Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-10-2006, 04:29 PM   #1
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
Default latest logs
from a friends Mustang Dyno, this one made 390 whp, I dont have the plots though because Im still waiting on them. We made a bit more area under the curve, and the load this dyno provides is awesome when you get off the dyno and use the car on the street. he also has a great fan setup, and exhaust evacuation, its good when your father owns an HVAC company.
about 80 degrees in the room this day
fp green 2.4 inlet/7cm^2 hotside
2.2L closed deck w/ aftermarket rods and pistons
wrx heads w/ work and sti cams
fp green
fmic
big maf
full 3 inch exhaust
no tgv's
tial 44mm ewg
baseline, before
Code:
                   Load Knock                     Mod   Mod         Mod   WB
 RPM   MAP  MAF TPS Site Count  AFR  Ign#1  Inj#1  Ign   Fuel Boost  MAF   AFR
       psig  V   %                    deg   duty   deg    %   (CL)    V
 2117  -7.1 1.9   3  00    00   W/B  +27.2    4.8 ECU.   -3.0 ECU.   1.6  14.45
 2107  -7.1 1.9   3  00    00   W/B  +27.5    4.5 ECU.   -3.0 ECU.   1.6  14.49
 2119  -7.1 1.9   3  00    00   W/B  +27.6    5.9 ECU.   -3.0 ECU.   1.6  14.58
 2120  -7.1 1.9   3  00    00   W/B  +27.6    5.8 ECU.   -3.0 ECU.   1.6  14.53
 2113  -7.1 1.9   3  00    00   W/B  +27.5    4.5 ECU.   -3.0 ECU.   1.6  14.42
 2123  -6.9 1.9   3  00    00   W/B  +27.2    4.5 ECU.   -3.0 ECU.   1.6  14.42
 2121  -6.9 1.9   3  00    00   W/B  +27.5    6.0 ECU.   -3.0 ECU.   1.6  14.45
 2131  -6.7 1.9   3  00    00   W/B  +27.6    4.8 ECU.   -3.0 ECU.   1.6  14.58
 2117  -6.7 1.9   3  00    00   W/B  +27.6    5.7 ECU.   -3.0 ECU.   1.6  14.49
 2125  -6.9 1.9   3  00    00   W/B  +27.5    5.9 ECU.   -3.0 ECU.   1.6  14.42
 2127  -6.9 1.9   3  00    00   W/B  +27.9    6.0 ECU.   -3.0 ECU.   1.6  14.45
 2108  -7.1 1.9   3  00    00   W/B  +27.6    4.7 ECU.   -3.0 ECU.   1.6  14.49
 2140  -7.1 1.9   3  00    00   W/B  +27.5    6.0 ECU.   -3.0 ECU.   1.6  14.42
 2112  -7.1 1.9   3  00    00   W/B  +27.2    5.9 ECU.   -3.0 ECU.   1.6  14.42
 2129  -7.1 1.9   3  00    00   W/B  +27.2    4.6 ECU.   -3.0 ECU.   1.6  14.49
 2103  -6.9 1.9   3  00    00   W/B  +27.5    5.8 ECU.   -3.0 ECU.   1.6  14.58
 2113  -6.9 1.9   3  00    00   W/B  +27.5    4.5 ECU.   -3.0 ECU.   1.6  14.74
 2138  -6.7 2.1  14  00    00   W/B  +29.8    4.3 ECU.   -3.0 ECU.   2.1  14.58
