11-29-2001, 12:32 AM | #1 |
Member#: 8935
Vehicle:2001 Impreza 2.5RS Aspen White |
Stalling problem...
Hi folks.
I'm posting this for a friend who has an older model impreza (mid-90's). We're having an issue where the car is throwing a CE light, giving the reason as a problem with the fuel pump relay system. The car semi-stalls intermittently while driving, in any gear, at any speed above idle. The car dosent stall completely, though -- the tach drops to zero and quickly jumps back up again. Would it be a bad idea to hard-wire the relays (so that the circuits they control are always "on") just to see if that is the problem? Any other ideas on what it could be? I think he has replaced the relays once already. Any suggestions appreciated. Thanks...
11-29-2001, 03:07 AM | #2 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
sounds like the Main Realy is going out....change it...
Jeremy |
11-29-2001, 05:01 PM | #3 |
Member#: 9436
Vehicle:05 Saab 9-5 Aero |
Hardwiring the relays won't hurt anything, just be sure to rememer to undo it. I would suspect an electrical problem, because of the tach that suddenly goes to 0 at the same time as the stall/stumble. Look for anything that would be common to both the fuel relay and the tach(or ignition system) like power feeds from the ignition switch for example.
11-29-2001, 05:53 PM | #4 |
Member#: 8935
Thanks for the ideas...
Changed the relays... same thing. I'm looking over the wiring now... will update later. Dave |
Similar Threads | ||||
Stalling Problems....??? | GraVitY0 | Normally Aspirated Powertrain | 4 | 03-04-2004 12:51 AM |
Ideas on stalling problem? | BIGSKYWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-04-2003 09:22 AM |
Compressor stall problem I think. Also, is there a such thing a wastegate slap? | knuckles | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 11-19-2002 07:28 PM |
stalling problems | jbdesros | Normally Aspirated Powertrain | 7 | 09-17-2001 01:44 PM |
Stalling Problems with MY98 RS Turbo | yebokmj | Normally Aspirated with bolt-on Forced Induction Powertrain | 24 | 08-29-2001 10:37 PM |
