03-10-2002, 11:31 AM | #1 |
Member#: 15669
TXIC
Vehicle:2009 Cadillac STS-vvvvvvvvvv |
2.2l legacy engine and 2.5l RS engine
Someone told me that the heads are the same????
Is this true??? The heads I am looking at are from a 91 legacy and I can get a good deal on them but I need to know if they are the same.I plan on getting them all redone but dont want to buy them if they dont work.
03-11-2002, 12:08 AM | #2 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
They are most certainly different . However, what you probably heard is that the 2.2 heads will fit on a 2.5 block and vice versa, which is indeed true.
Brian http://www.northursalia.com http://www.imprezamods.com http://www.scoobymods.com |
03-11-2002, 02:19 AM | #3 |
Member#: 12588
SCIC
Vehicle:Four Count 'em GF5,BDA,BD5, BP5 |
Also,
heads for the 2.2L (depending on year and vehicle application) are different for the manual transmissions compared to the automatics. Just something to consider. Not sure if this applies to the 2.5 heads as well. Dale |
03-11-2002, 09:17 AM | #4 |
Member#: 15669
TXIC
For a performance engine build,Would it be a good idea to get the 2.2 heads to polish,port and blah blah blah or would I be making a bad decision?
03-24-2002, 06:42 AM | #5 |
Member#: 15135
NWIC
Vehicle:95 GF WRX Black |
Go DOHC 2.5 if you are going N/A. You start with 30 more hp before the build. You are on th right track though.
03-25-2002, 11:45 AM | #6 |
Member#: 1184
South East
Vehicle:2020 STi SeriesWhite Ceramic White |
How do you figure 30 more HP using the 2.5 DOHC heads? The 2nd gen or 2.5 SOHC engine had more horsepower and torque, not much but more.
Kyle |
03-25-2002, 12:43 PM | #7 |
Member#: 15135
NWIC
I am talking about using the whole engine. It is actually more than 30hp. early 90s 2.2 has 132 hp, 97-99 DOHC 2.5 has 165hp.
03-25-2002, 07:30 PM | #8 |
Member#: 1184
South East
Ah yes, the whole engine.
My bad Kyle |
03-28-2002, 12:17 AM | #9 |
Member#: 16831
Vehicle:2000 Legacy L Dark blue |
1993 Impreza L
One question: would the head (2.2 or 2.5) fit on a EJ-18? I heard the block is exactly the same but its displacement was increased.
03-28-2002, 01:52 PM | #10 |
Member#: 1184
South East
All of the Subaru EJ series engines are basically the same block just different bore and stroke.
Kyle |
04-02-2002, 05:47 AM | #11 |
Member#: 16831
Ok. But would there be any heads which would fit and improve the output of the engine? If so, what are the pros and cons of such a swap?
WTB: 90-01 2.2L or 97-07 2.5L NA Flywheel | ej20forester | Private 'Wanted' Classifieds | 1 | 10-27-2009 11:05 AM |
95 2.2L Legacy to 98 2.5L DOHC | EastsideLegacy | Subaru Conversions | 32 | 01-29-2009 06:57 PM |
2.2l closed deck vs 2.5l STI semi-closed deck | 2.5rsDOHC | Normally Aspirated with bolt-on Forced Induction Powertrain | 27 | 09-01-2004 03:55 PM |
2.5l rs engine and MY00 Legacy BE- AVO turbo | Solomon | Legacy Forum | 37 | 07-10-2003 12:57 AM |
2.2l turbo block and 2.5l heads | Jessie James | Normally Aspirated Powertrain | 12 | 01-23-2001 08:34 PM |
