Old 05-11-2006, 02:38 AM   #26
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Originally Posted by Wrinkleboi
Super 16G is your answer Flows 580 cfm and still spools like a VF30 (usually, depending on tune and supporting mods of course)
sounds like our goals are similar, only difference is I've already got one of these sitting in my bedroom
Thats a negative. It will never spool like a 30.
cdvma is offline   Reply With Quote
Old 05-11-2006, 03:34 AM   #27
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
ok fair enough, shoulda said it spools close to a vf30, i stand by my opinion that it wont be far off...
like i said my vf34 untuned probabaly spools at the same rpm that my tuned super 16g will spool, so thats cool with me .
TROLL is offline   Reply With Quote
Old 05-11-2006, 03:46 AM   #28
McBain_TP
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
I couldn't tell any difference in lag between my VF30 and 18G.
McBain_TP is offline   Reply With Quote
Old 05-11-2006, 04:23 AM   #29
scoooby03
Member#: 110654
Originally Posted by cdvma
Most people only think that a VF22 is "laggy" because most people think "its a big turbo". Its still a tiny turbo and it isn't laggy at all. Your picture also presents one flaw - we know that the tachs are often not accurate and sometimes off by as much as 300 rpm.
Code:
 2876, -8.1,1.3,  0, 00,   00,  W/B ,+11.7,   4.5,ECU. , -7.2,ECU.  ,1.2, 15.94
 2858,-11.0,1.5,  1, 00,   00,  W/B , +4.4,   6.2,ECU. , -7.2,ECU.  ,1.7, 21.93
 2886,-10.8,2.2, 14, 00,   00,  W/B ,+10.2,   7.3,ECU. , -7.2,ECU.  ,2.3, >25:1
 2789, -8.3,2.5, 26, 10,   00,  W/B ,+21.3,  10.3,+22.7,-12.3,ECU.  ,2.2, 21.27
 2962, -5.1,2.6, 63, 10,   00,  W/B ,+35.2,  12.8,+21.8,-12.3,215.00,2.4, 14.96
 2926, -1.6,2.7,100, 10,   00,  W/B ,+34.3,  12.9,+22.3,-12.3,WGS.  ,2.3, 14.58
 2952, +1.4,2.8,102, 10,   00,  W/B ,+33.5,  14.6,+22.0,-12.2,WGS.  ,2.5, 14.33
 2986, +2.9,2.9,101, 20,   00,  W/B ,+32.9,  15.6,+21.8,-12.5,WGS.  ,2.5, 13.65
 3016, +3.7,2.9,101, 20,   00,  W/B ,+32.8,  16.8,+21.5,-12.4,WGS.  ,2.5, 13.09
 3041, +4.9,2.9,101, 30,   00,  W/B ,+32.7,  17.2,+21.2,-12.5,WGS.  ,2.6, 12.67
 3066, +5.9,3.1,101, 30,   00,  W/B ,+32.6,  18.5,+20.8,-12.2,WGS.  ,2.7, 12.39
 3103, +7.4,3.0,101, 40,   00,  W/B ,+31.0,  20.4,+20.2,-12.0,250.00,2.6, 12.23
 3129, +8.6,3.1,101, 40,   00,  W/B ,+30.7,  22.3,+19.7,-11.9,250.00,2.7, 12.00
 3138, +9.8,3.2,102, 50,   00,  W/B ,+29.3,  23.7,+19.3,-12.2,250.00,2.8, 11.84
 3239,+11.0,3.1,101, 50,   00,  W/B ,+29.3,  24.2,+18.7,-11.5,250.00,2.9, 11.61
 3239,+12.3,3.3,101, 60,   00,  W/B ,+29.0,  27.8,+18.1,-11.0,250.00,2.8, 11.30
 3297,+13.5,3.4,101, 60,   00,  W/B ,+28.2,  27.8,+17.6,-11.4,250.00,3.0, 11.05
 3330,+14.5,3.4,101, 70,   00,  W/B ,+27.5,  29.0,+17.1,-11.4,250.00,2.9, 10.87
 3415,+15.5,3.4,100, 70,   00,  W/B ,+26.8,  30.5,+17.0,-11.1,250.00,3.1, 10.78
 3561,+16.1,3.6,101, 70,   00,  W/B ,+26.7,  33.6,+16.5,-10.1,250.00,3.2, 10.67