 2164  -5.3 2.4  38  10    00   W/B  +35.5    8.1 +30.3  -1.0 ECU.   2.1  14.45
 2222  -3.7 2.4  61  10    00   W/B  +32.6    8.8 +30.1  -1.0 ECU.   2.1  14.30
 2252  -1.8 2.4  98  10    00   W/B  +36.2    8.6 +30.0  -1.7 ECU.   2.2  14.18
 2302  +0.0 2.5  98  10    00   W/B  +36.6    9.0 +30.0  -1.1 ECU.   2.2  14.25
 2329  +0.4 2.5  98  10    00   W/B  +36.5    9.8 +30.0  -1.4 ECU.   2.2  14.33
 2382  +0.4 2.5  98  10    00   W/B  +37.3   10.3 +30.0  -1.4 ECU.   2.2  14.22
 2427  +0.6 2.5  98  10    00   W/B  +36.9   10.1 +30.0  -1.5 ECU.   2.2  13.72
 2525  +0.8 2.5  98  10    00   W/B  +36.5   10.4 +30.0  -1.8 ECU.   2.3  13.62
 2529  +1.0 2.6  98  10    00   W/B  +36.1   11.0 +30.0  -1.8 ECU.   2.3  13.97
 2598  +1.2 2.6  98  10    00   W/B  +35.6   11.3 +30.0  -2.0 ECU.   2.3  14.05
 2649  +1.4 2.6  97  10    00   W/B  +35.1   11.7 +30.0  -2.0 ECU.   2.3  13.95
 2718  +1.7 2.7  98  10    00   W/B  +34.4   12.6 +30.0  -2.0 ECU.   2.3  13.75
 2768  +1.9 2.7  98  10    00   W/B  +33.4   13.2 +30.0  -2.2 ECU.   2.4  13.59
 2866  +2.1 2.8  98  10    00   W/B  +33.3   14.7 +30.0  -2.2 ECU.   2.4  13.56
 2911  +2.3 2.9  98  10    00   W/B  +33.1   15.2 +30.0  -2.2 ECU.   2.4  13.45
 3005  +2.5 2.8  98  10    00   W/B  +32.8   15.8 +30.0  -2.2 ECU.   2.5  13.06
 3069  +2.9 2.9  98  10    00   W/B  +32.7   16.4 +30.0  -2.3 ECU.   2.5  12.81
 3115  +3.3 2.9  98  20    00   W/B  +32.8   16.6 +30.0  -2.4 ECU.   2.5  12.68
 3202  +3.7 2.9  98  20    00   W/B  +32.4   17.1 +30.0  -2.4 ECU.   2.5  12.71
 3239  +3.9 2.9  98  20    00   W/B  +32.8   17.3 +30.0  -2.3 ECU.   2.6  12.83
 3320  +4.5 3.0  98  20    00   W/B  +32.7   17.9 +29.6  -2.3 ECU.   2.7  12.92
 3363  +4.9 3.0  98  20    00   W/B  +32.7   18.5 +29.4  -2.2 ECU.   2.7  12.86
 3490  +5.5 3.1  98  20    00   W/B  +33.0   19.6 +29.2  -2.1 ECU.   2.7  12.86
 3565  +6.1 3.1  98  20    00   W/B  +32.5   21.2 +29.0  -2.1 ECU.   2.8  13.02
 3683  +6.3 3.2  98  30    00   W/B  +32.0   22.1 +23.2  -3.0 ECU.   2.8  13.14
 3745  +7.0 3.3  98  30    00   W/B  +32.0   23.4 +23.1  -2.7 ECU.   2.9  13.17
 3831  +7.6 3.3  96  30    00   W/B  +31.9   25.3 +23.6  -2.7 ECU.   2.9  13.06
 3921  +8.4 3.5  98  40    00   W/B  +31.6   29.6 +21.7  -2.9 ECU.   3.0  12.78
 3977  +9.4 3.5  98  40    00   W/B  +31.5   35.3 +22.1  -3.8 ECU.   3.0  12.25
 4166 +10.6 3.6  98  40    00   W/B  +30.7   36.0 +22.6  -5.5 ECU.   3.1  11.43
