Tire & Wheel Forum sponsored by The Tire Rack |
07-18-2005, 11:11 PM | #1 |
Member#: 78663
Vehicle:04 WRX STi WRB |
HELP 235/40/17 Tires on stock 04 STI rims
can i fit 235/40/17's on stock sti rims? the 17 by 7.5 04 bbs wheels? would that tire size fit safely and provide any peformance gain?
please let me know soon i am ordering some new tires
07-19-2005, 05:58 AM | #2 | ||
Member#: 27790
E. Canada
finally, the 235/40x17 size is often a pound or two lighter than the equivalent 225/45x17 tire. |
07-19-2005, 06:51 AM | #3 |
Member#: 12901
South East
Vehicle:2005 STi/95 VX Pastelito Racing / SFSOC |
235/40-17 will be fine on that rim. It will be a bit shorter though than the stock size. The speedo on the STi's are already too fast with the stock tires, that size will make it a bit slower. The 235 tire might be a pound lighter in some cases, but it is a pound heavier in others. Not enough to make a difference. There will be no difference in performance in the rain as well for that little a difference. Never known of anyone having insurance problem with larger tires either.
07-19-2005, 07:22 AM | #4 |
Member#: 78663
thanks alot for your help so this is not recommended except maybe to look a little cooler meaning wider which is really why i want to do it
07-19-2005, 07:59 AM | #5 | |
Member#: 12901
South East
Will be a bit wider, and like I said you will not have a problem. I run 255/40's on my 8 inch wide wheel with no problems. |
07-19-2005, 08:53 AM | #6 | |
Member#: 27790
E. Canada
but it does look cooler... |
07-19-2005, 11:09 AM | #7 |
Vehicle:OK buy Nates beans westcoastroasting.com |
.....d00d.....on an STi, you should go with a slightly TALLER tire to get a bit more gear out of it....THAT would be choice for an STi......the WRX needs a bit of help the OTHER way, gearing wise.....and I'm really diggin' the slightly smaller tire, on the WRX, as far as that goes
I'd do a 235/45 on an '04 STi wheel... |
07-19-2005, 12:11 PM | #8 | |
Member#: 12901
South East
Agreed. My next street tire for my 05 STi will be a 235/45, which will help with the gearing and the speedo. I believe that is the stock size the JDM models have on them. |
07-19-2005, 05:57 PM | #9 | ||
Member#: 27790
E. Canada
http://www.subaru-global.com/lineup/...eet/index.html |
07-19-2005, 08:06 PM | #10 |
...there has been some discussion between some local peeps----subaru parts dept/performance enthusiast guys and it seems that, on the '05 STi's, the 225/45 gives an incorrect spedometer reading......the 235/45 makes it spot on.....the S203 has 235/45's, stock....go figure.
...and the STi could use a bit longer 1st and 2nd gear...less shifting--stay in boost ....and a bit taller tire does just this.....go figure. |
07-19-2005, 08:07 PM | #11 | |
Member#: 12901
South East
I must have mistaken it for something else. Maybe because the EVO comes with the 235/45-17. As for the gearing a little extra is always good for autocross, but it is so minimal between 225/45 & 235/45 that you would not even notice the difference on the street. The positive side would be that it would correct the speedo. |
07-19-2005, 08:09 PM | #12 | |
Member#: 12901
South East
07-20-2005, 05:45 AM | #13 | |
Member#: 27790
E. Canada
Similar Threads | ||||
will 235/40-17 rub on stock 03 WRX Sedan | WRXINXS | Tire & Wheel | 11 | 10-13-2007 03:13 PM |
235/40/17 tires on 17x7 rims. | cinemaster | Tire & Wheel | 9 | 05-03-2006 11:36 AM |
Is it okay to mount 235/40/17 tire on a 17/7.5 wheel?? | WRXinEffect | Tire & Wheel | 17 | 05-30-2005 08:56 AM |
Looking for pics of a 235/40/17 tire on 7.5 STi wheel | rich728 | Tire & Wheel | 7 | 06-29-2004 12:47 PM |
does anyone have 235/40 17 tires on 7.5" wide wheels? | rex n effect | Brakes, Steering & Suspension | 0 | 02-03-2003 01:22 AM |
