Old 02-23-2000, 01:12 PM   #1
nd4spd
Member#: 948
Question '91-'94 Legacy Turbo, intercooled??
Hi, I'm new to this board, I'm actually considering buying a Legacy Turbo and well, I have a question. On the '91-'94 Legacy Turbos is there an intercooler??and if not, whats the hood scoop for??also, whats it cost to get an intercooler for this car? Thanks for the help
nd4spd is offline   Reply With Quote
Old 02-23-2000, 01:43 PM   #2
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post
nd, no, they never came with an intercooler(unfortunately). You could probably get a custom spearco set-up for around a grand, give or take a bit. The 93-96 WRX intercoolers can be made to work with a little bit of modifications. These could be had for under $500 for the intercooler and pipe. You can probably get it alot cheaper if you find an individual that isn't using his anymore( Alot of WRX guys upgrade them with aftermarket units). The liquid-to-air intercoolers that came on the 1st gen. turbo Legacys everywhere else in the world would probably work but it's alot more complex and expensive.
I use the early WRX intercooler and at WOT in 4th gear, the intake temps dropped around 30-40 degress, so it is surely better then nothing and will work fine for me as I will probably never go above 12-13psi. Hope this helps.
Shik is offline   Reply With Quote
Old 02-23-2000, 04:54 PM   #3
PeteH
Member#: 431
Post
To answer you hood scoop question, on the 'overseas' cars the intercooler is mounted directly under the scoop. On the US spec Turbo Legacy's the scoop has a duct mounted to the bottom of it that channels the air to what is commonly known as the 'stovepipe'. This 'stovepipe' is nothing more than ductwork that surrounds the turbo charger to help keep the temps down. I am sure it helps somewhat but it will not replace the intercooler. BTW, the Legacy turbo has a water-cooled center section, in fact, I do not personally know of any turbo failures with this model.
PeteH is offline   Reply With Quote
WTB: '91-'94 Legacy Turbo Sedan (anywhere in southwest) shemoves SWIC Private Classifieds 6 06-14-2007 11:51 AM
Opinion on '91 JDM Legacy turbo EJ20 Speedwagon Normally Aspirated with bolt-on Forced Induction Powertrain 17 06-23-2003 02:47 PM
A '94 Legacy Turbo Need A Good Foster Home LordBass New England Impreza Club Forum -- NESIC 4 09-24-2002 04:05 PM
'94 Legacy turbo FS...maybe Scoobyslack1 Legacy Forum 12 11-21-2001 11:11 AM
Info on '91-'93 Legacy Turbo Dr. Spud Funk Legacy Forum 3 03-23-2001 02:52 PM