 4323 +12.3 3.9  98  50    00   W/B  +28.9   42.3 +19.4  -7.1 ECU.   3.2  11.27
 4432 +14.1 4.0  98  60    00   W/B  +22.8   50.8 +18.0  -5.5 ECU.   3.5  11.56
 4572 +16.7 4.2  98  70    00   W/B  +19.5   55.2 +18.6  -7.2 ECU.   3.5  11.27
 4782 +19.0 4.2  97  80    00   W/B  +20.8   65.3 +20.0  -6.1 ECU.   3.5  10.99
 4967 +21.4 4.3  98  80    00   W/B  +22.2   69.2 +20.0  -3.7 ECU.   3.7  10.89
 5112 +22.7 4.3  97  80    00   W/B  +22.1   71.9 +20.0  -3.5 ECU.   3.7  10.83
 5249 +22.9 4.4  97  80    00   W/B  +21.6   74.8 +20.0  -4.0 ECU.   3.8  10.83
 5437 +22.7 4.4  97  80    00   W/B  +21.8   79.6 +20.0  -4.0 ECU.   3.8  10.83
 5707 +21.8 4.5  98  70    00   W/B  +21.9   73.6 +20.0  -6.2 ECU.   3.7  10.86
 5837 +21.4 4.5  97  70    00   W/B  +24.2   74.1 +20.0  -6.4 ECU.   3.8  11.12
 5952 +21.4 4.5  97  70    00   W/B  +25.3   73.2 +20.1  -6.4 ECU.   3.8  11.56
 6150 +21.2 4.6  98  70    01   W/B  +26.3   76.6 +20.9  -6.0 ECU.   3.8  11.76
 6195 +21.0 4.6  97  70    00   W/B  +31.5   76.2 +21.0  -6.0 ECU.   3.8  11.67
 6510 +21.2 4.6  98  70    00   W/B  +33.4   78.8 +21.0  -6.0 ECU.   3.8  11.53
 6600 +20.4 4.6  97  70    00   W/B  +33.3   80.5 +21.0  -6.0 ECU.   3.9  11.56
 7032 +19.8 4.6  97  70    00   W/B  +34.1   78.0 +21.0  -6.0 ECU.   3.9  11.62
 6844 +19.6 4.6  97  70    00   W/B  +34.6   79.5 +21.0  -6.0 ECU.   3.8  11.67
 7032 +19.8 4.6  97  70    00   W/B  +34.9   83.6 +21.0  -6.0 ECU.   3.9  11.71
 7137 +19.8 4.6  97  70    00   W/B  +29.2   83.0 +21.0  -4.7 ECU.   4.0  11.71
 7358 +20.8 4.6  97  70    00   W/B  +29.1   82.4 +21.0  -3.8 ECU.   3.9  11.71
 7293 +20.8 4.6  97  80    02   W/B  +26.8   91.1  +5.0  -1.0 ECU.   4.0  11.48
 7407 +20.6 4.6  98  70    03   W/B  +28.5   83.8  +5.4  -3.8 ECU.   4.0  11.45
 7358 +21.8 4.6  89  70    02   W/B  +29.3   84.8  +5.9  -3.8 ECU.   3.9  12.61
Code:
 2112  -0.4 2.3  98  10    00   W/B  +35.1    7.3 +30.6  -1.0 ECU.   2.1  14.96
 2032  -0.2 2.4  98  10    00   W/B  +35.4    8.3 +30.8  -1.0 ECU.   2.1  14.96
 2105  +0.0 2.3  97  10    00   W/B  +35.0    8.0 +30.5  -1.0 ECU.   2.1  14.65
 2111  +0.4 2.4  98  10    00   W/B  +35.2    8.3 +30.5  -1.0 ECU.   2.1  14.58
 2191  +0.4 2.4  98  10    00   W/B  +35.1    8.5 +30.3  -1.0 ECU.   2.1  14.74
 2197  +0.6 2.4  98  10    00   W/B  +35.5    9.1 +30.3  -1.0 ECU.   2.1  14.58
 2220  +0.6 2.4  97  10    00   W/B  +35.9    8.8 +30.1  -1.0 ECU.   2.2  14.49
