05-12-2001, 01:21 PM | #1 |
Member#: 3844
Vehicle:1993 Legacy 1.8 White |
Lowering idle RPM?
I think that the car is using too high rpms when idling. Does anyone know how to do this adjustment? Hope it's not ECU related. Most of you have Imprezas but I think it would nearly the same with my oldie. Pics would be great but any comment is highly appreciated. Thanks in advance...
tony [This message has been edited by tonytiger (edited May 14, 2001).] |
05-12-2001, 04:11 PM | #2 |
Member#: 2263
Tri-State
Vehicle:2014 Sportwagen TDI |
Its controlled by the computer. What do you idle at!? When I start it up, I hover at 1500 for a while, then it drops to 1000. When it is compleatly warmed up, it sits at 500.
Kevin 95 L |
05-12-2001, 05:32 PM | #3 |
Member#: 1284
Vehicle:2005 Legacy GT Royal Blue Pearl |
There is an idle screw. If you look at the throttle body from the front of the car, it is located to the right of and almost below the throttle body. There is a 8 mm, IIRC, nut that keeps the screw in place. The head of the screw faces the firewall and you'll need a small phillips head screwdriver to turn it. Screwing it in increases the throttle opening at idle, hence raising RPM, and vice versa.
Hope this help, Joe If no one posts any pictures by tomorrow morning, I'll go take some and post it. BTW, be careful when you mess around with it. Lowering your idle RPM too much could cause the car to stall when you lift off throttle! |
05-13-2001, 01:51 PM | #4 |
Member#: 3844
jhuang76: Thank you very much. Still waiting for the photos if it isn't asked too much. Normally it hasn't used as high rpms when at idle. Nowadays it uses rather high rpms at the start (about 1500) but doesn't lower enough when warmed up. Dunno if this at all a wice thing to do but I'm giving a shot. Besides it's fun to all kinds of adjustments. Hmm...just catch a thoght about a that my battery went down last winter (minus 15 celsius). Maybe it has reset my ecu and therefore it doesn't lower... Any thoghts? Was it something like battery off for an half an hour and let it warm up by itself and then turn of...Thanks again
kevin: didn't catch your drift about idling, it's my mother language tony |
05-14-2001, 02:34 PM | #5 |
Member#: 3844
Umh, didn't find the skrew. It's time for brain or eye update mod If you are still here with us Joe please take a couple of fotos and sem them in. Of course anybody else is welcome to send them. Gimme gimme Haven't check my spark plugs for a while, maybe I should check those out also while messing under the hood, if those are causing the situation...
Similar Threads | ||||
Needle drop lower than idling RPM... | Henry | Engine Management & Tuning | 2 | 09-25-2003 10:52 AM |
Help! Needle drop lower than idling RPM?? | kalasend | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 05-07-2003 09:11 AM |
Raising the idle rpm speed | PaulRex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-17-2002 08:51 AM |
High idle RPMs and throtlle blips when shifting | Holograph | Service & Maintenance | 9 | 09-19-2002 02:53 AM |
Idle RPMs? | willguidry | Normally Aspirated Powertrain | 12 | 03-28-2002 12:33 AM |