 3486,+16.9,3.6,102, 80,   00,  W/B ,+25.3,  34.8,+16.6,-10.9,250.00,3.1, 10.56
 3595,+18.0,3.4,101, 80,   00,  W/B ,+26.2,  34.7,+16.5,-10.9,250.00,3.0, 10.45
 3568,+18.4,3.7,102, 80,   00,  W/B ,+24.9,  36.8,+16.5,-10.6,250.00,3.2, 10.48
 3654,+18.2,3.6,101, 70,   00,  W/B ,+24.9,  37.1,+16.5,-10.4,250.00,3.2, 10.56
 3724,+18.4,3.7,101, 80,   00,  W/B ,+24.2,  38.3,+16.5,-10.0,250.00,3.1, 10.64
 3770,+18.4,3.6,101, 80,   00,  W/B ,+24.3,  37.5,+16.5,-10.0,250.00,3.3, 10.71
The UTEC smooths out boost values so pay attention to the load site. I'm making target boost before 3500 RPM. I've hit 21 PSI in that same range as well. Tuning will not get you that much more spool so don't get your hopes up. Stock EJ205, stock exhaust manifold (not ported). Its all in the mechanics so free up the flow.
Can somebody help and let me know how to read this chart? appreciated, Drake
scoooby03 is offline   Reply With Quote
Old 05-11-2006, 10:18 AM   #30
pezman04wrx
Member#: 66558
^^^ The only columns you really care about are the first two ... RPM and Boost ... At 3330rpms he's making 14.5lbs of boost ... Hope that helps ...
+1
pezman04wrx is offline   Reply With Quote
Old 05-11-2006, 12:33 PM   #31
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Like this :
All that + perrin turbo inlet hose + STI IC and 3" catless turboback. I really don't think I can free up much more. Plus the exhaust is all heat wrapped and the turbo is ceramic coated.
On a side note: The engine overboosted SEVERELY and blew a head gasket as a result of this porting and polishing. I solved it by P&Ping the wastegate.
Side note 2: if you play that video frame-by-frame, 40MPH to 60MPH goes by in 1.18 seconds. The new Dodge viper takes 1.80seconds to do the same acceleration
powerlabs is offline   Reply With Quote
Old 05-11-2006, 12:59 PM   #32
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Originally Posted by powerlabs
Like this
Yea, like that
Old 05-11-2006, 01:29 PM   #33
Beebs99
Member#: 73803
2008 4 Door WRX
Where do you guys get the numbers for the super 16g? I thought it was the same as a big 16g from forced performance.
standard 16g=510
big 16g=550
evoIII 16g=575
Beebs99 is offline   Reply With Quote
Old 05-11-2006, 03:54 PM   #34
poormansporsche
Member#: 79798
Damn this thread is really selling me on the VF22. How do you think this will autocross. I would think worst case is that you slow the engine to 3k RPM's in a harsh corner maybe a split second of lag then booyah! Looks pretty sick.
cheers
garrett
poormansporsche is offline   Reply With Quote
Old 05-11-2006, 04:20 PM   #35
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
I get 14 psi by about 4500-4700 rpm.
Clark
AZScoobie is offline   Reply With Quote
Old 05-11-2006, 04:26 PM   #36
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Clark
Clark whats wrong with your car? Thats really laggy! OMG!