 2241  +0.8 2.4  98  10    00   W/B  +35.9    8.6 +30.1  -1.7 ECU.   2.1  14.58
 2270  +0.8 2.4  98  10    00   W/B  +36.2    9.1 +30.0  -1.0 ECU.   2.1  14.65
 2290  +1.0 2.4  98  10    00   W/B  +36.1    9.2 +30.0  -1.1 ECU.   2.2  14.58
 2306  +1.0 2.5  97  10    00   W/B  +36.6    9.3 +30.0  -1.1 ECU.   2.2  14.53
 2355  +1.0 2.5  97  10    00   W/B  +36.9    9.6 +30.0  -1.1 ECU.   2.2  14.42
 2384  +1.3 2.5  98  10    00   W/B  +36.9   10.0 +30.0  -1.4 ECU.   2.2  14.25
 2417  +1.3 2.5  98  10    00   W/B  +37.2   10.0 +30.0  -1.5 ECU.   2.3  14.15
 2417  +1.3 2.5  98  10    00   W/B  +37.3   10.3 +30.0  -1.6 ECU.   2.3  14.05
 2465  +1.3 2.5  97  10    00   W/B  +36.6    9.8 +30.0  -1.7 ECU.   2.3  14.05
 2493  +1.5 2.6  98  10    00   W/B  +36.1   10.4 +30.0  -2.1 ECU.   2.2  14.05
 2515  +1.5 2.5  98  10    00   W/B  +35.8   10.4 +30.0  -1.8 ECU.   2.3  14.18
 2510  +1.7 2.6  98  10    00   W/B  +35.8   10.7 +30.0  -1.8 ECU.   2.3  14.37
 2540  +1.7 2.6  97  10    00   W/B  +35.4   11.2 +30.0  -1.8 ECU.   2.3  14.30
 2568  +1.7 2.7  98  10    00   W/B  +35.0   11.4 +30.0  -2.0 ECU.   2.3  14.18
 2612  +1.7 2.6  98  10    00   W/B  +34.9   11.7 +30.0  -1.9 ECU.   2.3  14.15
 2681  +1.7 2.6  97  10    00   W/B  +34.3   11.8 +30.0  -2.0 ECU.   2.3  14.05
 2701  +1.9 2.7  98  10    00   W/B  +34.1   12.4 +30.0  -2.0 ECU.   2.3  13.95
 2745  +1.7 2.7  98  10    00   W/B  +33.7   12.4 +30.0  -2.1 ECU.   2.3  13.87
 2761  +1.9 2.7  98  10    00   W/B  +33.5   12.8 +30.0  -2.2 ECU.   2.3  13.84
 2808  +1.9 2.7  98  10    00   W/B  +33.3   13.1 +30.0  -2.2 ECU.   2.4  13.97
 2796  +2.1 2.8  97  10    00   W/B  +33.1   13.6 +30.0  -2.2 ECU.   2.4  14.00
 2839  +2.3 2.7  97  10    00   W/B  +33.3   14.0 +30.0  -2.2 ECU.   2.5  13.87
 2846  +2.5 2.8  97  10    00   W/B  +33.1   14.4 +30.0  -2.2 ECU.   2.5  13.75
 2929  +2.7 2.8  97  10    00   W/B  +33.1   15.6 +30.0  -2.2 ECU.   2.4  13.53
 2931  +2.9 2.9  98  20    00   W/B  +33.0   14.7 +30.0  -4.3 ECU.   2.5  13.25
 2960  +2.9 2.9  98  20    00   W/B  +32.8   15.0 +30.0  -4.5 ECU.   2.4  13.17
 3013  +3.1 2.9  97  20    00   W/B  +32.8   15.3 +30.0  -4.5 ECU.   2.4  13.50
 3055  +3.5 2.9  98  20    00   W/B  +32.7   15.7 +30.0  -4.5 ECU.   2.5  13.78
 3121  +3.5 2.9  97  20    00   W/B  +32.7   16.0 +30.0  -4.5 ECU.   2.5  13.75
 3106  +3.9 3.0  98  20    00   W/B  +32.5   16.1 +30.0  -4.4 ECU.   2.5  13.75
