Brakes & Suspension Forum sponsored by The Tire Rack |
02-23-2003, 02:24 PM | #1 |
Member#: 11778
MWSOC
Vehicle:1980 VWRabbit Diesel w/AAZ Swap |
suspension that lowers car more than 1.25" ?
I am looking for some setup that is really affordable to lower my caar more than just 1.25" I have eibachs and kyb agx's right now, but I want something that will drop it another 1.25"
So I am looking for some adjustable springs so I dont have to replace the struts, something that will give me a 2.5" drop from stock hieght would be great. Thanks -Eric |
02-23-2003, 02:36 PM | #2 |
Member#: 10644
International
Vehicle:2001 impreza Blue Ridge Pearl |
Not coilovers but cheap and you'll get the car low
5zigen R-rated spring if you can find them, its says 1.6 front, 1.5 rear but on the 2.5 rs it looks really low found an article on these springs Last edited by jdmimpreza; 02-23-2003 at 02:45 PM. |
02-23-2003, 02:45 PM | #3 |
Member#: 1134
MAIC
Vehicle:2015 Outback H-6 White |
Hmmm... 2.5" sounds awfully low... Might be worried about ill-effected handling, at that point...
Maybe someone can correct me, but I'm not sure what an "adjustable spring" would be, whereas you say you want to use stock struts. I'd say that if you're going for the showroom thing, just pick up any old set of drop springs out of some import showcar magazine. Won't cost too much, I bet. But if you want to still hang on to some handling, jeez I don't know, to me that sounds like a big drop. Maybe not though? -S2- |
02-23-2003, 03:06 PM | #4 |
Member#: 11778
MWSOC
sorry, I want the "look" so it may actually only drop it another 3/4" to get the "look" and they will be riding on kyb agx's.
Thanks |
02-23-2003, 03:11 PM | #5 | |
Member#: 10644
International
Old pic |
02-23-2003, 03:22 PM | #6 |
Member#: 3560
South East
Vehicle:20 BRZ 04FXT22WRX95rallyimpreza |
If you're really going to do this, can you go ahead and send me your AGXes? I'd like to have an extra set (just in case), and if you leave them on the car when you lower it 2.5" they'll be destroyed shortly anyway. Plus, the warranty will be void once the car is lowered more than 1.5 inches. I can give you my stock struts - they're shot, too, but with the ride you'll have, you shouldn't be able to notice.
sorry about the sarcasm, but I just wanted to point out a few things you might not be thinking about... |
02-23-2003, 03:33 PM | #7 | |
Member#: 10644
International
02-23-2003, 04:05 PM | #8 |
Member#: 21767
Vehicle:2002 STi wannabe Midnight Blue Swirl |
rub-rub... rub-rub
I think I hear a frog... |
02-23-2003, 04:15 PM | #9 | |
Member#: 10644
International
sorry for posting so many pics, it just makes explaining things a bit easier if you see it as well. |
02-23-2003, 05:40 PM | #10 |
Member#: 11778
MWSOC
I like your car jdmimpreza, looks good.
02-23-2003, 05:44 PM | #11 | |
Member#: 3560
South East
02-23-2003, 05:49 PM | #12 | |
Member#: 10644
International
02-23-2003, 06:32 PM | #13 |
Member#: 11778
MWSOC
Yes, I am lowered about 1.25" on all corners right now, and just want something to lower it alittle more, and get some stiff sway bars to get rid of this body roll i get on long high speed corners.
Here is my clearance with eibach prokit springs and kyb agx's -Eric |
02-23-2003, 06:38 PM | #14 |
Member#: 11778
MWSOC
btw, jdmimpreza what struts are you using in combination with the 5zigen springs?
02-23-2003, 06:48 PM | #15 |
Member#: 1581
Tri-State
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
PM'd you Eric
02-23-2003, 07:20 PM | #16 | |
Member#: 10644
International
I'll be changing them shortly once I get my tax return. I like your set up though, How are the AGX, My friend Sean used to run the Frankenstien set up with the AGX and ground controll Coilovers. He used to Launch that car into jumping over speed bumps and catching full air all 4 tires off the ground. |
02-24-2003, 12:33 AM | #17 |
Member#: 11778
MWSOC
hahaha.. thats great, gettin air over speed bumps..
Mine ride great, not bouncy at all, stiff responsive.. Except, my car is light, and I still have a bit of body roll, and believe it or not, a Honda Odessey can almost out perform me on the on/off ramps on a highway. My friend drives the Honda Odyssey, got it to like 55-65 on this one ramp, and I started sliding (maybe the tires not gripping enough, or just not sticky enough period) I am on Pirelli P6000 Sport Veloce, those maybe why he keeps up with me, his tires screech real bad too, so I figure, lower my car a little bit, get sway bars, and some sticky tires on 17" rims.... he wont stand a chance. That and my friends honda civic out performs me in the corners. not speed wise, but manuverability. You wouldn't believe how fast a honda odyssey is on 93 octane, and a crazy driver, it can beat any stock civic. it's crazy. They are probably one of the best performing minivans I have ever driven (my mom has one too). -Eric |
02-24-2003, 02:43 AM | #18 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
Ground Control coilover springs with adjustable perches. I have them on AGX's, but I ride near stock height as to not destroy the struts... I can drop down to about 2" bellow stock height if I wanted to, and its stiff as bajesus.
Dont ask "where can I get them?" because I dont know, as I got the set up used. Instead try a search as there were several topics created about them already. |
02-24-2003, 10:22 AM | #19 | |
Member#: 10644
International
When I went to a car show this was the craziest thing I've every seen. A tricked out odyssey, own by Turbo Mom of ArtnMotion Back on topic I hear you on the whole body roll, car feels to light situation. I was thinking about getting a roll cage to stiffen it up, but everyone tells me to try coilovers first before I go on the extreme end. I have 2 friends, one with a WRX Wagon with JIC's and his is the re-valved one which come with a soft setting, And man the wagon is a heavy beast, but the JIC coilover suspension helps tap the inner potential of the car. If felt like the car was on tracks and the body felt so stable and solid. My other friend has a JIC set up on his 2.5rs and his is the really stiff one. When I try to keep up with him it looks like he can turn so hard around low speed corners, The JIC's allow him to get the rear tires to really follow what the front are doing(I know it sounds wierd but you have to see it or you just have to try it). Coilovers really make the car feel very solid and responsive. |
Similar Threads | ||||
Suspension that will ride more comfortable than stock! | GoneSingle | Brakes, Steering & Suspension | 10 | 06-02-2010 12:28 PM |
Dog toys that will last more than 6minutes? | SQ3.0dotJP | Off-Topic | 77 | 06-29-2009 02:03 PM |
Organic Chemists: Help (Or people that just know more than me) | BhamRoadrunner | Off-Topic | 35 | 12-07-2007 03:44 PM |
Bands that Never lasted More than One CD.... | Oh Canada | Off-Topic | 114 | 08-04-2005 03:08 AM |
"You love that car more than me!" | Quick WRX | Off-Topic | 32 | 11-11-2002 11:11 AM |
