07-13-2003, 01:34 AM | #1 |
Member#: 30670
Vehicle:1992 MR2 Turbo Sure miss my old WRX |
Has ANYBODY busted an STi 6spd?
Hoping this goes unanswered (holds breath)...
I'm scared to death for my tranny, it is by far the weak link in making serious power on this car. It just hurts that much more that there aren't any affordable tranny options out there and many of the expensive ones have busted too. Yesterday I had the pleasure of watching an STi peel all the wheels when we lined up at a stoplight. After a bit we got next to each other and at about 40mph he reved the hell out of it (could hear it bouncing off the limiter) and dumped the clutch in some gear (probably 3rd) and proceeded to peel all the tires again . I can feel the weakness of my tranny - it wouldn't survive one shift or launch like that. Are the STi's truly bulletproof? Someone please tell me if that guy's going to ruin his tranny or if the 6spd actually has that kind of abuse capability. If the 6spd is really that bulletproof I just may skip messing around with gears and just save up for a real gearbox. People with STi 6spds and experience with these trannys, let me know. Thanks
07-13-2003, 03:14 AM | #2 |
Street's closed, pizza boy
Member#: 17301
Vehicle:2018 Focus RS 2006 Evo #17 STU |
I'd be curious whether or not anyone has busted the RA gearset in the otherwise stock transmission...
-bd |
07-13-2003, 06:45 AM | #3 |
Member#: 13110
NESIC
Here's a thread in the northeast forum. Someone saw an STi sitting at a dealership. (just ignore the pissing match and jump to the last post for a little detail.)
http://forums.nasioc.com/forums/show...hreadid=389264 |
07-13-2003, 07:50 AM | #4 |
Member#: 213
Vehicle:2004 Mazda RX-8 Black |
omg Stiles.. what kind of jackass would already be abusing the **** out of his car like that.
I don't care how strong the 6 speed is, a jackass pulling **** like that in a new STi deserves to have gear fragments embedded in his back passage. |
07-13-2003, 09:48 PM | #5 |
Member#: 35585
Vehicle:RIP I'll always be The Ver8 Magistrate |
I know of 1 where the GB is making noises. It is going to the dealer to be evaluated and checked out. Problem with the GB yes. Broken, I do not know. Noises in the GB are not good though.
Rally cars break them sometimes. Never heard of "civilian" doing do. A 7500 clutch dump will break them if you do it enough though. I beleive if you did enough research, you would find it is 2nd gear that will break on those gearsets. Probably not find 1st broken. Just a hunch. Both break in the US model. |
07-13-2003, 11:12 PM | #6 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
I've abused mine alot over the last few months and it's never complained. I've been running in excess of 300hp for the whole time I've had it. (~270whp) and using the UTECs launch control. Glenn Wallace posted a press release from Pat Richard stating they were going back to the standard 6MT because of reliability problems using dogbox transmissions, in their rally car. You can break anything if you try hard enough.
07-14-2003, 04:17 AM | #7 | |
Member#: 7321
NESIC
Vehicle:.... 122 IggPoints Work... ahhh... so tired. |
07-14-2003, 09:35 AM | #8 | |
Member#: 17301
-bd |
07-14-2003, 09:48 AM | #9 |
Member#: 10507
Vehicle:'04 Ex STi Owner '97 4Runner |
If you take a look at this thread:
http://forums.nasioc.com/forums/show...hreadid=379446 You'll see that all the gears look pretty much the same size, except 1st is much wider - that should stand up to hard launches pretty good. Actually, 2/3 look a little wider than 4/5/6. If you're worried about munching 2nd, I would suggest a lightweight flywheel. A quick 1-2 shift from redline doesn't give the stock flywheel enough time to spin down for a rev match, so when you let the clutch out quick, all the energy from the flywheel slams into 2nd gear. A lightweight flywheel will spin down fast, and put less force on the gears when shifted abruptly. Kevin |
07-14-2003, 10:53 AM | #10 |
Member#: 447
Vehicle:1999 RSTI WRB |
there has been no well documented cases on the internet... but it has happened...
07-14-2003, 11:09 AM | #11 | |
Member#: 7321
NESIC
07-14-2003, 11:17 AM | #12 |
Member#: 17301
The Legacy probably wouldn't be close-ratio which is one of the things I'd want in any transmission I went to... that's a good thing to keep your eyes open for though, definitely.
-bd |
07-14-2003, 06:37 PM | #13 |
Member#: 15607
Vehicle:I'm not the type to make angry |
I broke my 6MT!
But it wasn't gear failure.
The plug for the clutch release fork pivot pin vibrated out and the pin cocked in the bellhousing and broke it. I took the cracked pieces and welded them back together and reinforced them and haven't had an issue since. -Dylan "If it's gonna break, I'll break it!" P.S.- I have an extra 6MT for sale |
07-14-2003, 06:59 PM | #14 |
Member#: 25956
Vehicle:2004 STi white/gold |
Is the broken one the one for sale
07-14-2003, 07:09 PM | #15 |
Member#: 15607
Nope, that one is still in my car running perfect.
The one I have for sale has less than 100 miles on it, it's mint. -Dylan |
07-14-2003, 07:54 PM | #16 |
Member#: 27963
Vehicle:2017 series.yellow |
07-15-2003, 02:19 AM | #17 | |
Member#: 30670
Honestly, it's not the shifting that concerns me. I shift very nicely, never powershift, and always ride the clutch out a tad longer than neccessary between 1-2 and 2-3. Certainly different than most trannys where you let the clutch out slowly only when starting in first and then every upshift is in/shift/out - I kinda miss that A friend of mine who's really into drag racing gave me some good advice that's really pertainent to the WRX: make the clutch the "fuse" in your drivetrain rather than the transmission; it's a hell of a lot cheaper that way. What I'm worried about isn't banging the tranny on a shift, what scares the piss out of me is when I hear about guys with only 270whp or so doing a nice, smooth, WOT pull in 3rd...and the gear just strips on them. That freaks me out, cause I don't know what I'd do if I was just cruising and punched it in 3rd and the tranny stripped, no matter how well I shifted it. Well, it sounds like the 6spd for all practical purposes will handle power. i caught up to that guy at a light again tonight (small world) and got to talk for a min or two. He had a WRX and said the tranny just feels so much beefier. This is probably the route to go then... I don't want a tranny I can dump the clutch at 6k on. I want a tranny that I will still shift nicely (maybe a little harder...) but won't just strip gears when I feed 350whp through it. Seems like the 6spd's the way to go. Any other ideas? |
07-15-2003, 01:12 PM | #18 | |
Member#: 15607
-Dylan |
Has anyone put an STi steering rack in a 2nd gen Legacy? | subysouth | Legacy Forum | 29 | 06-17-2020 12:10 AM |
Has Anyone Seen an STi for Sale on the Left Coast for 15k? | Stylistics18 | North West Impreza Club Forum -- NWIC | 9 | 03-09-2009 07:37 PM |
Has anyone had an STi 21mm pink RSB on a GC? | Xcasinonightzone | Brakes, Steering & Suspension | 2 | 08-10-2006 12:44 AM |
Has anyone broken an 02-03 STi v2 front lip? | djerickd | Interior & Exterior Modification | 5 | 10-13-2005 09:19 PM |
Has anyone installed an sti 6spd tranny? | Benjamin Tang | Transmission (AT/MT) & Driveline | 20 | 06-24-2002 09:43 PM |
