Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 08-17-2009, 06:04 PM   #1
CosworthUSA
NASIOC Manufacturer
Vendor Sales Rating: (0)
Member#: 220232
2008 STI
Red
Default 2008 Subaru STI Cosworth EC Pro ECU, Standalone
This isn't a brand new product, but relatively new. Please feel free to ask any questions.
If your local tuner doesn't tune the EC Pro, have them contact us to become set up as a dealer. We just ask that they have a dyno, wideband and are familiar with tuning as a whole. Also we provide free training with the purchase of your first EC Pro.
The class we hold includes more info on:
EC Pro ECU
Ec Pro Sales Program
EC Pro Dealer and Support network
Pi Caltool - Cosworth Edition explained in depth
Pectel Engine Offload Tool - COSEXT
Pi Toolbox - Cosworth Edition explained in depth
Application: 2008 + Subaru STI (North American Version)
A higher performance solution for engine management is available from the Cosworth ECPro professional motorsport ECU. Engineered in conjunction with our electronics team who develop the world renowned Pectel Control Systems range, the Cosworth ECPro features an OEM compatible harness connector and a full base calibration allowing you to go straight to the dyno without the workload of full ECU and vehicle configuration. Exclusively available from select Cosworth dealers. Available for North American Vehicles only.
  • On the 2008+ STI ECPro, the addition of a Pi Research lap beacon enables the advanced user to build track maps in the Pi Toolbox software (supplied with ECPro) for advanced analysis of driver and vehicle performance.
  • Designed for full OEM harness and system integration Plug and Perform. Base calibration supplied to run a stock engine. There is no need for replacement of OEM wiring harness or sensors. Makes use of OEM dash and diff controller
  • 56Mhz MPC565 processor. Higher performance timing accuracy and control. Ethernet comms for fast data offload and high quality data viewing on the PC.
  • Internal logging memory. Pre-configured logging channel configuration at optimum rates for performance and diagnostics analysis by your dealer. User can define specific logging configurations. 4MB on board internal memory and up to 2,000Hz of logging bandwidth is standard.
  • Knock monitoring and control. Advanced knock processing chip offers industry leading advanced knock signal filtration and signal processing. OEM MIL lamp indication of Detonation levels (with user defined levels based on RPM and Boost).
  • Calibration select. (e.g. Fuel save, Test, Race) Use of the OEM SI Drive switch for switchable performance selection of 3 alternate calibrations (calibration selectable for boost, fuelling, ignition,rev limit, ALS setting, VCAM target, Fly-By-Wire pedal mapping, and overrun fuelling cut-off individually selectable for Intelligent, Sports, and Sports-Sharp).
  • Pectel ALS (Anti Lag System) OEM switch (cruise control button) used for ALS mode select.
  • Analog inputs for external sensors. Additional pressure transducers, temperature sensors, and digital inputs can be wired into the EC Pro for logging additional engine parameters and/or additional control strategies. Access dependant on user level access (Customer, Advanced customer or ECPro Authorised Dealer).
  • Closed Loop Boost Control. Full closed loop or open loop boost control via PID parameters and solenoid duty cycle map. Closed loop boost levels are also selectable via calibration select (see above).
  • Standard Motorsport Design. Machined billet aluminum case and professional motorsports specification electronics.
  • OEM Narrow Band Supported. Can be disabled by user.
  • External Wideband Supported. Compatible with all wideband units with 0-5v analog output.
  • Internal Wideband Supported. WBL kit - Requires Cosworth by Pectel NTK sensor, requires 3 extra populations and 2 pin relocating. Blank pins on OEM harness populating.
  • Variable CAM. Full pre-configured dual AVCS camshaft support.
  • External Comms Support. Optional Motorsport dash and center differential controller.
  • Designed for Racing - No OBDII, Motorsport use only. Ready to dyno tune for your engine specifications
  • Thermocouple Support. TC Kit can be fitted and wired directly to ECU for monitoring or control strategy e.g. exhaust over temp enrichment, auto ALS disable (Uses 2 spare pins on ECPro)
Thank you for looking!
__________________
Cosworth USA
3031 Fujita Street
Torrrance, CA 90505
310-534-1390
CosworthUSA is offline   Reply With Quote
More Hot Topics on NASIOC...
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:14 PM.
