11-17-2001, 09:42 PM | #1 |
Member#: 12421
Anyone put the intercooler in front then use the scoupe for Ram air?
11-17-2001, 09:56 PM | #2 |
Sooby Guru
Member#: 1914
SWIC
Vehicle:2000 2.5RS w/ EJ22T swap and N20. gone. : ( |
I guess you could do that but the amount of plumbing would be tremendous. Lag would be horrible. Besides, what do you need ram air for if you are running boost?
Eric |
11-17-2001, 10:13 PM | #3 |
Member#: 12421
besides being cold air, you'd be compressing compressed air. Maybe get an extra psi or 2.
11-17-2001, 10:42 PM | #4 |
Sooby Guru
Member#: 1914
SWIC
If you want a couple more PSI, crank up the boost a bit
Eric |
11-18-2001, 09:36 AM | #5 |
Member#: 7624
Vehicle:BD5; family sedan that just wooped your ass |
Ram air only increases psi at high speeds. 100+ mph
11-18-2001, 10:52 PM | #6 |
Member#: 5857
NWIC
Vehicle:2004 STI WRB |
I think ram air would be good.. more air is always a plus for me.
11-19-2001, 08:05 AM | #7 |
Member#: 865
Vehicle:2003 BMW M3 Phoenix Yellow |
huh?
This would provide no value whatsoever. The backpressure of the massive piping to the IC, the IC itself, the massive piping back to the turbo and the turbo itself would negate any sort of ram air effect. Like Imprezinator said, turn up the boost a bit.
Kurt |
11-19-2001, 09:11 AM | #8 | |
Member#: 6162
South East
Vehicle:2002 WRX MBP, 1st WRX Ever in FL. |
Re: huh?
To answer the question, yes, there is benefit. That's probably why the WRC car uses both a FMIC and a ram-air intake. Yes, I am fully aware that there is less piping in the WRC car, but a street car is merely experiencing more lag through pressurization delay in the piping. There is little-to-no pressure drop across a smooth bore, constant radius pipe. |
11-21-2001, 06:14 AM | #9 |
Member#: 8167
Vehicle:2001 ForesterS-Turbo Premium Silver |
You'd be better off turning the scoop around so that hot air is sucked OUT of the engine bay by air flowing over the hood. You might get oil and crap on the windscreen though. Regarding Ram air, stick your hand out of the window at 50mph and tell me that a ram duct with the same area isn't going to do any good! My friend has one on his Pulsar GTiR and he reckons it makes a difference. Go to http://www.godzillr.com for more info. Look in the 'GIG today' section and go to the last page.
11-21-2001, 07:44 AM | #10 |
Member#: 8943
TXIC
Vehicle:2006 MINI + Corvette Both Blue |
It will be great when somebody comes out with vents that really work well with the WRX hood!
Then when you go to front mount intercooler you can still obtain benefits with the scoop and vents combination? GoodFinder |
11-21-2001, 08:03 AM | #11 |
Member#: 7624
Learn something.http://www.fortunecity.com/silversto...tech_index.htm
11-21-2001, 02:09 PM | #12 |
Member#: 3931
Vehicle:WRX, Ninja, RX-7 Legacy, Fiat 850 |
I'd be surprised if there were any gains from ram air. You won't gain a PSI or two, since we still have a functional wastegate. You may get cold air, but it's just going to be heated up by the turbo. Any extra air to the turbo from a ram air setup is going to be lost in the pressure drop in a front mount intercooler, anyway.
11-21-2001, 02:25 PM | #13 |
Member#: 6162
South East
Why is it so hard to understand that there is a suction vacuum at the inlet of the turbo? If you pressurize this, you will make more power. For example, nissan made a production supercharged, turbocharged engine that placed the supercharger in front of the turbo.