Old 05-11-2006, 04:26 PM   #37
elsanto
Member#: 34832
1989 M3
my VF22 was laggier than my PNP small 16g.. BUT i also put in tgv deletes. the 16g is alot of fun on the lower band. I get ~10lbs by 3krpm and the rest follows quickly.
elsanto is offline   Reply With Quote
Old 05-11-2006, 04:54 PM   #38
AZScoobie
Member#: 8785
netcom.com
I have a new turbo thats larger then your head
C
Old 05-11-2006, 04:56 PM   #39
powerlabs
Member#: 45790
SUPERCHARGED
cheers
garrett
I will let you know this weekend I expect it to do very well on most courses, but I think a stock turboed car would do better on a very small course with lots of tight bends. The official COBB autocross car used a VF22 for a while, so its got to be pretty good
And on those tight courses... Bah, autocross represents maybe 0.0001% of the driving I do; big deal.
Old 05-11-2006, 05:00 PM   #40
elsanto
Member#: 34832
1989 M3
I autocrossed all of last season on a vf22. hella fun, but can be annoying coming out of tight corners. left foot braking would definitely help but i never got that good with that... i have an RA box as well. can't wait to play with the small 16g. funny thing even though the 16g supposably flows more than the 22 the 22 felt more powerful, maybe cause when it hits it hits hard.. but still perceptually it was stronger.
Old 05-11-2006, 05:07 PM   #41
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I chose the VF22 looking for power, but most of what I read on this forum pointed to it being a very laggy turbo, which I really didn't want since I autocross all the time.
This on 5th gear, level road (slight decline actually).
I'm totally always autocrossing in 5th gear
jblaine is offline   Reply With Quote
Old 05-11-2006, 05:10 PM   #42
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Your autocross test is this:
Put car in 2nd gear.
Slow to 15-20mph to simulate a reasonably speed for a semi-sharp turn.
Stomp gas pedal and watch gauge.
Old 05-11-2006, 05:31 PM   #43
richde
Member#: 79498
2013 XV
TD04 2nd gear stomping on it at 2k rpms and it hits 16psi at 2900rpms
5th grear roll on from 2K rpms....16+psi at 2550-2600rpms
Protuned, but no PnP.....yet.
richde is offline   Reply With Quote
Old 05-11-2006, 05:39 PM   #44
powerlabs
Member#: 45790
SUPERCHARGED
Here you go
You can hear when I get on it; its just under 25MPH I think. It goes pretty well; some times, if the road is dusty or wet, it will spin all 4 at 40MPH
Old 05-11-2006, 05:49 PM   #45
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Cool.
Old 05-11-2006, 06:20 PM   #46
poormansporsche
Member#: 79798
pwn3d.
cheers
garrett
Old 05-11-2006, 07:48 PM   #47
KmanRuffian
Member#: 48360
2011 WRX 5-door
Try cruising along in vacuum at 40 and then flooring it for a proper comparison to the viper 40-60mph test...
-D
KmanRuffian is offline   Reply With Quote
Old 05-11-2006, 09:48 PM   #48
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
flow numbers are taken from boostplanet.com the website of Deadbolt which is the only place to get a Super 16G
damn good company and they really stand by their turbos, never seen customer service like they have before in my life...
Old 05-11-2006, 09:48 PM   #49
powerlabs
Member#: 45790
SUPERCHARGED
-D
Hehehehehe... I have a feeling the viper would eat me alive then
Wait... Can I brake boost?
Old 05-12-2006, 08:39 PM   #50
Davenow
Member#: 23676
I have that beat with my 2.0 and VF22
14PSI at about 2950
21PSI before 3300
Jesus potato. Clear evidence of the Divine. taxcider Off-Topic 7 04-05-2010 11:24 PM
Evidence of the Change (tm) is upon us! CosmoTheCat Political Playground 23 11-10-2008 02:39 PM
Need hard evidence of the function of the STI spoiler vapore0n General Community 144 11-21-2005 03:58 PM
boost questions and has anyone heard of the 3/16 mod jacket03WRX Newbies & FAQs 5 09-24-2004 10:05 AM
