12-30-2001, 11:16 AM | #1 |
Member#: 8226
Vehicle:2002 WRX sedan Midnight black pearl |
Temp/altitude and boost
My newbie-level understanding (all other things equal) is:
Higher altitude = lower boost Colder temp = higher boost How do these variables interact? Us Rocky Mountain guys have to deal with both daily, and the extremes of both everytime we drive to the moutains (Denver is 5280 ft, to go skiing you have to go through Eisenhower tunnel ~ 11,000 ft). I'm just worried about overboosting in cold temps, as has been reported recently. P.S. I have a longer post in the Rocky Mountain Forum on this same topic directed at local folks.
12-30-2001, 04:46 PM | #2 | |
Member#: 4980
Re: Temp/altitude and boost
When i left my turboxs MBC was set for about 1.25-1.3 bar for our altitude. When i got to Kansas city, the very first time i jumped on the gas, i pegged my 1.5 bar boost gauge! Turned it down to 1.3 bar or so, and when i got back up to albuquerque, it was closer to 1.1-1.2 bar of boost. The car drives MUCH better at sea level than it ever did up here in albuquerque. In fact i have pretty much been depressed with the way it drives ever since i got back up here because its just so much slower both on boost and off. In KC i would get 1 bar of boost by about 3500rpms, in ABQ its closer to 4500rpms before i get that kind of boost. In KC, the car would drive quite happy at 55-60mph in 5th gear and accelerate well i if i rolled on the gas. In albuquerque, 55-60mph is 4th gear duty because there is no low end torque in that rev range up here. All the way around the car was better down there... its sad really, but i am sure going to a sea level track when its time to run again. Enough of this lousy 5200 feet crap. -Nathan |
12-30-2001, 05:28 PM | #3 |
Member#: 12828
Vehicle:2002 WRX WRC Blue Pearl |
Well first off, the higher the altitude, the less dense the air is outside. Less air outside means less air in the engine= less power. As far as heat is concerned, same thing applies, as heat rises, air density decreases. Try running your car in July like you run in Nov/Dec. You will notice the car is much more sluggish in the summer. The same theories apply to tubros/intercoolers/etc. The more efficient the turbo, the more air it can force into the engine without creating HEAT. Also, the more air you can cool through your intercooler will result in more power because cool air is more dense, and the more air you can cram in the cylinders (with the right amount of fuel), the more power the engine will make. Timing and fuel mixtures come in to play too, but you get the general idea.
Stefan |
12-30-2001, 10:50 PM | #4 |
Member#: 9832
South East
Vehicle:2022 WRX Magnetite Gray |
When I dynoed my car last month at TurboXs the boost was set to 15.6psi. Now that the weather has gotten colder I see my boost creeping to 16-16.5psi. The other day (20deg F) I saw a spike of 19psi but did not get an overboost CEL. Reset the computer anyways and now the car seems to have settled down with boost running around 16psi.
Oh yeah I have a unichip. |
12-31-2001, 12:11 PM | #5 |
Member#: 8226
Bueller, Bueller....
Bump. Anyone else have thoughts about this?
FS: Lamco Oil temp, voltage, and boost gauge | Hokie-wrx wagon | MAIC Private Classifieds | 12 | 05-02-2008 06:56 AM |
Altitude and boost | bobofatt | Newbies & FAQs | 9 | 04-20-2008 01:18 PM |
Altitude And Boost Questions | EagleRockWrex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 11-26-2005 02:15 PM |
VF30, altitude and boost question | cmos9 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 03-04-2003 05:25 PM |
Atmospheric pressure at altitude and boost compensation? | john banks | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 03-04-2002 01:30 PM |
