Welcome to the North American Subaru Impreza Owners Club Friday April 18, 2014
Old 10-08-2001, 09:12 PM   #1
adamsrs
Member#: 3768
Default I have compressor surge! Please help!!!
I got a Blitz Super Sound Blow off valve and it works great!....for 5 minutes. After five minutes it delays before it opens and sends a shockwave into my turbo. Then it opens? Why is it doing this? Where are you guy drawing your vaccum through? I have a Front mount intercooler if it makes any difference? Please help me, I am taking to a local shop to have it looked at but Any help is greatly appreciated!
adamsrs
www.unnatural.org
adamsrs is offline   Reply With Quote
Old 10-08-2001, 09:18 PM   #2
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
you definitely want to make sure that if you have the stock MAP, then you have a couple one-way valves in the vacuum line to make sure your MAP is getting no more than negative to zero pressure. If the MAP senses your boost, it'll send good engine management clear out the window. That's just one thing to check though, sounds like you're haveing more serious problems than that . . .
aussiebrydon is offline   Reply With Quote
Old 10-08-2001, 11:10 PM   #3
kaos200
Member#: 2692
aussiebrydon he's talking about something totally different
Adam where is the BOV, and does it have an adjustment feature?
kaos200 is offline   Reply With Quote
Old 10-09-2001, 03:38 AM   #4
adamsrs
Member#: 3768
YOu can see the location of my BOV. Yes there is an adjustment feature, but it seems not to be working right! Any ideas!
adamsrs
Old 10-09-2001, 04:16 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you are pulling vacuum of the acutal intake manifold right?? I can't tell from the picture. Make sure the hose doesn't have a leak somewhere that's not allowing the valve to pop-off,. Otherwise i am not sure what to tell ya adam.
Jeremy
Old 10-09-2001, 11:40 AM   #6
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
maybe you need a higher flowing BOV? IIRC from the SCC articles with their FMIC they had to go to larger and larger BOV's to prevent surge like you are getting. Nice install by the way!
STiShawn is offline   Reply With Quote
Old 10-09-2001, 12:55 PM   #7
Aphex
Member#: 146
'05 Legacy GT
My BOV does the same thing, I have an Apex'i twin chamber BOV. I'm only running 5psi of boost, it's starting to make me upset, because I adjust it, and it leaks boost, but it still gets compressor surge, I think I'm gonna have to trade out for a different BOV. I don't think the apex does that good for low boost applications, even though it says it does.
eli
Aphex is offline   Reply With Quote
Old 10-09-2001, 04:10 PM   #8
adamsrs
Member#: 3768
I am getting my vacuum directly in front of the throttle body, you can see in the picture. I am taking it to be looked at today. I just dont understand because all of these hondas are running five punds of boost and they are using the same type of BOV and they get no surge! WHY?????????!!!!!!!!!!!!!!!!!!?????????
Old 10-10-2001, 02:28 AM   #9
adamsrs
Member#: 3768
bump
Old 10-10-2001, 02:55 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
adam-
Do you mean behind the throttle plate(from intake manifold)??
Or actually IN FRONT OF the throttle plate(in air intake system)??
jeremy
Old 10-10-2001, 04:07 AM   #11
adamsrs
Member#: 3768
I mean if you are looking at the engine while standing in front of the car it is "in front of" the throttle plate. Like closer to the front bumper. I am talking about physical location not location in relation to the throttle bodyh and intake plenum!
adamsrs
Old 10-10-2001, 04:32 AM   #12
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Can't help ya, but you've got a nice setup...mind PM'ing me the specs on the kit and where you got it done? Thanks...that looks awesome..just what I'll do if I turbo my car again.
Keiho is offline   Reply With Quote
Old 10-10-2001, 04:57 AM   #13
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
It could be a defective BOV??
ive heard that blitz bov's have a tendency to get sticky..
maybe try a diff one..
Orbiter is offline   Reply With Quote
Old 10-10-2001, 11:42 AM   #14
zaidallas
Member#: 4106
Badass , that looks nice. while I don't have anything to add about the surge other than what was mentioned , I'd like to know if that IC was a kit and wha bumper that is.
zaidoun
zaidallas is offline   Reply With Quote
Old 10-10-2001, 12:13 PM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
adam-
it sounds like your BOV is bad.....never heard anything about BLITZ BOV's but it seems as if other people have. Got a friend who's you could swap in real easy by any chance??
Jeremy
Old 10-10-2001, 05:11 PM   #16
adamsrs
Member#: 3768
The intercooler is from a Greddy Integra Drag Kit. The entire piping is a custom setup by Turbo Technologies in Tacoma, WA.
adamsrs
Old 10-10-2001, 05:20 PM   #17
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
That's the same BOV that i have and have not had any problems with it. You might have a defective BOV.
Eric
Eric SS is offline   Reply With Quote
random air compressor question...please help! djelly84 Built Motor Discussion 17 09-07-2009 02:36 AM
RPM surge??? please help mchrenen Factory 2.0L Turbo Powertrain 21 12-12-2007 10:00 PM
Compressor surge please help.... subpreza Factory 2.5L Turbo Powertrain 2 10-06-2007 09:01 PM
TD05 installed, now I have compressor surge imposter Pre-2002 Factory Turbo Powertrain 4 04-23-2004 02:57 PM
Acceleration surges!! Please help IMPREZIV Factory 2.0L Turbo Powertrain 7 07-15-2001 12:44 PM