 3183  +3.9 3.0  98  20    00   W/B  +32.4   16.8 +30.0  -4.4 ECU.   2.5  13.81
 3226  +4.3 3.0  97  20    00   W/B  +32.4   16.7 +30.0  -4.2 ECU.   2.5  13.87
 3277  +4.5 2.9  97  20    00   W/B  +32.2   16.7 +30.0  -4.3 ECU.   2.6  13.95
 3306  +4.9 3.0  97  20    00   W/B  +32.1   17.1 +29.7  -4.3 ECU.   2.6  14.05
 3353  +5.3 3.0  97  20    00   W/B  +32.7   17.1 +29.7  -4.3 ECU.   2.6  14.15
 3380  +5.7 3.0  97  30    00   W/B  +32.7   17.4 +24.6  -4.0 ECU.   2.6  14.18
 3404  +5.9 3.1  98  30    00   W/B  +32.6   18.1 +24.5  -4.1 ECU.   2.6  14.15
 3490  +6.1 3.1  98  30    00   W/B  +32.4   18.9 +24.2  -4.1 ECU.   2.6  14.00
 3475  +6.1 3.1  98  30    00   W/B  +32.6   19.0 +24.1  -4.4 ECU.   2.7  13.87
 3549  +6.4 3.2  97  30    00   W/B  +32.9   19.9 +23.9  -4.3 ECU.   2.7  13.95
 3603  +6.8 3.2  97  30    00   W/B  +31.8   21.5 +23.5  -4.2 ECU.   2.8  14.05
 3654  +7.2 3.2  97  30    00   W/B  +31.6   21.5 +23.3  -4.1 ECU.   2.8  14.05
 3699  +7.6 3.3  98  30    00   W/B  +31.1   23.2 +23.3  -4.0 ECU.   2.9  13.95
 3753  +8.2 3.3  97  30    00   W/B  +31.0   24.0 +23.1  -3.7 ECU.   2.9  13.87
 3779  +9.0 3.4  97  40    00   W/B  +30.4   26.5 +21.2  -3.3 ECU.   2.9  13.68
 3840  +9.6 3.4  97  40    00   W/B  +30.6   27.2 +21.6  -3.0 ECU.   3.0  13.45
 3862 +10.4 3.5  97  40    00   W/B  +28.1   30.0 +21.5  -2.9 ECU.   3.0  13.09
 3930 +11.2 3.6  97  50    00   W/B  +26.7   31.6 +18.0  -3.2 ECU.   3.0  12.71
 4006 +12.3 3.7  97  50    00   W/B  +28.2   36.6 +18.3  -6.1 ECU.   3.1  12.42
 4156 +13.5 3.7  97  50    00   W/B  +25.6   37.7 +18.2  -5.6 ECU.   3.2  11.98
 4182 +14.3 3.8  98  60    00   W/B  +24.5   38.6 +18.0  -5.8 ECU.   3.1  11.67
 4246 +16.3 3.9  97  70    00   W/B  +24.3   49.2 +18.0  -4.5 ECU.   3.4  11.80
 4340 +18.4 4.0  97  80    00   W/B  +18.5   54.9 +20.0  -3.2 ECU.   3.5  11.53
 4391 +19.8 4.1  97  80    00   W/B  +17.7   58.1 +20.0  -2.3 ECU.   3.6  10.99
 4604 +21.7 4.1  97  80    00   W/B  +17.1   55.6 +20.0  -2.8 ECU.   3.4  10.89
 4504 +22.3 4.1  97  80    00   W/B  +17.5   56.5 +20.0  -4.3 ECU.   3.5  10.86
 4761 +22.1 4.2  97  80    00   W/B  +18.9   58.1 +20.0  -5.2 ECU.   3.5  10.90
 4803 +22.5 4.2  97  80    00   W/B  +19.1   59.4 +20.0  -5.5 ECU.   3.5  11.23
 4894 +22.9 4.2  97  80    00   W/B  +21.0   58.0 +20.0  -5.6 ECU.   3.6  11.30
 4990 +23.1 4.3  97  80    00   W/B  +22.5   60.8 +20.0  -6.6 ECU.   3.5  11.34
