Old 05-10-2006, 03:53 PM   #1
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Default VF22 and lag: Photographic evidence of the myth.
I think one of the biggest questions on this forum is "What turbo should I run". I've asked myself that question countless times and ended up running a VF22, mainly because:
1- It was very cheap (less than $400 shipped to my doorstep)
and
2- It is the largest turbo my injectors will support. I would definitely need bigger injectors to run a bigger turbo. A bigger turbo would also cost a lot more. If I get bigger injectors, I would need a standalone ECU (my V5 JDM ECU is not reflashable) to control them. If I got a standalone I would need to tune it on a dyno... Plus anything bigger than a VF22 and I would also probably want a FMIC to make the most of it... FMIC + Turbo + Injectors + ECU + Dyno Tune = close to 3 grand. No thanks
I chose the VF22 looking for power, but most of what I read on this forum pointed to it being a very laggy turbo, which I really didn't want since I autocross all the time.
So, how laggy is it?
Here it is:
1 atmosphere of boost (read at the center of the intake manifold) at just shy of 3200RPMs. This on 5th gear, level road (slight decline actually).
On a untuned JDM V5 Type RA ECU.
The setup:
JDM V8 shortblock, JDM V5 Type RA heads, mated with stock STI head gaskets and ARP head studs.
Ported and polished intake manifold, up pipe, turbocharger turbine inlet, turbocharger compressor inlet and outlet, intercooler Y pipe elbows, throttle body, intake manifold.
Wrapped headers, up pipe, down pipe. Ceramic coated turbo hot side
Perrin turbo inlet, USDM STI intercooler.
Here is a dyno of the car ***UNTUNED***:
After a ECUTEK reflash the car gained 30AWHP / 30AWTQ and peak torque now happens 580rpms sooner in the power band. Tuning really is everything on these cars... Still, 288AWHP on a stock ecu map isn't too shabby either
I figured this might be of some use to some of you.
Now, my question... At what RPMs do you guys see 1ATM / BAR of boost and what turbos are you running?
powerlabs is offline   Reply With Quote
Old 05-10-2006, 04:09 PM   #2
Bolster
Member#: 22290
2002 WRB WRX Wagon
I'm pretty sure I had that much boost at about the same revs, if not a bit sooner when I was running a VF22 on my stock internals EJ205.
Bolster is offline   Reply With Quote
Old 05-10-2006, 06:32 PM   #3
vlady
Member#: 77997
dirty blue
This really doesn't mean anything. You have better flowing heads than most and everything coated/ported.
For reference, I get full boost (18psi) with a VF34, borla header (coated from borla) at or below that rpm.
vlady is offline   Reply With Quote
Old 05-10-2006, 06:50 PM   #4
richde
Member#: 79498
2013 XV Silver Slug
'84 Porsche 911-sorta red
5th gear is a good way to disprove this myth?
Try a 3rd gear run.
Isn't that the one with the turbine erosion?
richde is offline   Reply With Quote
Old 05-10-2006, 06:53 PM   #5
powerlabs
Member#: 45790
SUPERCHARGED
Try a 3rd gear run.
Nope, its a new one.
I will try a 3rd gear run and report back :P
Old 05-10-2006, 07:18 PM   #6
DFL2.5RS
Member#: 73228
2015 White STI
2013 WRX, 2003 Rally car
I have full boost at 2250rpms but that's with a TD04
DFL2.5RS is offline   Reply With Quote
Old 05-10-2006, 07:20 PM   #7
benw
Member#: 103320
2005 wingless
aspen white
nailing the gas in 3rd gear at 2600 RPM on my VF34 I make 16.8 PSI by 3600 RPM.
5th gear spools it very close to 3,000.
benw is offline   Reply With Quote
Old 05-10-2006, 07:21 PM   #8
powerlabs
Member#: 45790
SUPERCHARGED
TDO4? One of these?:
Old 05-10-2006, 07:24 PM   #9
DFL2.5RS
Member#: 73228
2015 White STI
haha... BLAST!! you found out about my custom tinier than stock turbo swap!!!! 8psi at idle :P
Old 05-10-2006, 07:24 PM   #10
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
ha ha....
anthonyrb98 is offline   Reply With Quote
Old 05-10-2006, 07:26 PM   #11
powerlabs
Member#: 45790
SUPERCHARGED
Full boost @900RPMs
Compressor overspins and flies apart @4000
Old 05-10-2006, 07:32 PM   #12
DFL2.5RS
Member#: 73228
2015 White STI
or your compressor wheel can just fly apart because your turbo has FOD and you refuse to admit it.... I believe that's one point for me :P
Old 05-10-2006, 08:56 PM   #13
fireball_jones
Member#: 67536
00 AW GM6
And a bunch of parts
I'm sure most people would have believed you without taking a picture at 70mph on a residential street .
fireball_jones is offline   Reply With Quote
Old 05-10-2006, 10:06 PM   #14
powerlabs
Member#: 45790
SUPERCHARGED
Erm... Caugh... That's not a residential street
Nah, seriously, the speed limit on that road is 55; I live there, so it can't be that residential
Old 05-10-2006, 10:43 PM   #15
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
i always noted spoolup in 4th gear... went full throttle at 2250-2500 and then noted when boost shot up to max. seems that everyone does it differently, and it certainly varies by gear.
i wouldnt call the vf22 a laggy turbo, i'd call it a medium turbo... but its all relative... some hop into a wrx and think the stock turbo has horrible lag and they cant drive it and want their V8 back... some are happy all day long with a GT35R.
