11-02-2004, 08:46 AM | #1 |
Member#: 43539
Vehicle:95L 97L 03hedgehog 02 wag 180mph monster |
can a hydraulic tranny work with a car that has a cable clutch(updated)
any info would be graet does anything need to be converted
11-02-2004, 09:58 AM | #2 |
Member#: 34672
Vehicle:2003 wrx WR Blue Pearl |
You might want to explain what you're trying to accomplish, because as phrased, your question makes absolutely no sense.
11-02-2004, 05:32 PM | #3 | |
Member#: 14970
BAIC
Vehicle:1997 GF8 multi |
www.hasport.com Rich The linkage for a cable chasis to a hydo. transmission are the only things that dont have poly. bushings in them |
11-02-2004, 05:58 PM | #4 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & OB XT AWD 6MT EJ22T AWIC Swap |
I don't know exactly what you want to do, but I'll tell you what you need if you want to go from cable to hydraulic.
First off, there are two clutch styles. A pull type and push type. The pull type is found on the turbo legacy, WRX, and to my knowledge, any other subaru with a turbo motor. The push type is found on all the normally aspirated subarus. They are not interchangable. The earlier push type clutches were cable, the newer ones are hydraulic. If you get all the associated bracketry, master cylinder, slave cylinder, clutch pedal assembly, etc. You should be able to convert it. The time consuming part of this swap is the pedal assembly. Try taking the pedal assembly out.....it's a royal pain in the arse. If you have anything but a 90 legacy, the holes should already be there in the firewall. I'm pretty sure the early imprezas 93-95 had the hole in the firewall for the hydraulic clutch master cylinder. If they didn't, you'll have to cut one in the firewall.....like I did. I've got a template on my site www.surrealmirage.com/subaru/swap if this is the case. To be quite honest.....the only advantage I can see to swapping to a hydraulic clutch setup would be to have slightly reduce clutch pedal effort with a stiffer pressure plate. However I really couldn't tell you how much less effort it would be. josh |
11-03-2004, 02:16 AM | #5 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Adding on this, if you simply want to use a clutch from a hyd. equipped car in your cable operated car, you certainly can. I only had to make minor adjustments at the fork to get the correct engagement point.
Jay Storm |
11-03-2004, 08:00 AM | #6 |
Member#: 43539
what i am trying to ask is if a hydulic tranny can be used by a cable clutch
11-03-2004, 08:02 AM | #7 |
Member#: 43539
my car is cable and i just blew my tranny and i might get a tranny from a 98 rs which is hydro can i convert it from hydro to cable
11-03-2004, 09:23 AM | #8 |
Member#: 4800
TXIC
Yes you can do that. You will need to use the clutch fork, hardware, and move the pivot ball's location. If you have both transmissions there, you'll see that there are two spots for the pivot ball to mount to. The hydraulic clutches have the pivot ball in the top hole I believe and the cable ones have it in the bottom hole. You may have to tap that top hole. I don't know if it will be threaded.
Here's a pic to help explain what I'm talking about. http://www.surrealmirage.com/subaru/...2/DCP_3077.JPG |
2008 LGT Clutch, works with 06+ WRX's Also. 21k Miles/ Excellent Shape!! Cheap!! | Kylar | NESIC Private Classifieds | 5 | 09-03-2009 03:01 PM |
2008 LGT Clutch, works with 06+ WRX's Also. 21k Miles/ Excellent Shape!! Cheap!! | Kylar | Drivetrain | 5 | 09-03-2009 03:00 PM |
Can 1 car's accessport work with another car? | Kahn23 | AccessPort | 7 | 11-19-2007 10:36 PM |
Can High Impedience Injectors work with Low Impedience Fuel Rails? | Special | General Community | 3 | 11-12-2007 07:37 PM |
Can an aftermarket headunit work with the factory power antenna??????? | coloradobound | Car Audio, Video & Security | 4 | 09-05-2000 06:53 AM |
