11-25-2014, 09:05 PM | #1 |
Member#: 405515
Vehicle:2015 WRX |
2015 WRX lsd?
I was wondering if you guys can shed some light on this. Does the 2015 non sti have a limited slip differential or something like it? Does more power go to the outer wheels on turns? If not then what is the point of the display in the center showing how much power is going to each wheel?
Sent from my SM-G900V using NASIOC mobile app
11-25-2014, 09:11 PM | #2 |
Member#: 401780
Vehicle:2015 WRX CBS |
no it has an open differential. The display is for brake vectoring
11-25-2014, 09:13 PM | #3 |
Member#: 7374
BAIC
Vehicle:2023 MAGA Hat Model3 grey, or is it gray? |
Open differentials. And the last time I drove on LSD was in 1991 in a Saab 900 turbo. It was trippy, particularly when it started to rain and I had to turn on the wipers. I recommend against it.
11-25-2014, 09:17 PM | #4 |
Member#: 299286
NESIC
Vehicle:2017 Legacy Limited White |
Are you sure the display shows when the car is using torque vectoring?
Maybe, I think it is mainly for low traction situations to see what each wheel is doing -- I hope to encounter one such situation tomorrow, during the expected snow storm... In everyday driving that display is pretty damn boring. I just drove thru snowmaggedon and the display is still pretty damn boring. What you get is usually temporary flashing lights on all 4 wheels simultaneously while the traction control light flashes. For very brief moments it sometimes shows only one or two wheels when the traction light comes on, but mostly, lots of temporary flashes that amuse but don't inform. Probably only useful when stuck in the snow, as the other person suggested, so you can restore traction to the slipping wheels, but how often is that gonna happen, when the other wheels usually get traction... Last edited by Zeeper; 11-26-2014 at 04:59 PM. Reason: just tested the lights, woot! |
11-25-2014, 09:23 PM | #5 | |
Member#: 400973
International
It shows if you've slipped in the last 30 seconds or what wheel is slipping. The only time I think this would be helpful is if you are stuck in snow you'll know what wheel to focus your digging or providing traction efforts. |
11-25-2014, 09:28 PM | #6 |
Member#: 394143
Vehicle:2002 WRX PSM 09 NISMO 370z / 90 GT-R |
They stopped using LSD in 2008. IMO an LSD required for any performance car, its a must have. Thats why the STI's get them. Very disappointing to hear they don't have them. At least i have one in my old 2002 WRX.
11-25-2014, 09:49 PM | #7 |
Member#: 204578
Open diffs. No ability to generate anything but 50/50 side to side. Despite what the marketing department would lead you to believe.
11-25-2014, 10:16 PM | #8 |
Member#: 388015
2015 WRX lsd?
Viscous center diff and open front and rear diffs with brake assisted torque vectoring if you are in normal or trac mode.
Viscous diff helps send power to the front or back, whichever isn't slipping. Defaults at 50/50 torq distribution. I'd like to know if anyone has information about replacing the center diff. Are there any "bolt on" options or custom options? STI swap maybe? BTW, Cusco offers a 183 L15 rear lsd that works. Sent from my iPhone using NASIOC |
11-26-2014, 02:51 PM | #9 |
Big Ron
Super Moderator Member#: 18062
And when searching for intense technical knowledge on a vehicle you intend to spend thousands on, the LAST thing you want to do is perform said critical research on a god damn phone! Go to subaru.com and read, then go to the transmission forum AKA the right forum and read, then ask specific pointed questions after taking the right steps in the process.
11-26-2014, 03:05 PM | #10 | |
Member#: 405515
Vehicle:2015 WRX |
Sent from my SM-G900V using NASIOC mobile app |
11-26-2014, 03:07 PM | #11 |
Member#: 299286
NESIC
Note: the CVT WRX does not have a viscous coupler, uses an electronically controlled clutch system, similar to other Subaru automatics.
While there is no LSD, the current generations of Subaru use integrated Vehicle Dynamics Control (ABS, Traction Control) and the WRX has torque vectoring. In normal, on road driving, I doubt you will have issues with loss of traction due to the open differentials, but if that is your concern, sell it and buy an STI. |
11-26-2014, 10:33 PM | #12 |
Member#: 257679
Vehicle:2004 WRX Platinum Silver |
I thought the Australian 2015 WRX still had rear LSD but open front diff.
11-27-2014, 12:00 AM | #13 |
Member#: 402196
11-27-2014, 01:18 AM | #14 |
Member#: 405515
Vehicle:2015 WRX |
11-27-2014, 02:31 AM | #15 |
Member#: 388015
11-27-2014, 03:42 AM | #16 |
Member#: 399921
11-27-2014, 05:35 AM | #17 | |
Member#: 204578
11-27-2014, 05:48 AM | #18 |
Member#: 402196
It is just in the spec sheet, and there are many Australian reviews highlighting Viscous LSD.
http://www.subaru.com.au/wrx-and-wrx-sti/specs I have been looking for the part number, but having no luck yet, might have to ask subaru genuine parts dealers. |
11-27-2014, 06:09 AM | #19 | |
Member#: 204578
11-27-2014, 07:21 AM | #20 | |
Member#: 402196
http://subaru-com-au-2.s3.amazonaws....8__for_web.pdf |
11-27-2014, 11:07 AM | #21 | |
Member#: 204578
The Spec-sheet again only mentions the VC center diff...nothing about the front or rear diffs. |
11-27-2014, 11:59 AM | #22 |
Member#: 388015
It says "traction control Limited Slip Device (LSD)". I still think they are talking about the center diff.
11-27-2014, 05:27 PM | #23 |
Member#: 402196
lol.. could have done a search..
ok, go to page 24, in 'MODEL FEATURE SPECIFICATIONS' page, look for 'Rear Limited Slip Differential (LSD) (manual)' and/or Torsen in the left hand side column, under 'CHASSIS AND MECHANISM'. |
11-27-2014, 08:21 PM | #24 | |
Member#: 118209
Vehicle:2015 WRX Limitec |
Its splitting hairs, but it DOES have the ability to limit the amount of wheel spin (not torque) via the brakes... Is it the same, no... but in practice it can work fairly well. My only complaint with the 'virtual' LSD is that it is a little too aggressive with the brakes, but that is more the ABS system then anything else, there is no analog control. Its full on or full off, more or less PWM. |
11-28-2014, 08:10 PM | #25 | |
Member#: 204578
I didn't say it wasn't useful. I just said it takes a commonly understood term of art, and assigns it to a lesser function. Notice all the confusion on the this forum alone since its intro? It's not splitting hairs, it's a ****ty marketing ploy. |