TROLL is offline   Reply With Quote
Old 05-10-2006, 11:28 PM   #16
powerlabs
Member#: 45790
SUPERCHARGED
Originally Posted by Wrinkleboi
i always noted spoolup in 4th gear... went full throttle at 2250-2500 and then noted when boost shot up to max. seems that everyone does it differently, and it certainly varies by gear..
Which is exactly why I took a video of my boost gauge and tach and froze the exact frame where it hit 1ATM... Its just too easy to throw in some wishful thinking when you're eyeballing the gauge
I definitely wish I had less lag. The VF22 definitely lags. But it doesn't lag any more than my old VF29 did, and that is both a smaller turbo and one with a titanium turbine (less rotational mass, should spool up even faster). That was the whole point of this post.
Now, if I could get a turbo that would make more power, and lag less... I'd be sold
OK, and not cost a fortune. I imagine you could accomplish more power and less lag with a twin scroll setup for a mere... Say... 2-3thousand dollars?
Old 05-11-2006, 12:31 AM   #17
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
Super 16G is your answer Flows 580 cfm and still spools like a VF30 (usually, depending on tune and supporting mods of course)
sounds like our goals are similar, only difference is I've already got one of these sitting in my bedroom
Old 05-11-2006, 12:41 AM   #18
powerlabs
Member#: 45790
SUPERCHARGED
I think everyone's goals are the same:
"I want more power than anything else on the road, with NO LAG"
I've heard great things about the Super 16G. 580cfm? Wow! That's some serious power there... Maybe some day.
I find the "spools like a VF30" hard to believe though. You really think it would hit full boost at or below 3000RPM?
Old 05-11-2006, 12:44 AM   #19
justboosted02
Member#: 78285
2003 EVO
red and black
on my 18g ive hit full boost (1.5bar) at 3100 in 5th with a fmic and headers before. usually in 3rd i hit full boost at 3.7k
justboosted02 is offline   Reply With Quote
Old 05-11-2006, 12:53 AM   #20
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
true true... we all want a completely lagless 600 whp...
as far as spoolup of the Super 16G... I wouldnt say it hits 1 bar at or below 3000 but I didnt think a VF30 did either. I would say a tuned Super 16G with supporting mods should be at 1 bar (on its way to 1.5) at about 3200-3400 MAX, like I said I gauge this in 4th gear.
The way I figure, my untuned VF34 probably hits full boost at exactly the same time as the Super 16G will with a custom tune, only difference is bigger turbo plus tune will probably equate to ~60 more whp than I have currently on my VF34 and base map.
although the wheels on the 16G and 18G are larger and flow more, the mitsu wheel design is very efficient and by matching compressor and exhaust wheels carefully they can achieve earlier spool than other turbo designs.
Old 05-11-2006, 12:56 AM   #21
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
how hard would it be for you to switch to a US WRX ecu so you can tune with enginuity or openecu with the openport cable?
They sell modified injectors top or sidefeed at really good prices.
http://www.deatschwerks.com/subaru.htm
how about external wastegate setup?
jay
illmatic is offline   Reply With Quote
Old 05-11-2006, 01:17 AM   #22
powerlabs
Member#: 45790
SUPERCHARGED
External wastegate? At 300AWHP? Not needed I don't think.
jay
It would be doable, but I don't think it would be very straight forward... There is a lot missing on a JDM car that the WRX ECU would want; fuel tank pressure sensors, a second O2, OBD2 port, etc... I would need a us harness and it would probably take almost as much time as it took for me to do the swap in the first place.
Plus, its all extra money, and right now I need tires and a new tranny more than I need extra horsepower.
Old 05-11-2006, 01:54 AM   #23
powerlabs
Member#: 45790
SUPERCHARGED
Old 05-11-2006, 03:04 AM   #24
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
looks like it kicks in at 3300-3500, thats a vf22? if so im running a similar setup, 97 jdm wrx motor with stock vf22...will have my car back with the front clip parts installed soon from stock 2.5NA...cant wait to see how it feels, i drove a civic hatchback before with turbo and its quick with 261whp and a gutted rear ;] untuned my civic should beat it on the highway...getting an aem ems soon though ;]
2.5rsTurbo is offline   Reply With Quote
Old 05-11-2006, 03:37 AM   #25
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Most people only think that a VF22 is "laggy" because most people think "its a big turbo". Its still a tiny turbo and it isn't laggy at all. Your picture also presents one flaw - we know that the tachs are often not accurate and sometimes off by as much as 300 rpm.
