10-05-2014, 10:03 AM | #626 |
Member#: 337639
10-14-2014, 03:00 PM | #627 |
Member#: 134247
Vehicle:2012 STI Black |
yah, all is very interesting,
i've been told that my stock rotors can't be turned (they're 29mm now and "warped") and i am in need of a new set (front) for 2012 sti. called local dealer and they quoted me 433 per rotor ..... i say - it's a ripoff. since i am not doing track or rally, and not going for a punk look: what would be a smart reasonably priced decent quality rotor? would it make a difference if chunk of metal is called duralast or stoptech or brembo? would my stoptech street performance pads (which i got for less dust reason) eat into either brand faster or warp them quicker? should i bother looking for specific brand or just purchase cheapest direct fit online? btw, what is that myth about "warping" disks, as far as i understand vibrations come from un-evenly spread break pad material http://www.stoptech.com/technical-su...nd-other-myths so when i called local shop about turning my rotors they told me that discard size is 27mm for my rotors and my rotors start with 29.74mm new, so to get them "straight" from being "warped" they need to take more than 1mm from each side, can there really be more than 1mm or breakpad material left on rotor that's not seen by naked eye? thanks ! |
12-08-2014, 03:45 PM | #628 |
Member#: 408149
Vehicle:2004 Impreza RS |
Very useful read. I was telling myself that I needed new brakes.
Just bought the car a month ago... But nope all is good. Thanks much OP! |
12-15-2014, 01:58 PM | #629 |
Member#: 408263
Vehicle:1991 legacy White |
Well put. Got it, many years ago. Its comes under basic physics.
12-23-2014, 02:34 PM | #630 |
Member#: 409216
2011 wrx brakes
I just picked up a 2015 impreza last night....CVT both othewise base...i must say that this thing has more decisive stopping power than my 2011 WRX.... tempting to upgrade to a 2015 rex
12-23-2014, 06:53 PM | #631 |
Member#: 71910
Vehicle:2005 WRB WRX - Stg 2 2013 DGM WRX 5-dr |
12-23-2014, 07:28 PM | #632 |
Member#: 68797
Vehicle:04 WRX Aspen Whiiiiiiite |
And probably has more braking assist, and more weight transfer from softer springs..?
12-24-2014, 05:53 AM | #633 |
Member#: 409270
Vehicle:2013 WRX Charcoal grey |
Well written! I've had my share of fast cars over the years that ranged from mid 11's in the 1/4 up to stockers that were in the 13's. I was a mechanic for 19 yrs before my career change and NEVER had to upgrade/modify my brake systems. I just kept on top of my OEM style brake systems and serviced them accordingly - never had an issue!! - Even in my 3200 lbs 67 Firebird which was in the mid 11's, had drums all around and stopped after the traps with plenty of track left to go everytime!
12-31-2014, 02:27 PM | #634 |
Member#: 409806
Excellent read, now I know to save my cash and just buy better tires, as that has numerous performance gains instead of braking systems which will only help me in my pedal feel.
12-31-2014, 09:41 PM | #635 |
Member#: 409836
South East
Vehicle:1988 Loyale Wagon Maroon |
Very, very informative post. Thank You. Not that I am doing any speeding, but there are times when knowing shortest brake times could save a wreck, or help miss a tree.
02-12-2015, 11:18 PM | #636 |
Member#: 413310
Vehicle:2006 STI GDB EJ207 RALLY BLUE |
100% True! Great Post!
02-16-2015, 11:11 AM | #637 | |
Member#: 413206
brake fade
I have been in situations where the continual use of brakes, improved or stock, where the riding of brakes will fade. Shift down a gear on corners and steep hills and save your brakes until you really need them. |
02-19-2015, 10:30 PM | #638 |
Member#: 399805
SWIC
Vehicle:2004 Impreza WRX Silver |
Important read, will definitely be upgrading my rotors and pads in the near future.
02-20-2015, 07:37 PM | #639 |
Member#: 372347
Vehicle:2006 STi WRB |
that was awesome.
03-05-2015, 11:14 PM | #640 |
Member#: 415164
Vehicle:2006 Audi S4 |
Thanks for the info!
03-20-2015, 08:47 AM | #641 |
Member#: 342391
Vehicle:2015 WRX Black |
One thing to add, putting a 1000 piston caliper is not doing anything or increasing brake bite, what it is doing is making you think your awesome. The stopping force is from how the brake fluid moves through the caliper and how evenly it is distributed to each piston.
03-27-2015, 12:22 PM | #642 |
Member#: 174328
Thanks for the info! Will come in handy.
03-29-2015, 06:40 PM | #643 |
Member#: 162631
Vehicle:03 subaru wrx silver |
Great post! I swapped to some brembos off a sti for my 02 wrx and did notice a difference in braking. I did rotors and lines as well.
04-10-2015, 12:02 AM | #644 |
Member#: 418150
Vehicle:2008 STI black |
good post
Agreed
06-07-2015, 05:40 PM | #645 |
Member#: 423019
thanks for this post! It was super interesting and i totally agree
07-12-2015, 08:07 PM | #646 |
Member#: 425538
Well written
07-21-2015, 04:11 PM | #647 |
Member#: 324308
BAIC
Vehicle:2002 WRX Black |
S/S lines are good for track. No hose expansion from the insane heat so no loss of stopping power.
07-21-2015, 04:28 PM | #648 |
Member#: 165300
SWIC
Vehicle:2006 WRX Steel Gray Met. |
OP is 100% Correct.
I used to work for Toyo Technical Department for 7 years and it is very solid to me. Good post man. TA. |
07-21-2015, 10:58 PM | #649 |
Member#: 426294
Recent incident
I Just recently had an incident where a truck could stop faster than I could causing me to collide with him. haha Anyway most of it was probrably because I dont have ABS in my 95 subaru impreza L with the 2.2l eng. but I am also losing brake fluid somewhere and my brake light stays on for the whole winter and this most recent summer it never went off. Any information on how the brake light sensor functions or what might make my brake light come on other than having my parking brake on would be greatly appreciated. For the past 2 years or so it would come on for the winter and go off when it thawed, (I live In michigan), but this last summer it never went off. Any info would be appreciated. I like to understand things so if you think something you want to share is irrelevent, **** you, tell me that irrelevent peice of info. It is what makes me happy.
07-27-2015, 02:06 PM | #650 |
Member#: 313161
Vehicle:2003 wrx wagon black |
Thanks for the huge clarification, also this thread will be saving me an abundance of money.
Creepy cat is going to get you. | aod | Off-Topic | 32 | 10-26-2011 03:00 AM |
this is going to break a lot of hearts | brentyloke | General Community | 5 | 10-25-2008 12:36 AM |
this thing is going to get me fired | dr_wheel | Off-Topic | 9 | 12-09-2004 06:43 PM |
Do you think this is going to cause problems? | AustinSTi | Normally Aspirated Powertrain | 7 | 11-27-2003 09:08 PM |