 5089 +23.3 4.3  97  80    00   W/B  +21.0   61.4 +20.0  -6.2 ECU.   3.6  11.45
 5257 +23.5 4.3  98  80    00   W/B  +22.7   62.9 +20.0  -6.4 ECU.   3.6  11.53
 5265 +22.5 4.3  97  80    00   W/B  +24.6   64.5 +20.0  -6.7 ECU.   3.6  11.61
 5428 +22.1 4.4  97  70    00   W/B  +21.4   69.2 +20.0  -5.5 ECU.   3.7  11.58
 5500 +21.0 4.4  97  70    00   W/B  +21.3   72.0 +20.0  -4.7 ECU.   3.7  11.33
 5509 +20.4 4.4  97  70    00   W/B  +21.0   73.4 +20.0  -4.6 ECU.   3.7  11.06
 5649 +21.4 4.4  97  80    01   W/B  +21.8   72.1 +20.0  -6.1 ECU.   3.7  11.05
 5688 +20.8 4.4  97  70    01   W/B  +25.3   67.8 +20.0  -5.6 ECU.   3.7  11.24
 5973 +20.6 4.4  96  70    00   W/B  +24.1   77.3 +20.2  -5.6 ECU.   3.7  11.43
 5889 +20.8 4.5  97  70    00   W/B  +22.3   75.1 +20.0  -5.0 ECU.   3.7  11.43
 5984 +20.2 4.5  97  80    00   W/B  +22.9   77.4 +20.0  -4.2 ECU.   3.8  11.45
 6071 +19.8 4.5  96  70    00   W/B  +24.0   75.7 +20.6  -4.7 ECU.   3.8  11.39
 6038 +20.4 4.5  97  70    00   W/B  +23.8   73.2 +20.8  -5.6 ECU.   3.8  11.33
 6172 +20.2 4.5  97  70    00   W/B  +26.1   73.2 +20.7  -5.8 ECU.   3.8  11.39
 6289 +19.8 4.5  97  70    00   W/B  +28.7   73.5 +21.0  -5.8 ECU.   3.8  11.53
 6301 +19.8 4.5  97  70    00   W/B  +29.3   77.5 +21.0  -5.9 ECU.   3.8  11.67
 6422 +19.4 4.5  97  70    00   W/B  +29.3   81.0 +21.0  -5.8 ECU.   3.8  11.68
 6497 +18.8 4.5  97  70    00   W/B  +31.0   75.8 +21.0  -5.9 ECU.   3.8  11.61
 6720 +18.8 4.5  97  70    00   W/B  +30.6   76.1 +21.0  -6.0 ECU.   3.8  11.56
 6788 +19.4 4.5  97  70    00   W/B  +30.8   76.2 +21.0  -6.0 ECU.   3.8  11.62
 6693 +19.2 4.5  97  70    00   W/B  +31.5   77.5 +21.0  -6.0 ECU.   3.8  11.71
 6693 +19.8 4.5  96  70    00   W/B  +31.7   74.8 +21.0  -6.0 ECU.   3.8  11.77
 6844 +20.2 4.5  97  70    00   W/B  +31.8   77.9 +21.0  -6.0 ECU.   3.8  11.89
 6872 +19.8 4.5  97  70    00   W/B  +32.4   74.0 +21.0  -6.0 ECU.   3.8  11.98
 6858 +19.6 4.5  97  70    00   W/B  +31.7   77.2 +21.0  -4.1 ECU.   3.8  11.98
 7062 +20.0 4.5  97  70    01   W/B  +32.3   77.7 +21.0  -5.6 ECU.   3.8  11.92
 7077 +19.6 4.6  97  70    00   W/B  +26.1   80.5 +21.0  -5.2 ECU.   3.9  11.98
 7199 +20.0 4.6  97  70    00   W/B  +25.8   80.4 +21.0  -5.2 ECU.   3.9  12.00
 7407 +20.2 4.6  96  70    01   W/B  +26.5   80.1 +21.3  -3.8 ECU.   3.9  11.80
knock sensitivity was turned down about half of what Ron told me to set it, threshold is at 3.
