07-08-2006, 02:42 PM | #1 |
Member#: 97634
Vehicle:96 impreza L fugly |
Rear end noise
1996 Subaru impreza L:
I've replaced both wheel bearings. The brakes are all brand new. The noise starts around 15mph, gradually getting louder as speed increases. Does not go away if taken out of gear or clutch pushed in. Tires are ok, not new, but even after rotating, the sound is still there. It sounds just like a wheel bearing or bad brakes... obviously not them, as they have both been fixed. Maybe rear differential? Any suggestions?
07-08-2006, 07:23 PM | #2 |
Member#: 97634
Also, there is no vibration caused by the sound. I forgot to mention that.
anyone? |
07-09-2006, 10:53 AM | #3 |
Member#: 119664
its your rear end, whens the last time you changed the fluid? try changeing it, if that doesent help it will need to be rebuilt
07-09-2006, 11:10 AM | #4 |
GC84Ever
Super Moderator Member#: 301
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
07-09-2006, 11:18 AM | #5 |
Member#: 97634
Klapdout, I will try changing the fluid. I hope that works, i don't want to rebuild the rear end...
Jamie, Yes, the noise is based on speed, not gearing or throttle. I'll change the fluid and see what happens. Thanks. |
07-09-2006, 11:29 AM | #6 |
Member#: 55867
Vehicle:2005 Saabaru AS |
How often do the rear axles go bad? I don't know if you have to do this on scoobs, but on older cars, you had to balance the drive shaft sometimes. Just a thought.
07-09-2006, 06:50 PM | #7 |
Member#: 97634
Changed the fluid, noise is still the same. not sure where to go from here.
07-09-2006, 07:08 PM | #8 |
Member#: 38222
Vehicle:'10 &'12 Foresters another Miata convert |
Dude, seriously... wheel bearings, brakes, diff... all not naturally aspirated. I don't want to seem like a jerk, but there are reasons these forum divisions exist.
07-09-2006, 08:17 PM | #9 |
Member#: 97634
Dude, seriously...pushahh... you do seem like a jerk, and a very bored, uninformative jerk at that. My car is N/A. If the mods want to move it, they can. You are not a mod. Go away and try being supportive or productive... or maybe even both.
Similar Threads | ||||
Rear End Noise | BILLY K | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 06-05-2007 09:39 PM |
rear end noise | ryzies | Transmission (AT/MT) & Driveline | 1 | 01-25-2007 09:15 AM |
97 Legacy Outback w/ AT rear end noise in reverse | ChayesFSS | Outback Forum | 6 | 11-20-2005 08:54 AM |
91 subaru awd help rear end noise | coryc916 | Newbies & FAQs | 0 | 04-11-2005 01:20 AM |
Rear End Noise??? | sen | New England Impreza Club Forum -- NESIC | 3 | 04-17-2003 10:57 PM |
