Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Closed Thread
Old 05-09-2006, 01:49 AM   #1
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Question Flex Fuel Subaru?
Anybody heard ANY rumours on when or if Subaru will start making US cars that can run on higher ethanol blends. Turbo cars work well on richer ethanol blends as the higher octane can be taken advantage of with more timing advance. But the ECU has to be optimized to recognixe the fuel and not throw a CEL for overly lean mixtures due to the extra oxygen in the alchol. A reflash or reprogrammed ECU ought to be able to deal with it, as it's likely the fuel system is ethanol tolerant since it's certified for E10.
Just wondering - since it will also let Subaru get a boost in the CAFE ratings, which it needs.
Alan is offline
Old 05-09-2006, 03:05 AM   #2
silentbob343
Member#: 57307
silentbob343 is offline
Old 01-01-2011, 03:16 PM   #3
wrxkyle
Member#: 199635
02-4 rSTI
any current chatter on whether SUBARU will be releaseing flex fuel vehicles? aftermarket tunes are not flex fuel, you can run either E or gas but you can't indescriminantly mix between the two like true FFV's can.
it would be great to see cause then we would have E85 sensors and ecu's that could be tuned for varying mixtures.
wrxkyle is offline
Old 01-01-2011, 04:37 PM   #4
arghx7
Member#: 232940
It's hard to say. There's an ethanol backlash brewing in the US. That makes it less likely. But yes you are right, if you look at how the GM flex fuel vehicles work there are correction tables based on % ethanol in the tank.
arghx7 is offline
Old 01-01-2011, 06:33 PM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
My closest gas station has E85 and its 20 cents cheaper than any other fuel right now... I'd kill to be able to use it!
Kostamojen is offline
Old 01-01-2011, 07:58 PM   #6
arghx7
Member#: 232940
of course it's 20 cents cheaper. the federal government subsidizes it.
arghx7 is offline
Old 01-01-2011, 08:25 PM   #7
wrxsubaru
Member#: 65133
It is cheaper, but you also get worse gas mileage. E85 has much less energy per gallon than traditional unleaded.
wrxsubaru is offline
Closed Thread
SAAB's Entire Range Goes Flex-Fuel (Europe) ~ 2007 Geneva Motor Show NYCshopper Non-Subaru News & Rumors 1 03-02-2007 03:14 AM
Vishnu Flex-Fuel Lancer Evolution @ 2006 LA Auto Show NYCshopper Non-Subaru News & Rumors 0 11-30-2006 02:27 PM
Tahoe hybrid also flex-fuel capable. scott_gunn Non-Subaru News & Rumors 0 11-27-2006 01:19 PM
Toyota plans flex-fuel versions of Tundra, said a Japanese newspaper NYCshopper Non-Subaru News & Rumors 0 11-09-2006 02:25 PM
Fullflex flex fuel system jcp7620 Engine Management & Tuning 6 09-14-2006 10:32 AM