93 pump gas
SBW is offline   Reply With Quote
Old 05-10-2006, 04:53 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
IMHO no point to lean out that much up top. How are the EGTs? Also do you have detcans?
cdvma is offline   Reply With Quote
Old 05-10-2006, 11:01 PM   #3
SBW
Member#: 38469
07 LGT spec-b
yeah, i have a txs tuner. egts are fine, Im measuring just a few inches after the port and they never get over 810c
Old 05-10-2006, 11:05 PM   #4
da n00b
Member#: 65951
02' e46 ///M3
Imola Red
Hey I was wondering how do you record your logs? Im really new to the Utec. Thanks.
da n00b is offline   Reply With Quote
Old 05-11-2006, 01:32 AM   #5
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Sounds like you are prepared!
I am impressed with the combination of timing, AFR and EGTs that you see. Are you running some sort of secondary injection?
Old 05-11-2006, 01:06 PM   #6
wrex03
Member#: 29963
04 sti
duplicate post
wrex03 is offline   Reply With Quote
Old 05-11-2006, 01:07 PM   #7
wrex03
Member#: 29963
04 sti
Very laggy and very lean up top on 93oct
Old 05-11-2006, 01:49 PM   #8
SBW
Member#: 38469
07 LGT spec-b
lag is right, i just wish I could get it to spool faster. But it feels better with more timing during spool up rather than taking it away. it doesn't feel like the .2L makes that much of a difference to get it spinning.
Old 05-11-2006, 02:05 PM   #9
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
timing looks really aggressive during spool up. AFR's look pretty lean during spool up. I prefer to have the AFR's in the low 13's whenever i'm in the 1 to 10psi range. Then have it drop to mid 11's once it's above 10psi.
But maybe the 2.2L closed deck motor can handle those timing values and AFR's.
SloRice is offline   Reply With Quote
Old 05-11-2006, 02:27 PM   #10
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
SloRice,
I prefer to do stoich for low boost levels...helps the gas mileage too not instantly diping down into the rich area so when you grab a couple of lbs during accel you stay stoich. No harm in it anyway since the load is so little...why not save gas? I agree with the quick ramp once you get > 10.
Old 05-11-2006, 02:31 PM   #11
SBW
Member#: 38469
07 LGT spec-b
i agree with these guys about the slow spool though, Im thinking I may re-do my exhaust uppipe gasket, and ditch the sbc-id II, that or set the gain a bit higher.
Old 05-11-2006, 04:15 PM   #12
SloRice
Member#: 44351
2004 Mitsubishi Evo
Get rid of the sbc-id. I hated that boost controller. I have the DTEC and it rocks!!
latest shop photos and latest build Rocket_Rally Vancouver Impreza Club Forum -- VIC 21 03-06-2010 02:10 AM
critique my latest log pls! kuldud Open Source Reflashes 0 11-22-2008 05:54 PM
What game is better? The latest Gran Turismo, or latest Forza? brucelee Off-Topic 57 07-10-2007 03:10 PM
Data logging gurus, need your help reading log. vortectoy AccessPort 5 05-22-2006 01:19 AM
ghetto logging. take a look at my Tari log, need help Keith Engine Management & Tuning 8 06-21-2005 07:14 AM
