Old 02-21-2000, 08:30 AM   #1
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Unhappy Legacy Check Engine Light
Hi everyone,
I have a 90 Legacy with a check engine light on - only when warm and restarting it usually clears it. Dealer thinks to change all the ignition module$$. Does anyone here know it this is true and know of a cheaper source?
Thanks
aross - newbie
aross is offline   Reply With Quote
Old 02-21-2000, 08:47 AM   #2
Miller3339
Member#: 299
Post
check your O-2 sensor first.
Miller3339 is offline   Reply With Quote
Old 02-21-2000, 08:50 AM   #3
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Question
Miller,
Where should I get it from.. Dealer said it was not that piece!!
Aross
Old 02-21-2000, 09:33 AM   #4
Miller3339
Member#: 299
Post
did he check it?? I know that the Check light is fed from a few different sources.
Jamie, do you have Mike at Smart services E-mail??
Miller
Old 02-21-2000, 10:36 AM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
aross -
go to http://www.smartservice4u.com
email Mike - the owner/operator with your problem and ask him for a diagnosis... he will not mis-lead u and will know if the others are...
good luck!!
Old 02-21-2000, 05:47 PM   #6
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post
aross, what exactly is the car doing differently, if anything? The main causes for "check engine" lights on the early Legacys were water temp sensors and cpc solenoids, neither being too big of a deal. It could be many other things but these are the most common.
What are these "igniton modules" this guy is talking about? The only things I could thing of are the coil pack, igniter, and/or crank and cam angle sensors. chances are you would surely notice driveability problems with the first two and the second two, the car is unlikely to start( sometimes it will, sometimes it won't).
I would definately check around before you let this cat go changing things...at your expense!
Shik is offline   Reply With Quote
Old 02-21-2000, 06:04 PM   #7
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Thumbs down
Shik,
That is what I thought. Drivablity is not changed much if I continue to drive with the Check Engine light on.
I was told that it may not start or stall if I do not replace the components.
Can anyone recommend a repair location in the Toronto Area!!
Aross
Old 02-21-2000, 11:01 PM   #8
Ben
Member#: 423
2002 WRX wagon
Post
Aross, try Downtown Subaru at 601 Easten Ave. Tell Conway that Ben Send you there and he may give you discount on those repair or check!!
Ben is offline   Reply With Quote
Old 02-22-2000, 06:14 AM   #9
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Post
Usually the O2 sensor.
-mike
Paisan is offline   Reply With Quote
Old 02-22-2000, 04:25 PM   #10
AlpineSport
Member#: 736
Post
Had same symptoms on 94 Legacy...,didn't come on 'till warm. Turned out to be dead anti-knock sensor. Could tell because car "dogged" it pulling long uphills, evidently timing retards when knock sensor malfunctions??? May or may not help. Good luck!
AlpineSport is offline   Reply With Quote
Old 02-23-2000, 06:09 AM   #11
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Smile
Took it to Downtown Subaru as per Ben's recommendation, Conway replaced the CPC valve?? No check engine light!!!!
Gave discount and great service.
Old 02-23-2000, 08:36 AM   #12
Submerk
Member#: 116
Post
I think Shink is right. Do you have aftermarket air intake? Go to the shop that has computer diagnostic. It is better than guessing. I had the same problem, so I went to the dealer. They told me to change the water temp and throttle position sensor. And the problem is gone.
Submerk is offline   Reply With Quote
Old 02-23-2000, 09:43 AM   #13
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
Post
DO ME A FAVOR--GO BACK TO THE DEALER AND
GET THE CODE FROM THE SELECT MONITOR-DEALER
SCAN TOOL-AND I WILL TELL YOU WHAT IT IS.
THERE IS NO CODE IN THAT SYSTEM FOR A
IGNITION MODULE.
DAVE
M.S.P.T
PerformanceAutoSolutions is offline   Reply With Quote
Old 02-23-2000, 01:53 PM   #14
Shik
Member#: 132
2015 WRX 6spd CWP
Post
aross, glad to hear you got it straightened out. Just for the record, I have yet to see a bad CPC solenoid cause the car to stall or not start( not to say it can't ever happen but...). Just to be safe, I'd stay away from that first guy you took it to. Thank goodness for the Legacy Forum!
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
98 legacy 5 speed - flashing check engine light after ignition... Box This Electrical & Lighting 4 10-12-2009 10:16 PM
91 Legacy, Check engine light question submw80 Legacy Forum 4 01-01-2009 11:43 PM
1994 Subaru Legacy Check Engine Light and Fuel Odor Inside Car Modog100 Service & Maintenance 5 04-01-2006 10:32 AM
Check Engine light (95 Legacy Sedan) JamiePasson Legacy Forum 13 04-04-2004 02:58 PM
