07-23-2005, 01:40 AM | #1 |
Member#: 35584
South East
Vehicle:1965 FFR Roadster Coyote + TR-6060 |
I've got LED turn signal problems
I did a Koji mod on my 2003 headlights, painted the inside trim black, and got replaced the the ugly yellow bulb cover with a straight tube. I replaced the lamp with 19 bulb LEDs but now I have a problem. Because the LEDs draw less power, they blink fast as if the bulbs are out, which they are not.
Anyone else have this problem? Any idea how to fix this?
07-23-2005, 01:41 AM | #2 |
Member#: 73008
NESIC
i have catz 9 led bulbs and no blinker problems, they blink the same speed as before. there prolly isnt the right resistance across the bulb. if you know any electronics guru's they might be able to fix that for you by add or changing an resistor.
07-23-2005, 12:49 PM | #3 |
Member#: 3782
South East
Vehicle:02 WRX WFC#040 Clean on 19's |
yeah u need a resistor to make them flash normally, I have LED's in the front and I like them flashing faster...
07-23-2005, 01:47 PM | #4 |
Member#: 22035
SCIC
Vehicle:2014 Brocoma DCab 71 FJ40, 13 DRZ400SM |
Try getting a electronic flasher or a no load sensing flasher.
should fix it. Shane |
07-23-2005, 01:48 PM | #5 |
Member#: 68902
Vehicle:2011 WRX - WRBM 1988 Fiero GT - black |
You need a reisistor or a load equalizer. Same thing, different name. Get them here:
http://superlumination.com/equalizers.htm Check out my conversion thread here: http://forums.nasioc.com/forums/show...lb+replacement |
07-23-2005, 02:18 PM | #6 |
Member#: 22035
SCIC
I really dont like the idea of just sticking a large resistor to fix this problem.
get the non load sensing flasher. Shane |
07-23-2005, 02:19 PM | #7 |
Member#: 35584
South East
Wirelessly posted (Treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
Thanks people! I can always count on you. Chris |
LED turn signal Morette Mirror covers added... | Subie Gal | Interior & Exterior Modification | 27 | 10-05-2006 07:44 PM |
wing riser w/ LED turn signal (w/ videoclip) | satrya | Interior & Exterior Modification | 21 | 07-16-2003 12:16 PM |
how come my LED turn signal bulbs are barfing on my '00 RS? | sir_aspen_white | Electrical & Lighting | 16 | 03-11-2003 02:21 AM |
1999 RS w/ LED turn signals | Basshead | Electrical & Lighting | 6 | 03-11-2003 02:20 AM |
Anyone using LED turn signal bulbs... | Norb | Interior & Exterior Modification | 18 | 11-01-2001 10:14 PM |