Furthermore, the stock WRX airbox-inlet pipe neck exhibits a 6.3psi pressure drop in itself. If you make it harder for the turbo to get air, it produces less power. If you make it easier, it produces more (roughly). Yes, I am oversimplifying at this point. |
11-21-2001, 06:46 PM | #14 |
Member#: 5857
NWIC
I still think front mount would be better.. bigger area... if your worried about lag set up a fogger system infront of your ic. Cusco has a nice hood with a really nice vent setup.. well not really vents but yea..
11-21-2001, 07:54 PM | #15 |
Member#: 12495
I agree it would be not be worth making the intake get air from the scoop, but the colder the air is in before the turbo, the cooler it will be when it leaves the turbo. The turbo will heat it up less, and I can't remember the exact number, but every 3 degrees is like 1 hp or something like that.
11-22-2001, 12:17 AM | #16 |
Member#: 1911
Vehicle:2000 Impreza 2.5RS Silverthorn Metallic |
I think it is silly to go this route, but whatever. My only reason for posting is that "scoupe" is a car from Hyundai. What is on our cars is a scoop.
11-22-2001, 03:46 AM | #17 |
Member#: 5857
NWIC
good eye there...
11-22-2001, 06:16 AM | #18 | |
Member#: 1934
Vehicle:2002 WRX Sedan |
Philip |
11-22-2001, 09:57 AM | #19 |
Member#: 8943
TXIC
The Aqua picture looks very interesting indeed.
Do you know who might have more information (in English) on this? GoodFinder |
11-22-2001, 10:14 AM | #20 |
Member#: 7624
I would like a SCOUPE of ice cream.
I am glad we have people around to point out our misspelling errors. This is an INFORMAL board and misspellings do not get you a lower grade. Especially when they are an accident.:monkey: |
11-22-2001, 10:54 AM | #21 |
Member#: 9827
Vehicle:2002 WRX Wgn 292whp Alex Performance |
Why is everybody saying that long intercooler piping adds turbo lag? Have you tried it? I have several cars with front moutn intercoolers and I have a lot of friends that got very creative with fmic's and used a LOT of piping. In all cases there was no extra lag, as a matter of fact the performance difference was very, very pronounced because of the cool air from the front.
Alex... |
11-22-2001, 12:10 PM | #22 |
Member#: 6162
South East
Most of them are discussing theory. It will just decrease throttle response, not increase lag, and with the colder air, you wouldn't notice anyway.
Personally, I'd rather top mount some auxiliary coolers. |
11-22-2001, 12:28 PM | #23 |
Member#: 7962
Vehicle:08 335i TwinTurbo PSM 02WRX, 97 Dipped CRV |
good idea
I have to agree with Conduit
Just from a physics stand point, it would have to be a advantage for WRX's with significant mods for power. Bill |
11-22-2001, 12:31 PM | #24 |
Member#: 7624
If there is a loss of response etc. why do so many high-performance cars use the system?
11-22-2001, 04:18 PM | #25 |
Member#: 8943
TXIC
Next week Cobb Tuning will install and tune the FMIC and new turbo for my WRX (going to the APS-Cobb RT Spec Stage 2). So then with the stock intercooler gone, I have some new "real estate" under the hood to work with. I had thought about some auxiliary cooler units up there, but was concerned regarding what if a "leak" of any kind developed, since it will drip (or flow) right onto the top of the engine. Any thoughts? GoodFinder
Ideas to stop the road in front of my house from being used for burnouts.. | Fish | Off-Topic | 86 | 09-10-2007 02:15 PM |
Put Helen Keller on this, then videotape the results. FTW? | rogue | Off-Topic | 27 | 08-13-2007 07:27 PM |
Anyone put 6.5in in the rear deck? | super laubo | Car Audio, Video & Security | 11 | 05-26-2006 07:48 PM |
heat shields for ram air intakes....worth the $20? | kaisersouse | Normally Aspirated Powertrain | 2 | 08-08-2005 01:14 PM |
Used blue AEM short ram air and new AEM trupower pulley | brfatal | Private 'For Sale' Classifieds | 0 | 04-03-2004 01:33 PM |
