Tire & Wheel Forum sponsored by The Tire Rack |
05-29-2007, 09:35 PM | #1 |
Member#: 110418
Vehicle:2006 Sti white |
tires size question for stock sti BBS rims
I am running cobb springs and 18 x 8.5 volk time attacks currently with 255/40/18 T1R's and they do not rub.
Would that also mean that 255/40/17 would fit with the stock BBS's without rubbing? thanks
05-30-2007, 04:39 AM | #2 |
Member#: 72957
SCIC
Vehicle:2004 EJ257 VF37 51E w/ TypeRA Roof Vent & Lip |
255/40R17 are small than 255/40R18, so I don't see why not.
05-30-2007, 10:03 AM | #3 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
05-30-2007, 10:33 AM | #4 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
I think he meant shorter.
05-30-2007, 12:38 PM | #5 |
Member#: 110445
PRSIC
Why such a wide tire? It'll look like its bulging out. I'd stick with a 225 or 235at the most. You don't want the overlaping sidewalls, it's bad for cornering (folding in).
05-30-2007, 12:39 PM | #6 |
Member#: 86356
05-30-2007, 12:47 PM | #7 |
Member#: 110445
PRSIC
05-30-2007, 01:00 PM | #8 |
Member#: 86356
First of all, he stated they are 8.5" wide wheels.
Second of all, yes. ps- You're. |
05-30-2007, 01:11 PM | #9 |
Member#: 110445
PRSIC
That's not his question. He asked if a 255 would fit a STOCK BBS wheel which is a 18x8. It's an 8 inch wheel not an 8.5. It will fit but it's definately not the best setup. Please read carefully
05-30-2007, 01:13 PM | #10 |
Member#: 110445
PRSIC
Correction: the stock wheel is a 17x8, and there is a good chance that It'll rub in the rear depending on camber
05-30-2007, 01:20 PM | #11 |
Member#: 86356
I totally can't read.
05-30-2007, 05:03 PM | #12 |
Member#: 136889
TXIC
05-30-2007, 05:11 PM | #13 |
Member#: 110445
PRSIC
05-30-2007, 05:18 PM | #14 |
Member#: 136889
TXIC
This is a non-correction to your correction of my correction. Did not know that the 05+ was different. I stand corrected.
05-30-2007, 10:35 PM | #15 |
Member#: 142110
NESIC
Vehicle:2005 STI Blue |
wow let me correct you by saying wow specialist my I3 but the last one was funny
05-31-2007, 12:44 PM | #16 |
Member#: 96050
International
Vehicle:2005 EP Hatch Rrraw! World Rally Blue |
245/40/17 should be ok right??
05-31-2007, 12:59 PM | #17 | |
Member#: 24038
South East
Depending on the tire, sidewall flex may be a non-issue and easily cured with a couple more PSI. No "logrolling" what-so-ever. Very very popular setup. My 255 RT615's on 8" wheels in the mid-high 30's were great. Not 070 great, but still, a nice crisp turn in. See below... Last edited by REX8; 05-31-2007 at 01:07 PM. |
05-31-2007, 01:03 PM | #18 | |
Member#: 24038
South East
Really rolling logs huh?! |
05-31-2007, 07:53 PM | #19 |
Member#: 110445
PRSIC
Please refer to the original question. He states that he's lowered on cobb springs which are a 2" drop in front and 1.5" in the rear. You're on pinks which are not that low. True that you're tires do not logroll, but you have the 615's. I've seen other brands which do protrude on an 8 inch rim. And the overall ride height of the tire will definately throw off your odometer. That's ALOT of tire, not to mention the added stress on your bearings, drivetrain, etc. You're slower because of the added weight and size. It makes absolutely no sense to go that big if you can get the same result with a smaller tire with sticker compound.
05-31-2007, 08:03 PM | #20 | |
Member#: 110445
PRSIC
05-31-2007, 10:44 PM | #21 |
Member#: 86356
He said they don't turn in as well. There's a lot more to a tire than just turn in.
06-01-2007, 02:32 PM | #22 |
Member#: 110445
PRSIC
06-01-2007, 07:14 PM | #23 |
Member#: 86356
06-01-2007, 07:57 PM | #24 |
Member#: 110445
PRSIC
Whatever. It's my opinion and the opinion of tire manufactures like Falcon, BF Goodrich, etc., that the optimun setup for a 255/40/17 lies between the rim size of 8.5-10 inch. No one in this forum including so called suby-gurus can argue the facts.
06-01-2007, 11:34 PM | #25 | |
Member#: 24038
South East
For the street, a 255 is a waste, 8.5"+ wheel or not. Their benefits can't be taken advantage of and the drawbacks will be felt. All the things you mentioned are of course correct...That's something we all post here on a daily basis. As far as other 255 bulging more on an 8" wheel, your research should have showed you that a 255 RT615 and all RT615's for that matter have very very oversized section-widths. Its actually a 265. It's just about the widest of the 255's out there. BTW: Who the heck is Falcon? P.S. The above pic wasn't mine...but I did run them as well in the past (8"/255). I'd hate to see the look on your face if you saw 275's on a 7.5" wheel!!! Last edited by REX8; 06-01-2007 at 11:43 PM. |
Quick tire size question for stock wrx wheels. | 100_Percent_Juice | Tire & Wheel | 2 | 12-13-2008 05:19 PM |
Replacement lug nuts for stock STi bbs rims? | dsmkid95 | Tire & Wheel | 1 | 12-09-2007 02:30 PM |
Tire size for 17's STI BBS Rims on 05 Wagon? | barryj | Tire & Wheel | 4 | 08-21-2007 09:34 PM |
widest tire for stock STI BBS Rims. | Shabib67 | Tire & Wheel | 6 | 05-23-2006 06:03 PM |
Review Winter Tires (Nokian RSI's) on Stock STI BBS rims | STI-05' | Tire & Wheel | 6 | 01-27-2005 09:56 PM |
