06-11-2001, 10:51 PM | #1 |
Member#: 3198
Vehicle:2005 GT LTD Wagon Garnet Red |
LTD sound insulation
I know there is hardly any dampening material in the RS, does anyone know how much dampening material there is on the floor of the MY97 Legacy interior?
My only real complaint with my car is the highway noise. I've dynamatted the cargo floor, which helped some, and I'm debating about pulling out the seats and going to town on the interior floor. Anyone done this? How big a pain was it to get the carpet up?
06-12-2001, 06:27 AM | #2 |
Member#: 5030
Vehicle:1999 Legacy 2.5GT 19 Audi RS3, 13 Armada |
I'm interested in finding out about this as well. My tires are noisy to begin with so a different set will cure that. But I would actually like to be able to roll up the windows and barely hear the exhaust also. Not that I don't like the sound of my exhaust but it gets annoying when your on the highway for more than an hour.
What can I do to help this? Brad |
06-13-2001, 09:31 AM | #3 |
Member#: 1176
Vehicle:2012 MB E550 4M 2015 P85D |
I have only used Extreme Dynamat in the tunk and wing and still get vibration from the center LED of the wing...any suggestions??? As for interior noise...I keep my windows down and sound pumping all 700+ watts baby!!! So I don't hear jack while driving, but at a light I hear my GD LED rattle just a bit that ticks me off!
CRAZY KEN |
06-13-2001, 10:01 AM | #4 |
Member#: 3198
You should be able to make a foam sleeve for the light housing which would eliminate the vibration.
06-13-2001, 10:58 AM | #5 |
Member#: 2697
Vehicle:2000 Celica GT-S Spectra Blue |
Ah, the infamous wing rattling. I had a helluva time with that one when I had my sub. After carefully dynamatting the whole led, just to see if it would stop the rattle, I finally came to the conclusion that the insessant rattling was from the two walls of the hollow wing flexing. Try taking out the light completely and playing the stereo. Is the rattling still present? If it is, the only thing I could suggest is using some type of expandable foam and fill the inside of the wing. Just be careful that you don't overfill as it might damage/deform the wing.
Jason |
06-13-2001, 10:25 PM | #6 |
Member#: 1361
Vehicle:1999 Legacy GT Ltd. 2006 Rav4 Sport Silvarrr |
when i had two 10" subs in my GT most of the noise came from the License plate rattling and the wing LEDs. I dynomatted my plate and dynomatted the LEDs. I cut a long slimpiece of dynomat and covered the top of the LEDs. That cured like 90% of the majorly annoying rattling. The rest a little dynomat spray couldn't cure.
-chrisC Edit: oh BTW: i dunno about the regular GT's. My GT Ltd has pieces of dynomatt like stuff already in the trunk well. I Striped the trunk for an auto-x and noticed that pieces were already stuck in a whole bunch of places. [ June 13, 2001: Message edited by: silverSurfer ] |
06-13-2001, 11:11 PM | #7 |
Member#: 6035
NWIC
Vehicle:05 92-X Saabaru 87 VW Westfalia |
I've dynamated the LED in my GT's wing, and it still rattles like mad. I too think it's the wing itself flexing... if I put upward pressure on the bottome center portion of the wing... the rattle is eliminated. Pretty sure it's not the LED. Next is the dynamat extreeme trunk kit. I've read that expanding foam shot into the wing is a BAD thing?
Bottom line: If it sounds great inside, that's all that matters. I have noticed my rear deck material making noise during heavy hitting bass... vibrating against the rear window. Gonna remove and insulate... anyone else run into that one? |
06-14-2001, 05:22 AM | #8 |
Member#: 768
Vehicle:OB, volt, 911, ram 1500, 1098s, m620 |
you don't need to use dynamat to get rid of rattling. it's more for vibration control. my license plate was rattling against the metal frame and the frame was rattling against the car. i shot a little bit of silicone caulk stuff and let it dry and no more rattles.
roger |
What glue to attach sound insulation? | Rich10 | Car Audio, Video & Security | 3 | 06-13-2004 03:08 PM |
SOund insulation | Sir_Xenon | Alaskan Impreza Club Forum -- AKIC | 13 | 12-06-2003 05:15 PM |
Carpet Padding as Sound Insulation? | Rich10 | Car Audio, Video & Security | 8 | 03-26-2003 01:35 PM |
Is there any light compound for sound insulating? | tonytiger | Car Audio, Video & Security | 13 | 05-03-2002 07:15 PM |
Sound insulation | Subietonic | General Community | 7 | 12-13-2001 11:54 AM |
