01-10-2008, 02:11 PM | #1 |
Member#: 122356
NESIC
Vehicle:2002 Impreza WRX World Rally Blue |
O2 sensor, will wideband pass emissions
So i failed my inspection, due to a bad o2 sensor. Not a big deal as I need a wideband o2 anyways due to my catless dp. However, will a wideband 02 sensor pass Massachusetts inspection?
Thanks, brendan
01-10-2008, 02:29 PM | #2 |
Member#: 98961
Vehicle:2003 WRX Black |
Nope on the wideband. Which O2 was bad? You have 2 you know.
01-11-2008, 09:50 AM | #3 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
You can replace the rear O2 sensor with an LM-1 or LC-1, and program one of the analog outputs to act like a factory rear O2 sensor.
If you were to do this, you would also need to disable the CEL for "heater circuit open"... possibly some others as well. |
O2 Sensor, removing wideband question | wantedwrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 02-21-2006 11:58 PM |
my Front O2 sensor caused CEL, will I pass Emissions?? | Jobey | Engine Management & Tuning | 4 | 04-27-2005 06:52 PM |
Substituting O2 sensor for wideband unit. | powerlabs | Normally Aspirated Powertrain | 6 | 02-18-2005 05:04 PM |
O2 sensor not part of emissions | DDub | Warranty Issues & SOA Problems | 11 | 09-24-2004 04:59 PM |
is the FRONT O2 sensor a wideband sensor ? | Extraze | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 12 | 07-01-2004 04:21 PM |
