Old 05-09-2006, 03:00 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default 1993 leg 2.2 wagon is getting horrible MPG
I bought the car used around 8 months ago. At the time, the guy told me that after a hot restart, the CEL would usually come on. I didn't think anything of it, figuring it was just a bad O2 sensor.
I am now getting 23-25 mpg...keep in mind 90% of that is freeway. I do drive in the wind, and in a hilly area, but that is horrible.
I went to Shucks today to have them pull the codes, but they couldn't find an appropriate OBD plug (is this car obd 2? seems pretty old to be...).
Anyone have any clue?
Main symptoms after hot restart:
-Idle is surgy, usually around 1200-1700.
-Super touchy gas pedal, it makes me look like a total noob when people are in the car and I shift.
-Horrible gas mileage
I've cleaned the air cleaner like 3 months ago, it might need it again, or perhaps a new one.
Anyone have any input?
Thanks
Alex
Old 05-09-2006, 03:38 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
95+ Legacy is OBD II. You can check the cel yourself. Here is a good writeup from Legacy777 http://www.surrealmirage.com/subaru/engine.html
subiekid is offline   Reply With Quote
Old 05-09-2006, 04:06 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Im an idiot, thanks Dirty D
Old 05-09-2006, 04:33 PM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Jesus 5 codes?
I think I'm going to reset the ECU and drive it for a while, because this is nuts.
Crank angle sensor
Ignition Switch
Knock Sensor <i can see its broken, physically!>
Air control valve
Canister Purge Solenoid
The only ones I think I need to fix are knock, air control, and the crank angle sensor.
Any inputs?
Old 05-09-2006, 06:59 PM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
ouch.
Wiscon_Mark is offline   Reply With Quote
Old 05-09-2006, 07:31 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
lol, any others ?
Old 05-09-2006, 08:14 PM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Well, I was thinking...sometimes when one thing goes wrong, it gets the ECU to think other stuff is wrong, even if it's not.
Try replacing the knock sensors first, then see how it pans out.
Old 05-09-2006, 08:15 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Roger
thnx
Old 05-09-2006, 08:58 PM   #9
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
The knock sensor is pretty important. When it's broken like that, your car could be very conservative with timing, and run a bit richer than it normally would to be "safe". That can lead to poorer mileage.
MCarp22 is offline   Reply With Quote
Old 05-09-2006, 09:54 PM   #10
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Do you guys know if any EJ series knock sensor will work?
Alex
Old 05-10-2006, 06:11 PM   #11
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I would guess so. Any EJ22 sensor should.
horrible mpg question Brepic06 Service & Maintenance 9 11-26-2007 10:58 AM
my 2004 wrx wagon has utec .. i am getting 10~12 mpg.... imprezaBlue Engine Management & Tuning 4 12-28-2005 05:47 PM
My car is getting Horrible Gas milage - WHY? kusok Engine Management & Tuning 11 03-23-2005 11:33 PM
My car is getting horrible gas milage - why? kusok Service & Maintenance 1 03-21-2005 05:22 PM
Anybody getting >17 mpg. in Legacy Touring Wagon? ort5 Legacy Forum 13 02-17-2001 12:35 AM
