Old 05-11-2006, 12:28 AM   #1
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Default Seat belt latch nut!
Ok, so I need a seat belt latch nut. I measure it, M11x1.25. No big deal right? Hah.
Ace doesn't carry it, nor any hardware stores as far as I can tell. Went to the dealer, they looked it up. $50! Parts guys thought that was wrong, so he called Subaru. Subaru says that's for a 100pack, but the dealers screen supposedly doesn't show that. But still, can't even get 1 nut! Actually, I want 2, but still.
Besides for a junkyard search, anyone have any ideas? Or, anyone have some laying around?
They are 11x1.25 flange nuts.
Speedwagon is offline   Reply With Quote
Old 05-11-2006, 12:39 AM   #2
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
M11 exists? I can't find it on mcmaster-carr and that's not good.
MCarp22 is offline   Reply With Quote
Old 05-11-2006, 12:51 AM   #3
Speedwagon
Member#: 19681
Green
Well, 10 doesn't fit, and 12 is too big. I measured it with my micrometer, and it showed 11mm.
But I dunno, maybe I'll go measure it again. Could be I'm just retarded.
Old 05-11-2006, 09:37 AM   #4
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
I'm pretty sure there's no such thing as M11 nuts.
Are you sure the M10 you tried was the proper thread pitch?
KD7000 is offline   Reply With Quote
Old 05-11-2006, 03:36 PM   #5
Dobes
Member#: 164
2008 Exige S240
Grab a picture of the nut. I probably have one I can ship to you for a couple bucks.
JD
Dobes is offline   Reply With Quote
Old 05-11-2006, 03:59 PM   #6
blueb3
Member#: 108471
Are you talking about the nuts that hold the seat belt receiver to the seats (BG)? Or the bolts on the later models? The bolt is a 7/16 with a 20 thread. (picked up two of the bolts at Lowes, they were the same size as the fat bolt that holds the back inside part of the seat to the middle of the car) I have both nuts sitting in the garage if you want them.
blueb3 is offline   Reply With Quote
Old 05-11-2006, 05:13 PM   #7
Dobes
Member#: 164
2008 Exige S240
Be careful with what you replace those bolts with. Most of the crap hardware at Home Depot or Lowes probably isn't strong enough to be a direct replacement for the OEM hardware - that's a pretty important bolt! I'm assuming the OEM stuff is Grade 8 or higher. The same goes for suspension and brake hardware, don't skimp because inferior hardware can cause a catastrophic failure.
JD
Old 05-11-2006, 05:21 PM   #8
Speedwagon
Member#: 19681
Green
blueb3- Yes, that's the nut I'm talking about.
Dobes- If you look on your Legacy seat, where the seat belt latch is, that's the nut I need. I'm actually missing both of mine. I have at least one in a box(somewhere).
Old 05-11-2006, 05:22 PM   #9
Speedwagon
Member#: 19681
Green
No, I'm not. Like I said above, I might just be retarded in my measurement.
Old 05-11-2006, 05:23 PM   #10
Cajual
Member#: 12900
1997 Legacy GT-Turbo
Quick Silver Metallic
This is correct... when I installed my STi seats, I was missing the nuts and was told:
"ALL seat belt mounting bolts/locations in ALL cars, Foreign or Domestic by any Mfg., are 7/16 - 20. This is a federal requirement/standard! All hardware provided by aftermarket harness mfgs. meet this standard as well."
Cajual is offline   Reply With Quote
Old 05-11-2006, 05:39 PM   #11
blueb3
Member#: 108471
Speedwagon, shoot me a pm with your address and I will mail them out to you.
And the bolts I picked up were grade 8, Definately not someplace to skimp on.
Stripped out seat belt poly nut.... Need assistance. Effex Unlimited Service & Maintenance 3 05-18-2007 03:55 PM
How to remove stock seat belt latch from stock seat? Hokie-wrx wagon Interior & Exterior Modification 1 08-04-2005 09:32 AM
Seat Belt bolt/washer/nut setup for aftermarket seats ?? 02_Forester Interior & Exterior Modification 11 07-14-2005 05:11 PM
howto get rid of seat belt latch rattling? msun2000 Car Audio, Video & Security 2 08-27-2004 05:28 PM
Urgent help needed... seats, seat belt latch and anchor kgb Interior & Exterior Modification 3 09-30-2003 12:35 AM
