan '04) |
Best solution: fix the nut behind the wheel!
General roadracing shifting technique:
http://www.turnfast.com/tech_driving...shifting.lasso Subaru-Specific shifting advice: (Courtesy Mike Shields, one of the original Suby-Guru's!!!) http://www.spdusa.com/shifting.htm Also, STi engine and transmission mounts might also help, by lessening the drivetrain slack that is partly contributing to your missed shifts, as would firmer shifter bushings, a la Kartboy or Cusco. Learning proper technique is free though, and will help you in any car you drive. -scott- |
Similar Threads | ||||
Miss shift, doh! | outferno | STi Forum Archive | 23 | 07-29-2003 05:07 PM |
Miss Shifting | Neaners | Engine Management & Tuning | 2 | 07-07-2003 02:23 AM |
A $10,000 missed shift on an '03 ZO6 Vette | Sirkbac | Off-Topic | 26 | 04-22-2003 11:49 AM |
Missing shifts? | SeanLiew | Newbies & FAQs | 6 | 02-12-2002 06:24 PM |