Code:
 2876, -8.1,1.3,  0, 00,   00,  W/B ,+11.7,   4.5,ECU. , -7.2,ECU.  ,1.2, 15.94
 2858,-11.0,1.5,  1, 00,   00,  W/B , +4.4,   6.2,ECU. , -7.2,ECU.  ,1.7, 21.93
 2886,-10.8,2.2, 14, 00,   00,  W/B ,+10.2,   7.3,ECU. , -7.2,ECU.  ,2.3, >25:1
 2789, -8.3,2.5, 26, 10,   00,  W/B ,+21.3,  10.3,+22.7,-12.3,ECU.  ,2.2, 21.27
 2962, -5.1,2.6, 63, 10,   00,  W/B ,+35.2,  12.8,+21.8,-12.3,215.00,2.4, 14.96
 2926, -1.6,2.7,100, 10,   00,  W/B ,+34.3,  12.9,+22.3,-12.3,WGS.  ,2.3, 14.58
 2952, +1.4,2.8,102, 10,   00,  W/B ,+33.5,  14.6,+22.0,-12.2,WGS.  ,2.5, 14.33
 2986, +2.9,2.9,101, 20,   00,  W/B ,+32.9,  15.6,+21.8,-12.5,WGS.  ,2.5, 13.65
 3016, +3.7,2.9,101, 20,   00,  W/B ,+32.8,  16.8,+21.5,-12.4,WGS.  ,2.5, 13.09
 3041, +4.9,2.9,101, 30,   00,  W/B ,+32.7,  17.2,+21.2,-12.5,WGS.  ,2.6, 12.67
 3066, +5.9,3.1,101, 30,   00,  W/B ,+32.6,  18.5,+20.8,-12.2,WGS.  ,2.7, 12.39
 3103, +7.4,3.0,101, 40,   00,  W/B ,+31.0,  20.4,+20.2,-12.0,250.00,2.6, 12.23
 3129, +8.6,3.1,101, 40,   00,  W/B ,+30.7,  22.3,+19.7,-11.9,250.00,2.7, 12.00
 3138, +9.8,3.2,102, 50,   00,  W/B ,+29.3,  23.7,+19.3,-12.2,250.00,2.8, 11.84
 3239,+11.0,3.1,101, 50,   00,  W/B ,+29.3,  24.2,+18.7,-11.5,250.00,2.9, 11.61
 3239,+12.3,3.3,101, 60,   00,  W/B ,+29.0,  27.8,+18.1,-11.0,250.00,2.8, 11.30
 3297,+13.5,3.4,101, 60,   00,  W/B ,+28.2,  27.8,+17.6,-11.4,250.00,3.0, 11.05
 3330,+14.5,3.4,101, 70,   00,  W/B ,+27.5,  29.0,+17.1,-11.4,250.00,2.9, 10.87
 3415,+15.5,3.4,100, 70,   00,  W/B ,+26.8,  30.5,+17.0,-11.1,250.00,3.1, 10.78
 3561,+16.1,3.6,101, 70,   00,  W/B ,+26.7,  33.6,+16.5,-10.1,250.00,3.2, 10.67
 3486,+16.9,3.6,102, 80,   00,  W/B ,+25.3,  34.8,+16.6,-10.9,250.00,3.1, 10.56
 3595,+18.0,3.4,101, 80,   00,  W/B ,+26.2,  34.7,+16.5,-10.9,250.00,3.0, 10.45
 3568,+18.4,3.7,102, 80,   00,  W/B ,+24.9,  36.8,+16.5,-10.6,250.00,3.2, 10.48
 3654,+18.2,3.6,101, 70,   00,  W/B ,+24.9,  37.1,+16.5,-10.4,250.00,3.2, 10.56
 3724,+18.4,3.7,101, 80,   00,  W/B ,+24.2,  38.3,+16.5,-10.0,250.00,3.1, 10.64
 3770,+18.4,3.6,101, 80,   00,  W/B ,+24.3,  37.5,+16.5,-10.0,250.00,3.3, 10.71
The UTEC smooths out boost values so pay attention to the load site. I'm making target boost before 3500 RPM. I've hit 21 PSI in that same range as well. Tuning will not get you that much more spool so don't get your hopes up. Stock EJ205, stock exhaust manifold (not ported). Its all in the mechanics so free up the flow.
cdvma is offline   Reply With Quote
Jesus potato. Clear evidence of the Divine. taxcider Off-Topic 7 04-06-2010 12:24 AM
Evidence of the Change (tm) is upon us! CosmoTheCat Political Playground 23 11-10-2008 03:39 PM
Need hard evidence of the function of the STI spoiler vapore0n General Community 144 11-21-2005 04:58 PM
boost questions and has anyone heard of the 3/16 mod jacket03WRX Newbies & FAQs 5 09-24-2004 11:05 AM
