Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-09-2006, 02:11 PM   #1
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
Default unusual knock issue - built motor
yeah, i just built this motor (http://forums.nasioc.com/forums/showthread.php?t=993446) and i;m using the same utec and ecu from before the build. also, the map is an 1820/fmic/650 tune from eons ago (as before, i used this prebuild). the engine is quite loud...mainly piston slap.
no, the utec does not like the noise. yes, the CEL flashes indicating knock AND my logs all read craziness. any thoughts? piston slap does not = knock, correct? if that's true, is the crazy slapping loudness invoking a false CEL or are my crazy logs showing me that my new build WILL NOT (or atleast doesn't want to) run on this map?
Lennon is offline   Reply With Quote
Old 05-10-2006, 07:38 AM   #2
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
cmon guys, i know you know stuff...i didn't even get a "go get it tuned, d0rk"
Old 05-10-2006, 10:14 AM   #3
AaronWRX
Member#: 7194
2011 997.2 Turbo
what's the knock count? 1? Some people will tell the utec to ingnore (not pull timing) for a knock count of 1.
AaronWRX is offline   Reply With Quote
Old 05-10-2006, 02:12 PM   #4
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
I know in my own personal case with aftermarket rods and pistons and a closed deck, it tends to have a bit more vibration than a standard ej205, so I spoke to axis about it since they originally put this together to see what they recommended and what they found with tuning. as for a 205 w/ forged components, i would be unsure of what to say, I would first say to post a log showing what kind of knock counts your having.
I know other tuners out there have built the 205 blocks and probably have opinions of their own for knock sensitivity adjustments, like say Phil from element.
otherwise, maybe some det can setup and a way to record it and look at it with say gram light pro to see if the motors knocking as it can be heard to tell if you're actually hearing knock.
SBW is offline   Reply With Quote
Old 05-10-2006, 02:45 PM   #5
TurbojonLS
Member#: 38772
2 Cars, No Bling
Does the noise go away once the engine warms up? Isn't piston slap only a factor on startup, then goes away once things warm up?
TurbojonLS is offline   Reply With Quote
Old 05-10-2006, 03:26 PM   #6
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
I have a built motor and I have my knock threshold set to "2" and my knock sensitivities are knocked down quite a bit. My 1 counts are just false knock, so I ignore them.
SloRice is offline   Reply With Quote
Old 05-10-2006, 04:45 PM   #7
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
usually yes, sometimes no...i've had a knock count of five and another of four
no, not entirely, the slap only gets quieter as it warms up. it does not silence completely. and it's not necesarily the same volume consistantly either (though rythmic), it seems to depend on what rpm / gear you're at / in. anyway, thanks for the input...this will be investigated further.
i still plan to post up some logs for your review, but you need to know that they are completely whacked out
Old 05-10-2006, 04:47 PM   #8
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
does the cel still flash at you OR do the adjustments in knock sensitivity effect that?
Old 05-11-2006, 02:00 PM   #9
SloRice
Member#: 44351
2004 Mitsubishi Evo
The cel still flashes when I have knock counts of 1. I pretty much ignore and say if it sees 2 or more counts, it will retard timing.
ATTN Tuners, please help!!! built motor/35r tunning issues JT's06sti AccessPort 6 05-09-2010 03:07 PM
Built motor.. first startup knock. wrxG Built Motor Discussion 39 03-18-2008 02:23 AM
Built Motor completed, possible Turbo Issue paintbing Built Motor Discussion 1 01-14-2008 01:18 AM
Hopefully you all can help... built engine knock issues with AP Bankheist AccessPort 4 03-26-2007 02:21 PM
built motor knock sensitivity dukeduster Built Motor Discussion 5 03-13-2007 12:39 AM
