Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > WRX Forum Archive
Old 02-15-2001, 05:51 AM   #1
Neil Wallerstein
Member#: 938
2004 Former STi now
Dakota 4x4
Question What gauges are best to monitor a turbo engine?
I know this was asked before but there were few real answers. With all the talk about gauge pods I was wondering what guages would be best for monitoring a turbo engine. I already know boost so that leaves two holes to be filled. EGT and oil temp? EGT and oil pressure?
Neil Wallerstein is offline
Old 02-15-2001, 06:48 AM   #2
allbent
Member#: 4075
Blaze Yellow
Smile
I am getting what I think are the 4 most important - Boost for the steering column, oil temp, oil pressure, and EGT for the STi pod. EGT is about the best for tuning, the others are the best for monitoring. Of course, this is IMHO......
Adam
allbent is offline
Old 02-15-2001, 06:54 AM   #3
Prog
Member#: 1473
2005 Legacy GT 5MT
Satin White Pearl
Post
excuse my stupidness but whats EGT?
Prog is offline
Old 02-15-2001, 06:56 AM   #4
CP
Member#: 3522
1997 A4 1.8TQMS
Pearl White
Post
Exhaust Gas Temperature...lets you know if the turbo is going to melt down or is running inefficiently.
CP is offline
Old 02-15-2001, 07:38 AM   #5
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
No, exhaust gas temperature lets you know if you're running rich or lean.
RidinLow is offline
Old 02-15-2001, 07:42 AM   #6
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Post
Boost, EGT, Oil Temp.
Oil pressure is no more an issue than with a non-turbo car, unless you could monitor pressure to the turbo itself, maybe.
[Edit: I forgot this was the WRX forum. You don't need fuel pressure.]
[This message has been edited by Jon Bogert (edited February 15, 2001).]
Jon Bogert is offline
Old 02-15-2001, 08:19 AM   #7
KC
Member#: 442
17 Imp Spurt
00 S2k
Post
AIR/FUEL RATIO Gauge lets you know if you're running rich or lean.
EGT lets you know how stressed the turbo is by the amount of heat going by the o2 sensors.
My ideas for gauges:
Boost, EGT, A/F Meter
--kC
KC is offline
Old 02-15-2001, 08:21 AM   #8
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
I think oil pressure is very important - in any car.
The idiot light only tells you when it is too late.
Let's say you're doing a track day, and are suffering partial oil starvation. A gauge will let you know that but with the stock idiot light you may only see a flicker, if that.
Both of my old English Fords come with oil pressure gauges, and they are a very useful gauge indeed.
Glenn
ANZAC_1915 is offline
Old 02-15-2001, 08:22 AM   #9
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Funny, I use my EGT gauge to judge whether I'm rich or lean.
RidinLow is offline
Old 02-15-2001, 08:28 AM   #10
AWDTURBO
Member#: 4087
Post
Boost-to tell if anything is wrong with the turbo/wastgate. Also nesisary if upgrading the car
EGT-measures temperature of the exaust gasses. Richer the motor runs cooler the egt and vice versa. To hot/lean and bye bye pistons...
A/F-the blinky light kind are not so good. Get a digital number voltage only gauge.
Fuel pressure-any drop in pressure under boost is a very bad thing
Those are the biggies for a turbo car. oil pressure and all the others should go on any car turbo or not.
AWDTURBO is offline
Old 02-15-2001, 09:01 AM   #11
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
Wink
Isn't the EGT gauge used to tell if your 5" chrome exhaust tip is getting hot before it melts your bumper cover? Hahahaha
RidinLow is, of course, correct. Both times.
Old 02-15-2001, 10:54 AM   #12
Dan_E
Member#: 673
1999 2.5RS-T <RIP>
2000 RS-TURBO'D
Post
I would also highly recommend a Fuel pressure gauge. Especially if you plan on running 6psi+ of boost.
Dan_E is offline
Old 02-15-2001, 04:02 PM   #13
Herbie
Member#: 415
2018 WRX Ltd
Dark Grey Metallic
Exclamation
EGT: RidinLow, your a/f mixture directly affects the temps of the exhaust gas. This is how you can use the EGT gauge to adjust mixture, because there is SOME correlation between the mix and the EGT. The more rich the mix, the cooler the EGT, the leaner, the hotter.
