Old 05-10-2006, 09:09 PM   #1
jeffsnyder
Member#: 10039
Default JDM V7 sti intercooler in 2006 WRX get it in there
okay help me get this bad boy in my car... what do i need to do
PICS:
jeffsnyder is offline   Reply With Quote
Old 05-10-2006, 09:15 PM   #2
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
have you tried takin off the strut bar?
hhhhmmm even if you do it doesn't look like it'll fit.
Bishop is offline   Reply With Quote
Old 05-10-2006, 09:23 PM   #3
jeffsnyder
Member#: 10039
i'm thinking of cutting the about half inch off the neck of the intercooler.
Old 05-10-2006, 09:35 PM   #4
1-3-2-4
Member#: 100762
2012 WRX Hatch
14 FZ09, 03 VFR, 09 WR250
I think Uncle Scotty has the same intercooler on his 06. If he doesn't chime in, send him a PM. I could be mistaken though...
1-3-2-4 is offline   Reply With Quote
Old 05-10-2006, 09:36 PM   #5
dvang
Member#: 84188
05 legacy
caravan full of kids now
i assume the DBW tb is too long. sell it and buy a bar n plate that fits
dvang is offline   Reply With Quote
Old 05-10-2006, 09:39 PM   #6
jeffsnyder
Member#: 10039
the brackets for the intercooler to bolt down to almost line up perfect. it just the neck is too long. maybe because it came off a car that wasn't drive by wire
Old 05-10-2006, 10:42 PM   #7
th3w0rm
Member#: 98962
2006 OBP WRX
42Autosports tuned vf39
Is this with the stock turbo? You have to do some tweaking with the elbow at the turbo if you still have the td04 in there. Then you'll have the clearance for the throttle body piece.
th3w0rm is offline   Reply With Quote
Old 05-10-2006, 11:19 PM   #8
jeffsnyder
Member#: 10039
i can slide it all together right where it sits. no kinks or anything like that.
it has the stock wrx castings on the bottom
plus i want to make this work w. the strut bar because it should and there is a cut out on the back of the intercooler where it seems the strut bar goes through
Old 05-11-2006, 04:17 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....unbolt and push the electrical harness right below the bpv outa the way(you'll see when ya get the stock IC off) and install it.....the passengers side bracket is 'off' by ~1"....ziptie and done
There is MORE room at the 'top'(aft) edge than on my '02
Old 05-11-2006, 05:31 AM   #10
silentbob343
Member#: 57307
scotty what splitter are you using?
silentbob343 is offline   Reply With Quote
Old 05-11-2006, 06:18 AM   #11
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
The only splitter that will probably fit is the Ver 7 one through www.rallispec.com, ask them though.
Old 05-11-2006, 04:51 PM   #12
jeffsnyder
Member#: 10039
u can use a usdm sti one. it will be abit smaller but it will still be cheaper than buying one through ralli-spec
Old 05-11-2006, 04:52 PM   #13
jeffsnyder
Member#: 10039
i made the choice i'm goin to trim the neck of the intercooler down, because one i don't want to use zippie ties and look getto under the hood and two everything will line up correctly including the brackets
Old 05-11-2006, 05:39 PM   #14
1-3-2-4
Member#: 100762
2012 WRX Hatch
Post pics and let us know what you think about the upgrade.
Old 05-12-2006, 12:11 AM   #15
Bishop
Member#: 59993
Ass, grass or cash
correct i use the usdm splitter BUT w/the JDM shroud.
Old 05-12-2006, 12:16 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
BAD idea
Old 05-12-2006, 05:04 AM   #17
jeffsnyder
Member#: 10039
Originally Posted by Uncle Scotty
BAD idea
better than the getto fab w. zippie ties like u did.
Old 05-12-2006, 10:29 AM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
you do NOT have a CLUE, deeeeewwwwwwwwd.....no clue at all
....and bending the bracket a bit is a FAR-FAR better way of 'fixing this than destroying the IC....
YOU are the idiot mechanic that does stupid things, like cutting the IC, that all of us have nightmares about----especially getting a used car from someone like you that did insanely stupid things to 'fix' easy issues
....jeez
Old 05-12-2006, 11:31 AM   #19
SubasaurusWrex
Member#: 70285
2011 JCW Mini
Midnight Black/Red roof
can you go one day without insulting someone?
SubasaurusWrex is offline   Reply With Quote
Old 05-12-2006, 12:47 PM   #20
Dystinct
Member#: 105759
lack of suprise
KatsSubyRocks!
He was provoked.
Dystinct is offline   Reply With Quote
Old 05-12-2006, 02:52 PM   #21
black06wagon
Member#: 97270
hey toekneeyo...you've got an 06 with a v7 sti cooler, how did the garage tuning guys get yours to fit?
black06wagon is offline   Reply With Quote
Old 05-12-2006, 04:09 PM   #22
1-3-2-4
Member#: 100762
2012 WRX Hatch
If I had to choose between zip ties and cutting the intercooler, I too, would choose zip ties. However, looking at those pictures, it looks like you can make up some very simple brackets to mount everything...so why cut?
Old 05-12-2006, 04:46 PM   #23
jeffsnyder
Member#: 10039
lol i just noticed too that he uses aluminum tape on his intercooler on both sides...
also it looks like he chewed the blue hose from the turbo to the intercooler
and u tell me i'm a idiot mechanic. u ghetto fix everything for ur easy issues that u have
Old 05-12-2006, 07:00 PM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....uuummmmm....that's insulation on the IC.....and that IC has been off and on several times on several cars with several turbo's and still works just great---the hose is a bit....mmmm.....used.....so when has THAT ever been an issue.....and if ya unbolt and move that harness below the bpv.....I hadn't at the time of that pic-----it MIGHT just fit JUST FINE without ANY extra hackin of ANYTHING....or ya just too dumb to try THAT??????
....deeeeewwwwwwwwd.......I was wrenchin bikes and cars and airplanes a LONG time ago......and hackin a $500 part when it is TOTALLY unnecessary is just plain dumb.....is, has been and always will be.
Old 05-12-2006, 08:11 PM   #25
jeffsnyder
Member#: 10039
intercooler w. very little cutting is in and everything lines up. pics to follow in a hour
scotty ur one of those ppl that think they know everything. it seems u need to be in control at all times. u get very upset when someone has a different way of doing things and if they don't do it ur way ur like a little 3yo that doesn't know how to react to it. so u just spurt out some comment out of
that thing under ur nose.
so to finish off i used no zip ties and no ghetto fabs.... so scotty. who has the cleaner install and used no ghetto eng.
FS: JDM V7 STI Intercooler TDQuiksilver Engine/Power/Exhaust 5 03-21-2008 09:03 PM
FS: Mint JDM V7 STi intercooler scooby9 Canada Region Private Classifieds 0 06-30-2007 02:28 PM
FS: JDM v7 STI intercooler darkcrystal05 Engine/Power/Exhaust 15 06-11-2007 02:01 PM
WTB MD: JDM V7 STI Intercooler Splitter soobaviator Private 'Wanted' Classifieds 11 12-07-2006 03:33 PM
JDM V7 STi Intercooler brandon_bxtr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-10-2005 12:46 PM
