08-26-2001, 09:03 PM | #1 |
Member#: 3181
Vehicle:07 Rav4 Silver |
Which manual tranmission fluid to use?
I need to add manual tramission fluid to my manual WRX. What type should I purchase? Also, you put the fuild in the same hole as the dipstick right?
08-26-2001, 09:47 PM | #2 |
Member#: 1590
Vehicle:2004 Rx8 |
I've heard a lot of people are liking the Red line shockproof line of gear oils just be sure to run the superlight, other than that any redline or amsoil synthetic is good also try this link
08-26-2001, 11:38 PM | #3 |
Member#: 4324
Vehicle:02 GDA Platinum |
Actually most people are running the Redline 75w90NS in the trans and either shockproff or 75W90 in the rear diff.
Im using the 75w90ns in the trans myself, very smooth and quiet no crunchiness, or gridning at all. i would reccomend it. EJ20WRX |
08-26-2001, 11:49 PM | #4 |
Member#: 7089
NWIC
Vehicle:2016 STi |
Same here - redline 75w90ns in front diff/tranny, love it.
08-27-2001, 02:10 AM | #5 |
Member#: 6046
BAIC
Vehicle:'08 Prius |
My MT fluid is at the "L" point too. Are you going to top it off or change it wholesale, and where do you drain the MT fluid?
08-27-2001, 07:52 AM | #6 |
Member#: 4083
NESIC
Vehicle:2018 OB 3.6R Limited magentite gray |
I'm running Redline 75w90 NS too. Its nice. Suprside how much junk was on the magnet on the drain plug. I'm using Amsoil Series 2000 75w90 in the rear diff. I got it as a trade.
No problems - but haven't been able to evaluate gas mileage as I've had my foot in it... The drain plug is underneath the transmission. 1/2 inch drive on it. Roger |
08-27-2001, 08:36 AM | #7 |
Member#: 7089
NWIC
Vehicle:2016 STi |
Fubaru - There is a big gold bolt on the bottom of the transmission case. You can't miss it. It's like 19 or 21 mm. Big sum'bitch.
08-27-2001, 08:51 AM | #8 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
Was running Redline 75W90NS in the trans, but I hated it. IMO, it doesn't spin the synchros fast enough, so I ground into gear often.
08-27-2001, 09:31 AM | #9 | |
Member#: 3181
So what fluid did you decide to use? I'm low on transmission fluid, and I'm having the grinding grears problem as well.
08-27-2001, 09:57 AM | #10 |
Member#: 4083
NESIC
8,
Umm, not to tell you how to drive, but I've been told by several people at Subaru Dealers not to shift into 1st unless stopped. 2nd should be able to carry you through. Roger |
08-27-2001, 04:14 PM | #11 |
Member#: 8679
Vehicle:2010 The most hated vehicle on the internets |
He never said specificallly he shifted from 2nd (or any gear for that matter) to first, he just said downshift. Anyhoo, just do what I do, double clutch on the downshift, it makes things s lot smoother...
Corn-Picker |
08-27-2001, 04:49 PM | #12 |
Actually, I didn't even say downshift. I just shifted too fast for it. *shrug*
What fluid did I use? Uhhh... well it depends on how my trans. gets fixed.... (still broken) |
PS fluid low, best fluid to use? | Subystud | Brakes, Steering & Suspension | 2 | 09-28-2007 12:22 PM |
Which Redline Tranny/Rear Diff Fluid to use for 6Spd??? | NotoriousD | Service & Maintenance | 3 | 04-29-2006 03:39 PM |
Which Redline Transmission/Rear Diff fluid to use? Info please! | NotoriousD | Transmission (AT/MT) & Driveline | 3 | 04-25-2006 10:30 PM |
('93-'01) Which Transmission Fluid to use? | 2yLiTe | Impreza Forum | 6 | 04-29-2001 12:04 AM |
Which Brake Fluid to Use? | silverSurfer | Brakes, Steering & Suspension | 21 | 02-03-2001 12:27 AM |