An a/f gauge reads this more directly by reading the O2 content in the exhaust stream. The EGT is useful because things OTHER than mix can affect the exhaust temps, and it allows you to find problems not neccesarily related to mix.
Oil Pressure: I too think Oil Pressue is a HUGE deal. Ditto what Glenn says about the idiot light. Notice factory built cars like the Porsche RS, etc. all come with both an oil pressure gauge and oil pressure warning light the size of your hand. And the sensors on those cars are tuned to trip the light BEFORE you get into trouble, whereas on most "consumer" cars, they're set to go off WHEN you're in trouble.
Herbie is offline
Old 02-15-2001, 05:29 PM   #14
RidinLow
Member#: 329
1995 325i
Arctic Gray
Question
Like what other things besides the mixture?
RidinLow is offline
Old 02-16-2001, 10:25 AM   #15
Herbie
Member#: 415
2018 WRX Ltd
Dark Grey Metallic
Post
>Like what other things besides the mixture [affect EGT]?
Compressor trim, compressor sizing, bearing efficiency for the compressor wheel, ignition problems, hot spotting due to bad head/intake work.
There are also purely mechanical things that will make changes in the readings you get (but not neccesarily the actualy combustion temps) like changes in downpipe configuration or length, changed heat shielding, etc.
We found this out the hard way at a track event when a friends DSM was suddenly reading 200* lower EGT's that it had been earlier in the morning. He was very confused and spend 2 sessions trying to sort the fuel mix back out, thinking it had somehow gotten over rich to cause the temp drop. Turns out the tie downs for the header-wrap that he had on a big chunk of his downpipe, etc. had failed and most of the insulation had come away. The result was that the exhaust was radiating more heat into the engine bay, so less heat was being read at the EGT sensor.
Herbie is offline
Old 02-16-2001, 03:30 PM   #16
Neil Wallerstein
Member#: 938
2004 Former STi now
Dakota 4x4
Question
OK, Assuming there won't be much tuning going on in the first year of my cars life would you go with:
A) Boost, EGT, Oil Temp
B) Boost, Oil Temp, Oil Pressure
C) Boost, Oil Temp, AF
D) Boost, Oil Pressure, AF
I may do a little tuning with the car but I won't go for anything above 250hp..
[This message has been edited by Neil Wallerstein (edited February 18, 2001).]
Old 02-17-2001, 12:46 AM   #17
WRX1
Member#: 3533
2002 Impreza WRX
WR Blue
Post
Engine timing has alot to do with EGT vs AFR. If you pre-ignite (due to timing, not octane related), you EGT will readdifferent than what your AFR will read (EGT high temp and AFR rich). To do the best monitoring, you should use both, but not an absolute. Just my .02
WRX1 is offline
Old 02-18-2001, 07:00 AM   #18
Neil Wallerstein
Member#: 938
2004 Former STi now
Dakota 4x4
Post
-Bump-
Old 02-18-2001, 07:55 AM   #19
allbent
Member#: 4075
Blaze Yellow
Post
Since 30 hp should be very easy to come by in these cars, I don't think that there will be major problems with the AF ratio. This would cause me to choose your choice (B), boost, oil pressure, oil temperature. Good luck on getting a consensus here......
Adam
allbent is offline
what is most important to monitor w/ gauges? Vampyr Interior & Exterior Modification 30 09-27-2005 08:34 AM
what mods are best to start with? raginbull74 Newbies & FAQs 4 09-20-2004 08:12 PM
IT guys- What do you use to monitor your server room environment? beachbum Off-Topic 12 08-03-2004 04:20 PM
What parts are needed to turbo a MAP sensored RS? Homemade WRX Normally Aspirated with bolt-on Forced Induction Powertrain 19 12-10-2003 12:21 AM
What gauges are needed to monitor Engine hrtpumper Newbies & FAQs 8 11-26-2002 08:58 AM
